Old 01-03-2016, 05:40 PM   #1321
opus's Avatar
Chassis: All-American R/E
Tango, just wondering do we get consultation wages and paid vacation through all this??
Old 01-03-2016, 06:14 PM   #1322
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
My vote is measure, drill and weld reinforced nutplates on the other side and bolt it in place
Captain Obvious on deviantArt
Old 01-03-2016, 10:28 PM   #1323
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
I'm sure my vote will get "screwed".......
M1031A1 is offline   Reply With Quote
Old 01-04-2016, 09:55 AM   #1324
Thanks for reinforcing my decision guys. Yesterday I went to the Depot and stocked up on new drill bits, then came back and started punching holes. I am using 1/4" self tappers all around with a heavy dose of seam sealer under the mounting lip. The floor in this old gal is heavy metal and in great shape just about everywhere, so like the wheel wells...the box will get screwed. Down, that is. Also got a coat of primer (self etching) over all and started laying down a rubberized coating on the inside. Will add some more (about 4 coats) then top it with truck bed liner for a little tougher finish. All that is to protect the steel from any gassing from the batteries. The LifeLine batteries are supposedly fully sealed, but...I want to play it safe. It will also get a heavy dose of undercoating on the underside as well. Then comes the insulation. I figure if I can keep the batteries closer to the interior temp they will give me peak performance and a longer life. We'll see.
More pix in a day or so.
ONWARD!
Old 01-04-2016, 10:05 AM   #1325
opus's Avatar
Will there be a vent, incase gasses do form?
Old 01-04-2016, 11:20 AM   #1326
Roger a small vent. I'm adding one in spite of the claims it is not necessary. Who knows, at some point I might have to replace the fancy, schmancy LifeLines with some WallyWorld Acid Queens.
Old 01-05-2016, 05:14 PM   #1327
Howdy All --- just ran across another set of handy calculators that folks here might find some uses for. Courtesy of Spicer no less. They include more than I can list here so take a look and see if there is anything there you can use.
Spicer Tool Kit
I found the above while trying to calculate my driveshaft speed (like everything else on this rig...I have to make one from scratch).
Below is the formula I found for that puzzle just in case anyone is too chicken to ride under the belly and count the RPM's going down the road. This one courtesy of The Driveshaft Shop. Thanks guys.
To check for critical speed, calculate this equation:
Top speed x 336 (a constant) x rear ratio (like 4.10), then divide it by the tire height (such as 28” tall tire).
Here is an example:
Top speed is 160mph x 336 = 53760 x rear ratio of 4.10 = 220416, then divide this number by the tire height, 28”. This car would have top RPM of 7872. Now the shaft being designed will need to be able to so this RPM.
MINE=
65mph x 336 = 21840 x 4.30 = 93912 divided by 33.6" = 2795 rpms
Old 01-05-2016, 05:48 PM   #1328
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
I kinda like the weld nuts with bolts over the self tappers myself, with something that heavy.... but that's me.
Old 01-05-2016, 05:55 PM   #1329
opus's Avatar
Thats handy!!
Old 01-06-2016, 02:22 PM   #1330
Is everyone else enjoying the same crappy weather we've been having here in Houston for the last two months!? Chilly, overcast and your choice of either drizzle or rain. I know, I know. Some of you folks have that mysterious white stuff to deal with but, hey. This is supposed to be the Tropics! I want my share of Global Warming! At least then I could do a little paint work. As it is, my "quick dry" rattle can work takes 3 days to set up.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
