Old 06-09-2016, 10:02 PM   #1741
Originally Posted by Tango View Post
PS...this will be under a big cottonwood tree and overlooking the washer pitching court.
The washer pitching court? What do you do there? Pitch washers, I assume. But what kind? Lock washers? Dishwashers? Something somewhere between bocce ball and frozen turkey bowling, likely.
Old 06-10-2016, 09:06 AM   #1742
Thanks Redd...but after this one, I may well be retiring from actually doing this kind of work. I have a couple of foot long abdominal hernias from some major surgery about six years ago that just keep getting worse. Makes lugging hundred pound sacks of cement and sand pretty uncomfortable. Still love the work and strong enough, but my gut may literally bust at any moment if I keep pushing it too hard (which probably has something to do with why it has gotten worse).
Dan-Fox...What? You have never pitched washers!? Where have you guys been? We have a couple of tournaments each year and the winning team can take home a few hundred bucks. But we all have a good time. and yes...there is usually alcohol involved. The rules and specs vary a bit from here to there but you can get an idea about it here...
https://en.wikipedia.org/wiki/Washer_pitching
Back to work.
Old 06-10-2016, 02:08 PM   #1743
China?! You won't get them until Aug 2. How are we supposed to entertain ourselves without your pics? I'll bet you could use your phone camera----just saying---- Jack
Old 06-10-2016, 10:50 PM   #1744
What's a "phone camera"? My old flip phone just barely makes calls.
Old 06-10-2016, 11:44 PM   #1745
Well... --- I got a small taste of what the woodworking portion of this project is gonna' be like today. A RPITA! No straight lines, nothing is square, the walls are curved outward and getting a decent fit means going on & off two dozen times and trimming 1/32" here and there.
Had to go ahead and get the wood base on this one section as it will be an even greater bear later on. It will be behind the water tanks which I am anxious to get placed and welded down.
These sections of the rear steel panels will get a layer of 5mm underlayment, then some vinyl flooring material. Only the wood is cut to fit here. I will put a couple of coats of old fashioned shellac on both sides then screw and glue it. With any luck I will pick up the maple-look flooring manana.
ONWARD!
Old 06-11-2016, 04:13 AM   #1746
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Interior work!!!!! WoHOO!!!!!!!! or ..... Only time will tell now!
Congrats (I think......)
M1031A1 is offline   Reply With Quote
Old 06-11-2016, 09:18 AM   #1747
Hey Tango. I knew you were just holding out on us! I also buy shellac by the gallon to use as a waterproofer. I believe I used the same sub flooring material on my bus. Its a good thing you sealed both sides and the edges because the glue used to make the plywood isn't waterproof I discovered.
Anyway, lookin' good--you're on a roll now! Jack
Old 06-12-2016, 10:53 PM   #1748
Getting REALLY tired of the Biblical floods here! --- Managed to get the wood underlayment adhered to the wall yesterday but no pix, Looks just like the other shot but with a bunch of screws holding the panel in place till the glue fully sets.
Today I played with designing an area on the left rear that will be next to my Genny and house most of the associated electronics. Just a hump made out of metal but thanks (once again) to the ship like curves, promises to once again be a PITA to pull off properly. You folks with straight sided, flat, square buses have no idea just how easy you have it!
And, regarding floods...we had a forecast for "light scattered showers" today so I didn't worry. Until they started. By the time I got back to where my "other" car was parked the street was dry. Checked my security cams and lo & behold...there is my primary vehicle...in three feet of water for about an hour and a half! I am just about ready to go back to the three year drought we just came out of. But I really can't complain. A buddy at my neighborhood sheetmetal shop has had his house completely flooded (as in 6 feet of water) four times now in the past two months. Lost three cars and his son's monster truck. No idea yet how he fared today.
Hey Kalifornia...bring your water trucks here and feel free to fill up.
Old 06-14-2016, 09:30 PM   #1749
Hey Tango. You asked me about my RV roll out shade over on Nomadicista.org the other day, but I'll answer here. I pulled a 20' shade from a junked S&S and cut it down to the same length you want. Mine happens to be a Super Shade brand though the mfg is long out of business. I also wanted pole brackets that mounted to the side of the bus. This unit mounts to the side but quick releases to allow for ground support. That is sort of handy because the poles or arms can be a real head banger sometimes. I ordered new awning material from "Sunbrella" on ebay and had the retaining bead sewn into it---WAY better than the usual vinyl replacement and cheaper as well. Also, the long rollers have two coil springs in them. That gives you an extra spring should you need it as in the short awnings we need there isn't enough room for two springs. The single spring works perfectly. As it happens, my buddy who runs a tow/junk yard business where I help out during police tows, just hauled in a junk S&S with an awning like I started with ( Ya, I know, cop to junk yard dog. What can I say). All the hardware is intact and I'm sure I could acquire it for my labor. If you are interested let me know. Jack
Old 06-15-2016, 08:12 AM   #1750
Hey Jack --- Sounds pretty cool and very interesting. Does yours/this one have the roller cover that the shade tucks into when on the road? I am also assuming it is all mechanical. And I really like the Sunbrella idea. Seems like even the "better" RV shade materials are mostly caca at best.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
