Old 05-20-2017, 08:14 PM   #2261
On mine...I have to "Tap" the T-Handle, but the idea is the same. I like being able to choose my gears when I want to.
Old 05-20-2017, 08:21 PM   #2262
what gears and tire size are you running? I know its in the 250 pages of thread somewhere..
gear selection seems important.. esp since im over-gearing.. I was concerned about engine torque with such low gearing.. but they tell me just going to a lockup vs free-wheel its gonna feel like someone also put a new engine in my bus too...
Old 05-20-2017, 09:08 PM   #2263
My (new) tires are 33.6" and the Dana rear axle is now 4.30 (changed from 5.13. That should yield about 63mph in 6th at 1800 rpm which is my little 4BT's sweet spot.
Old 05-20-2017, 09:21 PM   #2264
so im 31's with 3.54 gears.. my 444E peaks at 2300 RPM.. so im guessing that 1800-1900 will be its weet cruise spot.. thatll ne my 5th gear.. ill have to see if I use 6th.. that will likely push it to like 1650 or so.. since the orice was near the same id definitely kick myself if i didnt get 6 gears and wanted them.. so I figure if i dont need 6th i can just turn it off... then those days when I have a tail wind and want to cruise at 70 i can turn it on... or i may find i use it all the time..
Old 05-21-2017, 11:27 AM   #2265
I'm thinking pretty much the same way. There are a LOT of long, flat miles in this country where that extra gear will help keep fuel in the tank. And when you hit some steep angles, the selectable close ratio gears will give you what you need to handle them as well.
Old 05-21-2017, 08:50 PM   #2266
Stewzer55's Avatar
Coachwork: Fisher Body
Chassis: GM "B" Platform
Engine: 350 TBI Chevrolet
Rated Cap: 8
Those 3.54s will give it some pretty long legs with a .61 OD, looks like both the 1000 6 speed and the 2200 MH have identical gear spreads.
Closest I have to a Bus would be my '92 Oldsmobile Custom Cruiser Station Wagon 1 of 4,347 built.
Stewzer55 is offline   Reply With Quote
Old 05-21-2017, 08:54 PM   #2267
yeah thats why I have them build it so i can turn 6th off when I get in areas that id just lug the engine. one thing for sure itll be better than a free-wheeling 545.. lolol
Old 05-21-2017, 09:09 PM   #2268
Stewzer55's Avatar
Rated Cap: 8
Tango, at 1800 RPM with the 0.61 6th gear, you're looking at 68.6 MPH
Christopher, at 1800 RPM and a 0.61 6th gear 76.88 MPH, 5th 66.05 MPH
This is using Tremec's calculator Gear Ratio Calculator
Allison 1000 and 2200MH ratios: 1 (3.10), 2 (1.81), 3 (1.41), 4 (1.00), 5 (0.71), 6 (0.61)
Old 05-21-2017, 09:38 PM   #2269
definitely some long legs.. my bus is gonna sound like the Semi trucks on the freeway.. almost idling lolol..
the 444E engine has a wierd throttle map. which might actually play into my favor as it tends to put out a lot of its power in the last 25% of pedal.. so depending on I have them map it I can avoid Lugging by it issuing a downshift at say 80-85% throttle.. maybe not do a double downshift till 100%.. im sure there will be some tuning involved to get it right..
Old 05-21-2017, 09:53 PM   #2270
Stewzer55's Avatar
Rated Cap: 8
You may end up making your own tune to make them match, maybe take advantage of the lower amount to heat that will be generated to add a little horsepower.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
