Old 02-21-2017, 08:31 PM   #2091
browncrown's Avatar
Rated Cap: 79 at Birth
Nice work on the sofa bed frame...I envy your welding skills
BC
Old 02-22-2017, 10:03 AM   #2092
Thanks BC...It's amazing how much better you can make welds look with the right grinder.
After another dozen or so in & outs, I now have the gas pedal and steering pretty much worked out.
Wound up "revising" the way the linkage attaches to the pedal. You can't see it, but I spent way too long making a teeny, tiny little welded eye that connects the cable to the pedal. But at least it is now in and functioning.
On the backside of the box is where the return springs attach to the throttle arm on the engine. I like having two in case one fails.
And here it is with the steering linkage in place. Still working on a small bracket that will stabilize the column where the bearing is located then on to the really BIG task...the brakes that have to go in there somewhere.
Advice to anyone thinking about converting an antique school bus into an updated, highway capable RV...
START YOUNG!!!
ONWARD!
Old 02-22-2017, 11:49 AM   #2093
Amen to that Tango!
Old 02-22-2017, 03:31 PM   #2094
yeppers you are doin a skoolie conversion PLUS building a Street rod!!!!
ive done the hotrod thing.. though never built a complete modern streetrod out of a 40s car.. I have helped on a few such projects.. and they looked and felt very much like you are doing.. lots of custom fab and custom Re-Fab when you discover the first time around wouldnt work
Old 02-22-2017, 04:12 PM   #2095
Phatman's Avatar
START YOUNG!!!
ONWARD!
You left out the second part Tango.......... And have lots of money or be willing to take some constructive criticism !!
Old 02-23-2017, 03:03 AM   #2096
Just a couple of detail shots...
This was a nail-biter. It is the bracket I had to make and install that holds the steering shaft bearing in place. Everything had to line up just right.
And this tiny bit of metal was a bear as well. It is the new clevis attachment for the throttle cable. Fabbing & welding stuff this small is royal pain.
Now if I can just figure out where the heck to stuff all the brake parts I have laying around.
ONWARD!
Old 02-23-2017, 09:37 AM   #2097
Phatman's Avatar
Tango the Fab work looks like it's coming along pretty good. It's a good thing my friend that you are not a big guy....... boy would you be cramped.
Old 02-23-2017, 09:59 AM   #2098
Roger that. The roof is so low that I need not fear being invaded by giants...or...normal sized people.
Could well be The Hobbit Bus. Hmmm...wonder what kind of insulation growing grass on the roof would provide...
Old 02-23-2017, 11:44 AM   #2099
Phatman's Avatar
That's the idea Tango. Always thinking !!! Do you have room for a snare ?
Old 02-27-2017, 09:31 AM   #2100
Back to boat building --- At least that's what I call the woodwork necessary to accommodate all this old gals curves. Forget true & square, nothing is either on this puppy so you wind up cutting every piece to fit whatever compound angles she might have.
Putting wall panels into the passenger side rear quarter called for making a number of blocks to attach the new wood onto.
Here is a test fit of the wall panels. The center, lighter segment is formed with "bender board", a very flexible type of specialty plywood. Handy stuff.
After a great deal of careful fitting, cutting & routing, several coats of shellac were applied and some radiant barrier insulation applied to the backside of each panel.
The space between the inner & outer wall is minimal, but I decided to try and use it anyway by cutting an access opening. In a Shorty, you gotta try and use every cubic inch. A hatch cover for this will be forthcoming.
Here's what the back of that panel looks like. As with the others, it required more time than I would have liked, but fitting was a bear.
It will be a while before I actually do the final installation of the panels, but at least most of the done.
ONWARD!
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
