Old 04-14-2016, 10:04 AM   #1531
opus's Avatar
Chassis: All-American R/E
Originally Posted by Tango View Post
Never had any lifting issues even where it met our deck and got tons of sun. There are a couple of similar looking products that are lightweight and I believe vinyl. The Pirelli is quarter inch thick rubber.
Hmmm...I dont believe this stuff to be rubber. Looked to be a heavy vinyl. They had to use a wood mallet to whack it together so it would lock.
Is yours flexible? This are pretty stiff tiles.
I think I'd like the rubber!
Old 04-14-2016, 10:50 AM   #1532
Looks like a good choice and if it ever does wear thin you can ship it back to Pirelli for a recap. Jack
Old 04-14-2016, 11:54 AM   #1533
Chassis: Blue Bird
Engine: ISC 8.3
How's that stuff rate for heat transfer (or insulation, depending on perspective)? I've been thinking about making a radiant heated aisle section in my rig, probably with PEX fastened to the bottom side of steel or aluminum sheet. But smooth metal sheet would be slick when wet and I don't want to go with a diamond board because that would be uncomfortable on bare feet. The Pirelli would be a nice covering if it conducts heat alright.
Old 04-14-2016, 12:31 PM   #1534
Chassis: International S3800
my experience with it is that it was Very much insulating.. at least from my perspective building hotrods laying on that as opposed to laying on the concreete floor.. it seemed like the furnace in that garage took MUCH LESS time to get it roasty toasty in there after that type of material was layed down.. I only had a chance to work on it for one winter until my house was built then I moved to my own garage (which doesnt have it).. im a LOT colder working on my garage floor and I have a bigger furnace....
I do know the standard "fake laminate" flooring has really nice heat transfer properties.. I cant remember what they call it.. its not real wood but its a floating flexible floor that looks like wood.. I did an electric heat loop for a friend's bathroom under it.. and it got quite warm very quickly.. you would have no trouble heating through that with a PEX glycol loop..
Old 04-14-2016, 02:17 PM   #1535
Howdy All ---
Opus...yep, all rubber, not vinyl. Has a fair amount of flex and lays down beautifully. I installed it in my loft using a 2-part epoxy permanent adhesive but will likely go with a little lighter adhesive so that the tiles can be taken up if need be down the road. Does require a special adhesive just for rubber.
Jack...based on what I have seen of this product, I will be long dead and gone before it will need to be re-capped unless someone takes a grinder to it. But I like your thinking.
FamWag...The rubber is actually a surprisingly effective insulator for both heat and sound so I don't think it would pair well with an in floor or radiant heating system. I do like that it's mass does a pretty good job of dampening vibration.
Cadillac...you are correct sir. It is surprisingly insulating. That's actually one of the excuses...er, reasons I used to justify my choice since I don't have room for conventional, thick foam.
Old 04-14-2016, 02:22 PM   #1536
opus's Avatar
Howdy All ---
Ahhh. There was no adhesive used in this garage, just laid down like....floor tile? I'm curious now, I should find out.
Would it be like this flexible?
Old 04-14-2016, 03:06 PM   #1537
Opus --- Probably a bit less. The stuff in the vid appears to be 1/2" thick rubber foam. Mine is very dense solid rubber close to 1/4" thick. And it does need to be adhered to the base flooring, in my case, plywood.
And, BTW...lots of colors available...
PRF Group
There are also a few knockoffs of the Pirelli that cost less but as I recall are only about 1/8" thick.
Old 04-14-2016, 03:21 PM   #1538
One more "BTW" --- I did have some of the lock together, foam rubber stuff down at my last house. My dog's claws trotting across shredded it pretty quickly.
Old 04-14-2016, 03:48 PM   #1539
opus's Avatar
This is the stuff: http://www.swisstrax.com/cointrax-garage-flooring/
Old 04-14-2016, 08:52 PM   #1540
Hey Tango.As you know, I'm working on my Ecotemp on demand water heater. As you will recall I let the thing heat up the water so much that the pvc pipe ballooned and a seam leaked. I don't know why I didn't think of it before, but wiring in a temp control switch would have saved my a$$. I've been using one to cut in and out an extra cooling fan for my genny and it has worked perfectly---so why not use the same device on the Ecotemp? Sometimes I'm a slow learner.
This switch 10A 12V Digital Temperature Controller w Sensor Thermostat Switch 40 120C US | eBay
controls my genny temp within 2.5 degrees F and all for about ten bucks. Jack
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
