Old 11-29-2015, 12:05 PM   #1261
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Good to see an update!
Onward, indeed sir.
Old 11-29-2015, 01:50 PM   #1262
Pretty slick dip stick. The round knob looks perfectly functional.
I'd have known you were back from just a glance at the first pic--I saw your multi colored bed roll just inside the door!
How about using one of those little electric winches Harbor Freight sells, you know, the ones rated at 2000# but only good for 200#. That way you could raise lower your spare tire with no effort at all. That didn't come out right. I didn't mean your spare tire, I meant the bus's spare tire. Wait, that doesn't sound right either!?! Keep the pictures coming! Jack
Old 11-29-2015, 02:27 PM   #1263
All my spare tires could use some help Jack. And while an electric winch might be nifty, a manual crank might help burn off part of one of them. Though I confess that I hope to not be using it often enough to make a difference.
Which for some reason reminds me of all my ex-wife's exercise equipment. Somehow they all quickly tuned into expensive clothes racks.
Old 11-29-2015, 08:24 PM   #1264
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I did just that-a boat trailer winch to hold up my spare tire. Works fine. Simple-cheap-few moving parts.
Old 11-30-2015, 01:08 AM   #1265
Sounds just like what I have on my parts shelf.
Old 11-30-2015, 11:48 AM   #1266
Just dropped off some steering parts at my local machine shop. Need to have a section of serrated spline fabbed from scratch in order to hook my steering column to the gearbox. Turns out that having custom spline shafts made is not cheap (surprise, surprise). Will get some pix when it comes back.
Note to anyone considering a complete rebuild on a classic (aka; "old") school bus...
START YOUNG!
ONWARD!
Old 11-30-2015, 12:01 PM   #1267
now you tell me!
Old 11-30-2015, 01:18 PM   #1268
Too late for us Jack! --- I'm beginning to wonder if maybe I should take someone here up on the offers to give away their wheelchair lifts.
No Geezermobile is complete without one.
Old 12-09-2015, 06:38 PM   #1269
More drafting & fabbing with nothing yet to show for it but greasy paper and worn out pencils. Still working out/on the spare tire carrier...steering column...doghouse...driveshaft...parking brake...exhaust system...and...the replacement for my frames main crossmember. That last one has been a head scratcher. Can't go any farther on the driveshaft and park brake until the original crossmember is out of the way. It's tempting to just weld some steel in, but these old frames don't handle welding very well so it has to be either bolted up or hot bucked riveted. And since all I have are pop rivets...it looks like some drilling and bolting are in order.
Pix...some day. Meanwhile, back to the drawing board. Literally.
ONWARD!
PS...in addition to starting a project like this at a young age...I should also add you would also be well advised to acquire a machine shop and sheetmetal works as well.
Old 12-11-2015, 09:25 PM   #1270
opus's Avatar
Chassis: All-American R/E
Say....have you got a bead roller?
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
