Old 12-14-2015, 10:45 AM   #1301
I do understand the limits and appreciate the connection. Trying to close the deal as we speak.
Update:
$200 with shipping and hopefully it will be here in a few days and as described. I am always a bit nervous buying parts unseen, but hey, here we go.
Old 12-14-2015, 11:17 AM   #1302
And...just to try and clarify for Jack (or anyone else I have confused)...
What I am doing is stacking two of the steering shafts together with an inch or so trimmed off of one to get the length I need. That's why I need the male serrated input shaft. It will weld to the top end of the one coming up from the gearbox and the upper shaft will use it's existing female clamp to connect to the lower one. Throw in a steering shaft support bearing between the two and it might even work. Will still need to do some machining but I think I can pull it all together.
Make any sense?
If I can ever get all the parts in one place, I promise...pics.
ONWARD!
Old 12-14-2015, 08:01 PM   #1303
Hey Tango. That makes perfect sense and will work just fine I'm sure. I guess I'd ask why not use a similar pair (input shaft/intermediate shaft) from some other easily had and more economically priced donor for your hook up between the stacked shafts? Jack
Old 12-14-2015, 09:47 PM   #1304
Chassis: GMC blue bird
Engine: 350 chevy
Hey Tango, I was looking at some buses for sale here in Colorado on craigslist and found a 1947 chevy short bus and wanted to share it with you...
https://cosprings.craigslist.org/cto/5334547774.html
axis is offline   Reply With Quote
Old 12-14-2015, 11:06 PM   #1305
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
When in doubt, build it like a race car.
steering joints @ Speedway Motors, The Racing and Rodding Specialists
you can also get a slightly oversized heim joint for a support. (like a .754 for a 3/4 shaft.)
Old 12-15-2015, 09:19 AM   #1306
The Isuzu is such an odd duck that nothing else fits anything on it. The serrated connection is 11/16 by 38 splines and the shaft itself is 1-1/16 which makes it just about impossible to adapt to. I did order the gearbox and will mount the input shaft at the top of the first section of column. At the same time, that part will have a 1" OD section machined so that I can use the largest "standard" support bearing. Which, BTW came from Speedway. From there all I should need to fab is the bracket to hold the support bearing.
Ain't we got fun!
Old 12-15-2015, 11:06 AM   #1307
GET ER DONE then you can buy that '47 as a fifty something birthday present for yourself! Jack
Old 12-15-2015, 11:34 AM   #1308
"Fifty Something"??? I can't even remember my fifties!
Old 12-15-2015, 11:57 AM   #1309
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Maybe Jack meant after buying the '47 you could buy a '50's bus....... LOL
Firearms stand next in importance to the Constitution itself. They are the American peopleís liberty teeth and keystone under independence. ó George Washington
M1031A1 is offline   Reply With Quote
Old 12-16-2015, 12:56 PM   #1310
Hey M1 --- how goes your build? Don't think I've seen any pix lately.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
