Old 08-15-2017, 11:11 AM   #2551
Roger that Phatman --- Wednesday is "Hump Night Honkey Tonk" at REHAB Bar on the Bayou. Great, free live music. I will be there. But then, I'm just about always there...7 days a week.
Old 08-18-2017, 12:14 AM   #2552
Well Dang! --- Spent the better part of the day digging through "spare parts" at my friendly diesel shop trying to find something to make an air filter out of but struck out.
I want to build a Kenworth style air filter housing that attaches to the side of the cowl the way the Big Boys do. Just a whole lot smaller. Brought one home off a Kubota that looked close but I don't think it will work. The airflow would have to be reversed. The tech said he saw no reason that wouldn't work but...???
I also learned from the same tech that I need an adapter for the hot outlet on my turbo in order to connect the shiny new charge air cooler pipe. After a fair amount of digging I'm beginning to think what I want may be a unicorn. Will make a trip to the local Cummins shop tomorrow and see what they have to say.
Wish me luck.
ONWARD!
Old 08-18-2017, 09:52 AM   #2553
Good luck with the project as the Big Boy air filter off thr cowl just sounds perfect for this. I keep thinking mini-mini kegg but wouldn't know where to find one.
Oldcarnut is offline   Reply With Quote
Old 08-18-2017, 09:58 AM   #2554
Ya...I definitely think it would look good plus be easy to service and away from the engine heat. Gave some thought to building a canister from scratch, but they need to seal up absolutely air tight to do their job so the hunt continues.
Old 08-18-2017, 10:43 AM   #2555
I think part of the issue with sucking the air over the inside of a canister air filter toward the outside is that of surface area.. on the outside you have much more surface area.. so as the filter gets dirty, the dirt is dispersed over a larger area vs if you try and bring their over the inside of the filter first...
I like the idea of the external intake from a cold air perspective.. on the right truck it definitely looks good too
Old 08-18-2017, 11:02 AM   #2556
That was exactly my thought Christopher. The only saving grace might be that if I went that route, the filter itself would be substantially larger than the typical 4BT filter to begin with. Hoping the Cummins folks might be able to provide some insight but I may also contact someone like Donaldson to see what they think. Of course they will have product liability concerns but maybe I can get some straight talk from someone in engineering...if I can get through.
Old 08-18-2017, 11:28 AM   #2557
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I ran a Donaldson on my 360 cid wrangler with snorkel. Loved that thing. Love your build !!!
Old 08-18-2017, 11:40 AM   #2558
Thanks leadsled --- I plan on either Donaldson or Fleetguard for the actual filter. Used to run K&N's on my motocross bikes but frankly, they suck dog eggs on a diesel. They advertise "more air flow" which is true. But only because they don't really "filter" much of anything. OK if you are running only on a track and gonna rebuild the motor every other race, not good if you are trying to protect your engine and make it last.
And my formula GP bikes?...
Filters? We don't need no stinkin filters!
Old 08-18-2017, 01:09 PM   #2559
ANYTHING with a Turbo needs a good filter... its not so much the diesel engine that cares.. but Dust a turbo and then come back and say no filter needed is what I tell anyone who wonders why I check and change my air fillters often..
Old 08-18-2017, 01:12 PM   #2560
wonder if there is some nice tractor intakes that would be compact and still look good.. or at least something that you could take to the chrome shop and have chromed if needbe.. what are you using a 3 inch or 4 inch intake pipe t othe turbo?
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
