Old 06-28-2016, 07:55 AM   #1771
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
lookin good!! its always those seemingly small things that end up being the toughest and also the most accomplished when you get them done... just because well.. making anything custom and then seeing it fit the way you want just plain rocks!!
Is it me or did Tango post the pics in stealth mode?
M1031A1 is offline   Reply With Quote
Old 06-28-2016, 08:00 AM   #1772
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Must be you, I see them.
Old 06-28-2016, 10:10 AM   #1773
You got that right Chris --- the "little stuff" on a custom build is what consumes 90% of your time. Stuff like installing the engine & tranny get done in a day or so...making all the crap around it can take years! Ask me how I know.
Old 06-28-2016, 03:17 PM   #1774
Hey Tango. I think you are going to like the cable way better than you would have liked "fly by wire" like I have. What with the rocking horse effect of our short wheel bases, I can't hold the accelerator in position without using cruse control.
When I first glanced at your pics, I thought "Hey Dude, did ya know you had a pink Hula Hoop stuck through your fire wall?" Ha, Ha. Jack
Old 06-28-2016, 08:08 PM   #1775
All skoolies require a pink Hoola-Hoop through the firewall. Everyone know that Jack. It's just is what it is.
Old 06-28-2016, 08:21 PM   #1776
Chassis: International S3800
plus with the cable you have a chnce of fixing it if something goes wrong... if the fly stops flying or the wire stops wiring its a lot harder to be able to go 'by'...
Old 06-29-2016, 10:37 AM   #1777
Tango, I see no issue with concrete pictures in your thread, it is your story...roll with it
I will hyjack, I am building this, using type "S" mortar and I need to paint the chimney area so water doesnt soak in, what kind of paint and prep work?
I still have to finish covering the dome, I was thinking what should I do for water proofing?
it is going to be blue and the base will be parged and painted ...looks over shoulder for wifey...Yellow w/blue tiles maybe
oops not a recent picture, I built the chimney last night
I don't want it to have a chance of freezing either and cracking apart
Thanks
I will also add this one, finally got her started and will bring her home weekend after 4th, maybe this Friday...she has a nice round smooth rearend hugh?
P.S>if you remind me I can delete this to clean up YOUR thread
Old 06-29-2016, 10:53 AM   #1778
Now don't be doing that Bansil--we all love a beautiful rear end like that one! Jack
Old 06-29-2016, 04:37 PM   #1779
Beautiful indeed!!! What a sweetheart. '38-ish?
As for painting the mortar and waterproofing, your best bet is to apply a good quality concrete sealer first over everything...then you can use just about any kind of paint. Unless the 'crete is thoroughly sealed, it will outgas moisture and the paint will flake off in no time.
My personal preference is for penetrating type sealers but they can be tricky to find.
But either way, when will the pizza be ready?
Old 06-29-2016, 04:57 PM   #1780
Attention any welders!!! Serious Safety Issue!!!
I just came across the info in the link below and think any of us hobby welders need to be aware of this potentially lethal combination. I have used "Brake Cleaner" to remove oils & such many times prior to welding but will find another option after reading this. Surprised the fool out of me. Please pass on as you see fit.
Safety Alert! Brake Cleaner = Phosgene Gas - BREW Bikes LLC
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
