Old 06-02-2017, 04:15 AM   #2341
Wow that thing is huge! Is it wider than the bus or just looks that way because the bus rear tapers down?
Old 06-02-2017, 10:06 AM   #2342
Her lovely rounded butt does make it appear wider, but it is actually about 2" inside the line of each outer wall. I would have made it a bit narrower, but I need every square inch back there to fit my genny and such.
Old 06-02-2017, 10:17 AM   #2343
Stewzer55's Avatar
Coachwork: Fisher Body
Chassis: GM "B" Platform
Engine: 350 TBI Chevrolet
Rated Cap: 8
If I may quote Hip Hop, "Shortie got a big ol' butt"
Closest I have to a Bus would be my '92 Oldsmobile Custom Cruiser Station Wagon 1 of 4,347 built.
Stewzer55 is offline   Reply With Quote
Old 06-02-2017, 11:03 PM   #2344
OK, OK...I know --- I said I was done for now on the deck but could not resist adding the hinge and one more frame element.
Used all of the C-clamps I had handy and needed more just to position this sucker. Note to self...take more to shop.
Sweated bullets hoping I had the position just right but here it is in the down position...and...
...in the up position. Then, after a few minutes of angst...
...I welded it in place. Drilled a dozen or so 1/2" holes then melted some iron in them. Also put beads along the edges. Should (hopefully) stay put. Working on a latch system next to keep it in place when on the road.
ONWARD!
Old 06-03-2017, 12:25 AM   #2345
GuidoLyons's Avatar
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
Disregard previous post...you got the hinge covered!
GuidoLyons is offline   Reply With Quote
Old 06-03-2017, 09:57 PM   #2346
More on the deck --- Or, maybe that should be "Moron, the deck!". Hard to stop once you get going on something. Especially after having had most of the parts sitting around for about a year or two.
Adding the fold up section now. Still have a few more chunks of iron to weld on but it is coming along. Decided at the last minute to cut down the size of the fold up to 22" instead of 24". Just seemed like more deck than I needed and will save a tiny amount of weight. And in case you are wondering, that back rail IS smaller than the others. 1-1/2" x 2" instead of 2" x 2". I also have a pair of adjustable stabilizers I made eons ago that will be added before I take it all back off and set it in a corner...or hang it from the rafters. Stuff this big (and heavy) can be a PITA to deal with but I need access to the body for a while longer.
ONWARD!
Old 06-03-2017, 10:24 PM   #2347
Looks good!!! Yeah atuffcthia big is a bit to deal with , as I'm dealing with my transmission project , a lot of weight real quick in metal stuff!!
Old 06-04-2017, 10:06 PM   #2348
Still on the deck --- Today I got the final pieces welded up from the top-side. Will wrap up the underside manana. Then, attach the adjustable stabilizers. Will have to fab some mounts for them.
Except for the welding on bottom, it is together. Here it is down...
...and here it is up.
And up from the driver side.
The angled corners came out pretty OK in spite of the size change of the iron.
Will wrap up the last bit of welding tomorrow then take it off and set it aside for a while. Engine work comes next.
ONWARD!
Old 06-04-2017, 10:41 PM   #2349
Robin97396's Avatar
Looking good.
That's a pretty nice looking bead on those inside corners.
Robin
Nobody's Business
Old 06-05-2017, 09:44 AM   #2350
Thanks Robin --- I've been getting a lot of welding practice in lately. More than I'd bargained for.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
