02-07-2018, 12:12 PM
#3041
After the war, civilian industry (and civilians) benefited greatly from the many developments made by the military in numerous fields.
We would never have known the joys of microwave popcorn if it wasn't for leaky radar cooking stuff all around it!
02-07-2018, 03:15 PM
#3042
Right and people like Tango and me were made during the war--but only of the good stuff and look how well we have weathered the years.
02-07-2018, 03:54 PM
#3043
Chassis: Saf-T-Liner MVP ER
sure seems like everything made in the war was really just designed to last till the war was over.. and of course the post-war economy sure showed that to be true as some of the best things ever built in this country were done in the 20 years post WW2
Not even that long.
Many aircraft were built with the expectation that they would last weeks. They didn't even bother painting many of them.
02-07-2018, 05:35 PM
#3044
Year: 86
Chassis: Ford B700
Engine: 8.2
Hey man.
Sent you a PM of the Allison info I received.
Let me know if you didn't get it.
It is the same #12 fitting but my contact recommended a J I C 12 with o-ring so the fitting could swivel as needed.
Good luck
02-07-2018, 05:38 PM
#3045
Year: 86
Chassis: Ford B700
Engine: 8.2
I will be back there in the morning but only for an hour to meet the inspector.
But I have there specific numbers and they know me but name now so i can call at any time.
02-07-2018, 07:37 PM
#3046
Originally Posted by Jolly Roger bus 223
Hey man.
Good luck
thats the one I used.. the one that can swivel. you tighten the adjusting nut once the fitting is turned the direction you want. its a 90 coming off of the transmission.
02-07-2018, 09:33 PM
#3047
Just what I need! Thank you!
02-08-2018, 01:54 PM
#3048
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
02-08-2018, 04:09 PM
#3049
Hey Jack...maybe we should start The Vintage Bus Owners Club.
You know...where it's the owners that are vintage(?).
Nah, someone would want to make up rules and it would get too complicated. I guess we'll just have to stay Old Farts.
02-08-2018, 04:12 PM
#3050
Not me. I'm well into my second childhood. Getting younger every day.
Robin
Nobody's Business
02-08-2018, 05:18 PM
#3051
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Hey Robin,
Don't you have to PROGRESS BEFORE you regress?????? Just askin'...
M
02-08-2018, 07:42 PM
#3052
Yeah, I've seen better days. I'm pretty sure my progressive period is basically over. Every day I do a little wheel spinning and some gear slipping and there goes another day. I'm on the permanent sick, lame or lazy list or in other military terms I've got a permanent profile against physical activity due to a severe neurological disorder. I've been put out to pasture. I don't have to be progressive. I vegetate very well. I've finally got all the time in the world to do things but I can't do much now. Its wonderful how things work out, isn't it?
Robin
Nobody's Business
02-08-2018, 09:56 PM
#3053
Got a buddy just down the street who is a world class sculptor. At 80, he decided to start counting back down. As near as I can tell he is now about 70...and still working day in and day out making giant concrete sculptures. David Adickes. He is one of my heroes.
Meanwhile...back at the ranch house...
More headway on the battery box. Some grinding...some wire brushing...some drilling...some welding...etc., etc.
I realized the hinge would never lay right if it was on top of all those diamonds, so they had to go.
Cleaned up the metal then drilled some 1/4" holes down each side of the hinge. Welded one side...nuts & bolts on the other.
Eureka!...it opens and closes with a nice, snug fit.
And to keep it snugged down, I drilled and tapped for some 1/4" x 20 bolts. I am lovin' these low profile, hex head bolts.
Still need to paint & insulate but getting closer. The search is on now for some watertight through wall electrical lugs to connect the battery cables.
ONWARD-ISH!
02-08-2018, 10:52 PM
#3054
Man, you're getting closer and closer. Have you reserved Rehab, for the grand revel?
02-08-2018, 11:00 PM
#3055
Howdy 1ol --- No need for reservations since I'm there pretty much nightly. But...I am actually working on a deal with the owner for a reserved parking space with electric hook up when I'm in town.
I'll be building another big bench to cover that.
02-09-2018, 06:02 PM
#3056
" One small step..." --- Well, actually, three small steps. Spent way too long cleaning up the metal. Diamond plate is a royal Beotch to get down to bare metal! Can't sand it...paint stripper make a mess...so it was a wire wheel or go rent a sandblasting rig. The wire wheel won out.
BTW...NEVER EVER use a wire wheel without a full face mask. Those little stainless needles fly off at about two hundred mph and will sink deep into your eyeballs. My clothes were filled with them by the time I was done. Even had one stuck into my shoe.
Once all the wheeling and dealing was done, I applied a rust converter. Will paint tomorrow.
One more BTW...Read the instructions on any rust converter you use. Nearly all require a 24 hour minimum cure. Paint over it too soon and it can actually cause rust to form.
Everyone have a splendid weekend working on your Skoolies!
02-09-2018, 08:13 PM
#3057
Mighty fine my friend.
02-09-2018, 10:46 PM
#3058
Thanks Jack...still a ways to go but still hammering at it.
But then...screw Baby Steps! I want to win the Lottery and pay someone to wrap this thing up!
02-10-2018, 09:09 AM
#3059
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
This projects comin' along fine Tango! Can't wait to see the finished piece.
02-10-2018, 09:34 AM
#3060
I have that same thought quite often.
