Old 08-07-2017, 10:16 AM   #2521
Howdy Guido --- Yes. I am absolutely investing in both heat and noise barrier materials. It is essential to living with the "paint shaker". I will be putting a variety of materials under the hood, on the firewall and around & over the engine. Already have a blanket for the turbo and multiple layers around the downpipe and exhaust.
The carpet on the roof above the doghouse is strictly to reduce reflected sound on the interior. Blue Bird and other makers have used perforated sheet metal in the same area which helps, but is even worse than carpet for collecting and redistributing dust. At least with short nap carpet, you can run a hand vac over it every once in a while.
Old 08-07-2017, 02:03 PM   #2522
one thing I have found out with redbyrd is that dynamat is nice for sound insulation but doesnt seem to do much for heat.. I dynamatted the panel that is used as access for the transmission and rear of the engine and it is a bit quieter inside but that thing still gets hot as heck...
sure looks good to see you got your TCM mounted!. where did you put it? i was told they are "generally" water resistant but not to put it somewhere where it would get in constant water spray. i put mine on the side of the battery box.
Old 08-07-2017, 11:41 PM   #2523
I've heard the same thing about Dynamat...pretty good for noise, not so good for heat.
And I am hoping the Allison guy is correct about the TCM being "waterproof". It is attached to the frame but away from any direct spray. I am also a bit concerned about the connector that is used for programming & reading. It has no cover which does sound like a problem waiting to happen after a very short while. Not sure what that lead is called, but I may start looking for something to close/protect the plug part.
You have me concerned about fording any streams now!
Old 08-08-2017, 07:54 AM   #2524
the programming connector should be run into the cab. its OK to cut the harness and extend it. i think theres only 4 wires. i did so with WeatherPAK connectors as they are waterproof. the idea behind that connector being in the cab is if you need any adjustments, someone can read a scan tool while the bus is being driven.
Old 08-08-2017, 10:40 AM   #2525
Thanks Christopher...good to know. As previously noted, I am a real dunce in this area.
And I may totally re-think where the TCM is located as well. Especially after watching the morning news here. Flash flooding all over the area. Nothing unusual for Houston, so maybe trying to get that doodad a little higher up might be wise. I have twice had the electronics in my 4Runner ruined by similar rain events. Do NOT want it happening to this rig. Would like to be able to cross streams without losing the tranny due to a water related electrical issue.
Back to the drawing board.
Old 08-08-2017, 11:43 AM   #2526
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Better now than after she's built and you're up a creek in need of a paddle....... Or some electronics....
M1031A1 is offline   Reply With Quote
Old 08-08-2017, 12:06 PM   #2527
Roger that M...saw a lot of local folks on the news this morning in need of paddles...and life jackets...and boats. I got lucky. My street can go from damp to four feet deep in a little over three minutes (I have timed it). The storm drains from half of Houston apparently all come together right here and when they are over whelmed (which is often), blow the manhole covers off at each end of the block and fill this street up from below. They look like Old Faithful.
Old 08-08-2017, 12:17 PM   #2528
seems to be storm drain management must always be left off of city planners' plans.. theres an area in columbus.. its flooded many times over the years.. they recently re-did the whole thing.. tore down the old buildings.. put in new stores, shops, restaraunts, etc.. even tore up the street and ran new everything.. it seemed..
however a big rain this summer flooded it just like it always has....
P.S. if you shou;ld happen to drench the electronics your transmission wont just go into Neutral.. it will run without the TCM in limp mode which I think is second gear... and you'll have reverse.
Old 08-08-2017, 02:45 PM   #2529
Thanks again Christopher...sounds like I really should move it up above the waterline.
Old 08-09-2017, 12:21 AM   #2530
Began the process of re-locating both the TCM & TPS today. Thanks again to Cadillac for reminding me about how water crossings and electronics play together.
Working out a location near the top of the cowl. At about four + feet off the ground, if I get into water that deep, the tranny will likely be the least of my worries. Hmmm...maybe a snorkel is in order here.
Will update with pix after I figger it all out.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
