Old 04-14-2016, 10:29 PM   #1541
Brilliant Jack! --- Hopefully no more "China Syndromes".
Old 04-14-2016, 10:31 PM   #1542
Robin97396's Avatar
The temperature sensor from an old water heater is the right range. Commonly used in home made smokers to control the electric hot plate.
Old 04-14-2016, 10:58 PM   #1543
opus's Avatar
Chassis: All-American R/E
Hey Tango.As you know, I'm working on my Ecotemp on demand water heater. As you will recall I let the thing heat up the water so much that the pvc pipe ballooned and a seam leaked. I don't know why I didn't think of it before, but wiring in a temp control switch would have saved my a$$. I've been using one to cut in and out an extra cooling fan for my genny and it has worked perfectly---so why not use the same device on the Ecotemp? Sometimes I'm a slow learner.
This switch 10A 12V Digital Temperature Controller w Sensor Thermostat Switch 40 120C US | eBay
controls my genny temp within 2.5 degrees F and all for about ten bucks. Jack
Jack, what happens if for some reason that sensor dies or trips something and is no longer working? Is there a safe default setting that it would fall back on?
Old 04-15-2016, 10:27 AM   #1544
Opus. the Ecotemp has several safety features built in. It turns itself off automatically after 20 minutes, it shuts down immediately if water pressure or flow does not meet system requirements and it has the normal high pressure relief valve like a standard water heater.
The reason I want the temp control is because the hot water system is being used with a continuous loop flow circuit to and from the fresh water tank and eventually the water in the tank heats up (especially when near empty). The Ecotemp continues to add heat according to the burner rate and flow rate I originally set and the water gets hotter and hotter (30 degrees above incoming temp until the upper factory limits are reached). The thermostatic switch will shut the burner down when the temp of the water coming from the heater reaches my setting. Had I been satisfied letting water run down the drain while I waited for the heater to do its thing, I wouldn't have encountered the problem I had because the incoming water temp would have remained constant.
Hope all this made some sense. Jack
Old 04-15-2016, 10:46 AM   #1545
opus's Avatar
Perfect. Seems to be pretty configurable as well.
Old 04-16-2016, 02:35 AM   #1546
One more Baby Step --- Got the last section of my stainless exhaust in the mail today and just had to put it on.
Probably not a big deal for those of you whose buses CAME with some kind of exhaust but it was a beautiful moment for me.
And...most importantly...it's shiny!
ONWARD!
Old 04-16-2016, 06:31 AM   #1547
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Shiny is always good
Old 04-16-2016, 08:15 AM   #1548
I love exhaust.. after all im a former Hot-Rodder so shiny pipes coming in the big brown truck (or being lucky enough to live in the state where JEGS and Summit are HQ'd) always made for a super good day!!
Lookin good! I like it
Old 04-16-2016, 08:28 AM   #1549
Hey, I know its not exhaust.. but I thought of these to consider for your Dash A/C and defrost...
the size looks workable for in the front area of a Bus too..
this is the inside unit... it has Floor / panel / Defrost outlets and a dash control.. you can duct it in however you like..
Evaporator 960 A - 50 001 703
seeing the underbody of your bus made me think of This condenser unit too because it mounts underneat the bus and doesnt require room in front of your engine radiator or having to try and locate in the skirting area...
Condensers 102 - 50 001 479
something to think about anyway.. im likely going to use the above condenser in mine
Old 04-16-2016, 10:24 AM   #1550
opus's Avatar
Ok, I'll ask. You took the exhaust to the other side of the bus....why?
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
