Old 06-18-2015, 07:04 PM   #1021
Chassis: I.H.
Originally Posted by Tango View Post
HolyBus --- Love the simple, retro look of that dash but I'm looking at a minimum of seven gauges. I hope to keep a similar appearance while accommodating all the extra diesel gauge stuff.
Its just an example. You could install a couple combo gauges. That would cut down on the number of total gauges to make room for.
I really like this one:
Don't shoot the messenger
Old 06-18-2015, 07:43 PM   #1022
Thanks HB --- I have seen (and liked) some of the combo gauges and will likely incorporate at least one in the grouping, but they don't make combi's for much of what I need...EGT, boost, fuel pressure, trans temp, etc., so I will still wind up with a lot to fit in. I am saving some space by using a digital "Tiny Tach". Still investigating what route to go with the speedo. I've been told there are GPS units these days that are more accurate than the mechanical type..but who knows. The adventure continues.
Old 06-18-2015, 10:53 PM   #1023
Someone here had a vintage bus somewhat like yours with a GPS speedo a couple of years ago, but Old Timers' Disease prevents me from recalling who. The dial was nice and clear like the one in HolyBus' cluster, not with "2-inch thick" letters and numbers that ran together to obscure the reading like a lot of dials that came out of the 1950s .
I do remember I was impressed.
Old 06-19-2015, 12:45 PM   #1024
Hey RedBear --- Thanks for the heads up. Dug around and found a couple of references that led to the site below. Might come in handy if anyone else is working on gauge issues. They seem to cover a wide range very well. Looks like the answer to most of my gauge needs. Thanks again.
Gauges, Custom Gauges, Tachometers, Speedometers, Shift Light, Pod
Old 06-19-2015, 01:43 PM   #1025
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
:click: :click: And bookmarked
Captain Obvious on deviantArt
Old 06-19-2015, 03:11 PM   #1026
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Same here!
M1031A1 is offline   Reply With Quote
Old 06-19-2015, 09:47 PM   #1027
Is this the World's greatest Forum or what!? My personal thanks to all the many contributors who share their finds & experience. Opinions welcome too.
Also to the Site Team who does all the hard work. Many gracias for building such a worthwhile community where all us misfits can gather.
Old 06-21-2015, 10:51 PM   #1028
Grrrrrr --- Still waiting on doghouse parts so I am stuck with piddling with the rear deck thingy for the moment. Have all the steel rough cut but do not have a floor level enough to tack it all together on that will yield anything close to square and flat. May have to send it all back to my sheetmetal shop. They have 20' x 10' welding tables.
Old 06-24-2015, 08:34 AM   #1029
Chassis: I.H.
Boost and egt combo. I've also seen a digital screen that lets you choose what you see and displays it like a cluster of round gauges on its screen. It may be too electronic for the bus/engine setup.
Old 06-24-2015, 10:39 AM   #1030
Thanks HB --- The only switchable digital set up I have seen in person was on an extreme pickup truck at a car show couple of years ago. A touch-screen arrangement that covered dozens of parameters but required way too much messing with for my taste. My personal preference is still for individual gauges that can be read at a glance.
Back in my motorcycle racing days we used a simple trick to minimize how much eyeball time was needed to check the gauges. All I ran were a tach, water temp & EGT but we would rotate the housings so that when the needles were at their ideal points...they would all be at the 12 o'clock position...straight up. That way you didn't have "read" each gauge...just a single quick glance to verify they were all close to where they should be.
Note: At a little over 200 mph you are covering about the length of a football field per second.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
