Old 10-08-2015, 09:59 AM   #261
2kool4skool's Avatar
That pump is the one I just sent back.
For the Onan, I ordered this one: http://www.amazon.com/gp/product/B00..._prd_ttl_sol_6
I will try this one on the Yam first, we leave on the trip very soon so I need something. If I can get the Onan going, I will re mount it.
Thanks Nate!
Don, Mary and Spooky the cat.
Old 10-08-2015, 12:14 PM   #262
Engine: 466DT
I'm curious how that Airtex works out for you. If it works good, maybe I'll get that one for my backup one then.
Hvbuzz is offline   Reply With Quote
Old 10-09-2015, 05:13 PM   #263
The Airtex works the Onan, plenty of flow. I am still having fueling issues, the carb will come of for a good cleaning next.
The AirTex fuels the Yamaha a bit too much even at 1/2 lb pressure.
I mess with it after our upcoming bus trip, for now it's the Yam on the ground and cabled to the bus.
Old 10-27-2015, 07:39 PM   #264
Installed a Planar diesel air heater today. 14k btu, like a little jet engine when it spools up and gets HOT!
Need to fab some fuel tank brackets for a permanent solution. 7L fuel=14 hrs on high thrust.
Old 10-28-2015, 06:57 PM   #265
Tank in and everything tested. Works well.
Old 12-03-2015, 09:39 PM   #266
Old 01-28-2016, 05:24 PM   #267
New carpet top interlocking mat throughout. Just finished, need to mold the edges.
Old 01-28-2016, 05:27 PM   #268
The Planar has been working very well. With outside temps of 30-40 it uses about 1 gal. per 24 hrs.
Old 02-26-2016, 07:53 PM   #269
opus's Avatar
Chassis: All-American R/E
So where are you at with the genset saga? My Onan runs great after I rebuilt the carb. Parts are almost impossible to find and if you do, expensive. I had to make some small round gaskets out of leather.
I had contemplated the same Yamaha as well.
Old 02-26-2016, 08:31 PM   #270
I did clean the carb and reinstalled with no start...Even with test fuel so I need to address the ignition. I have new plugs, points and cond. but the coil is suspect. I like the Yamaha a lot, very quiet and enough power for our needs. I would like to fabricate an exhaust extension though.
Old 02-26-2016, 08:49 PM   #271
opus's Avatar
I have a manual for a BFA 4.0 if thats what you have and if you need it. Points on those are a bugger, plus the little plunger thing can get worn out too.
I dont need much power either. Biggest we do is a college dorm type fridge. I have a Champion 4.0 that is a little quieter than the Onan. Starts first pull too, no fuss. I love the Onan, until its cold and I have to fiddle with it. I dont want a diesel.
My deal with the Yamaha was having enough fuel capacity without spending another chunk of money to make it work.
Old 02-27-2016, 12:33 PM   #272
Understood on the fuel volume thing. I'm adding a spare 15 gallon tank to feed my Honda EU3000.
Old 02-29-2016, 06:10 PM   #273
Finally built my spare tire holder. It looks low but it's higher than the front axle.
Old 02-29-2016, 06:33 PM   #274
opus's Avatar
Looks like my generator rack:
One our generator topic, another generator gem I own:
Old 02-29-2016, 07:18 PM   #275
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
I have the EM600, absolutely love it!
The automatic choke is a PITA though, i will probably convert it to a manual one in the spring.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 02-29-2016, 07:31 PM   #276
nice, right below the battery box, I would have never thought of that, it your spare on a rim?
Old 02-29-2016, 07:41 PM   #277
opus's Avatar
Yes, it indeed is.
Old 03-25-2016, 05:12 PM   #278
Spare is mounted.
Went with the Pinnella remote kit with a pulse pump. Now I can pump from my onboard 10 gallon gas tank with the genny 1 gal. for reserve.
Charge!!!! /\/\/\/\/\/\/\-
Old 03-31-2016, 08:27 PM   #279
The Pinnella kit worked flawlessly, running the gen twice a day for a 1/2hr. to heat water.
Old 11-07-2016, 06:08 PM   #280
Added an auto transfer switch to our elec. system. Used to just leave the fridge on batts./inv. even when plugged in, now it's on 120v automatically and back to batts. when off grid.
I drank the Kool-Aid opus Skoolie Conversion Projects 176 06-03-2016 09:12 AM
Plan in works to fix 'Electric Kool-Aid Acid' bus lornaschinske School Bus News 0 03-16-2013 11:25 AM
15 kool buses for auction citrus co Florida racetearoffs2 Classifieds | Buy, Sell, Swap 2 02-12-2009 03:01 PM
Olde Skool update 7-7-07 KaptnKAOS Skoolie Conversion Projects 0 07-08-2007 12:42 AM
Old Skool's Got brake lights !!! KaptnKAOS Conversion General Discussions 16 06-26-2007 02:41 AM
