Old 05-22-2016, 08:47 AM   #1681
Chassis: International S3800
wow!! thats bigger than the separate fuel and water separators on my 360... I found my water separator and fuel filter are totally separate devices.. mine are both under the hood.. only issue I would have with not having them close to the engine would be cold winds if you are way up north in the middle of winter... you never know just how winterized the diesel fuel is esp if bought down south..
is your filter setup 2 separate things where you could locate them in different spots or is it a single unit with 2 elements?
are you using Hydra-sist brake booster ? (power brakes that operatoe off of the power steering pump so you dont need a vacuum pump on your diesel?).. maybe thered be room on the firewall..
Old 05-22-2016, 11:20 AM   #1682
There are smaller double units and much smaller singles, but after reading up on a bunch of different diesel forums, it sounds like things are getting much worse as far as fuel quality.
No room on the firewall...heck...I am still trying to find space there for the master cylinder! Will be playing around with it some more today but it looks like underbody will be about the only option for me.
And if your water separator is independent of the fuel filter...make sure it is first in line as far as fuel flow.
Back to work.
Old 05-22-2016, 08:46 PM   #1683
Slow Sunday --- Got the throttle bracket and bell crank assembled today. Other than that, just measuring and figgering on other stuff.
This is the adjustable hot rod bell crank from Raceway. I need 180 degrees to make this work.
Here it is attached to the bracket I made. Note the extra bracing for rigidity.
Same thing, just a full view.
Having to make every single component from scratch does seem to slow things down a bit.
ONWARD!
Old 05-22-2016, 09:17 PM   #1684
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Well, build it like a tank and ya'll never have to fix it again! That's my motto!
M1031A1 is offline   Reply With Quote
Old 05-25-2016, 11:45 AM   #1685
Yippee-Ki Yo! --- UPS just delivered both my new Allison shifter and my dual fuel filter kit. Time to get back to work.
All mechanical T-handle for a 6-speed with park.
The only wire on this rascal is to backlight the indicator.
Will get pix of the fuel filter set up later.
ONWARD!
Old 05-25-2016, 11:53 AM   #1686
opus's Avatar
Chassis: All-American R/E
Maybe that little T handle is a line lock for doing burnouts!! Nice...
Old 05-25-2016, 01:05 PM   #1687
nice lookin shifter!!.. so looks like you have OD.. (up to 6).. and then if you go D.. im guessing you'll only go up to 4? and then you can go from 4 to 2, 1.. interesting if thats the way it works.. makes sense though!.
Old 05-25-2016, 07:54 PM   #1688
Sweet Tango. I don't mean sweet Tango, what I mean is Tango that's a sweet shifter--er ah I hope you mean what I know!?! Anyway, I like the "T" handle better than the push button on mine.. The PB would be OK if the shift lever was to my right when I drive but the only space available without having to make up a new cable put it to my left on the floor. The floor location is good, but I'd like to graft a second thunb on my left hand to operate it. The shift pattern looks to be the same. Jack
Old 05-25-2016, 10:32 PM   #1689
Robin97396's Avatar
Finally the truth come out between you two.
Both of you have done some amazing things, one little step at a time. I'm pretty sure that shifter increased your top end already Tango, or is it Sweet Tango?
Old 05-26-2016, 12:18 AM   #1690
OK folks...let's keep it clean here.
Hey Jack...is yours a 6 speed? The double OD must come in handy. At least, that's what I'm hoping for.
Caddie...The way I understand it is "D" will handle everything from low to 4th on it's own but you can downshift as needed. "OD" will handle everything from 6th on down with the downshift option. Maybe Jack can chime in on this. Or is it Sweet jack?
Meanwhile, today I built a mount and installed the fuel filters.
They come with vacuum gauges so you can tell how clogged they are. They are pretty much under the pilots seat since I need to keep the engine bay for other stuff but they have plenty of ground clearance. BTW...my engine has a stock fuel filter as well. I just wanted some extra insurance after reading a few horror stories about today's fuel.
And I couldn't resist one more shifter shot. This is with the mounting wedge attached that will be fitted on the dash, just to the right of the wheel. Like Jack, I came close to a floor mount on the left, but dangit...I'm just not that ambidextrous! Besides...my parking brake will likely have to go there. Somewhere.
ONWARD!
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
