Old 11-16-2017, 10:33 PM   #2791
JR --- we are using bronze bushings that should outlast the bus (and me). You are absolutely correct in that having brake linkage lock up/rust in place is not a good thing. Also the gloves and sleeves. I have a bad habit of jumping in and have ruined/set fire to some otherwise nice clothes cause I didn't stop to change. But it ususlly only bothers me when it's one of my vintage Hawaiian shirts.
Old 11-18-2017, 10:09 AM   #2792
Back in the Doghouse --- Been working on trying to fit a doghouse over the back end of my engine and it has been a RPITA. Nothing about it is remotely square and getting really tight measurements has been difficult. Got three pieces cut today and will be back on it tomorrow as time allows. An 8th of an inch here and a 16th of an inch there make a big difference I have discovered.
Old 11-18-2017, 02:03 PM   #2793
make sure to leave thickness for INSULATION for your dog house.. my Red bus has no doghouse because its a V8 and the engine is set forward. . my DT360 is set up where the turbo is right near the doghouse.. its factory insulated but not nearly what aftermarket should be. so i get LOTS of heat off of it on hot summer days.. so be sure to insulated it well .. both for sound and heat..
Old 11-18-2017, 02:40 PM   #2794
Absolutely. My turbo and downpipe are just a few inches off the doghouse so serious insulation is in the plans. I tried to head off as much as possible by ceramic coating the downpipe and adding heat shielding to both the turbo and the pipe.
Stainless downpipe is ceramic coated inside & out.
Then wrapped in the "Lava" heat wrap (NOTE: Wrapping pipes that are NOT stainless steel will greatly accelerate rusting!)
Over that are two radiant heat shields after which I blanketed the turbo.
The final barrier will be inside the doghouse. Still shopping materials for that and I am open to any recommendations.
Old 11-18-2017, 03:09 PM   #2795
[QUOTE=Tango;234400]Absolutely. My turbo and downpipe are just a few inches off the doghouse so serious insulation is in the plans. I tried to head off as much as possible by ceramic coating the downpipe and adding heat shielding to both the turbo and the pipe.
"The final barrier will be inside the doghouse. Still shopping materials for that and I am open to any recommendations."
Tango I have an old Safari van with a doghouse. Not sure what it is made of though, it's light, fairly thick, maybe 1/4" and works well. I was driving it for a day or two without the doghouse on and the heat was unbearable in July. What a difference that material makes so maybe you could fab something from something like that. I wish I knew what it was made of but looks like aluminum colour. Should be lots of them in boneyards around.
Good luck,
Old 11-18-2017, 04:02 PM   #2796
Thanks John, I will have to check that out. Some of the aftermarket stuff I have been looking at has a fibrous heat layer between a couple of sheets of metallic reflective material that sounds similar.
What year Safari?
Old 11-18-2017, 05:30 PM   #2797
What year Safari? 1997 Pure metal, no composite materials. I'm sure you will know what will work anyway best for you Tango. Sounds like the least of your obstacles though.
I hope to take a ride someday in that beast with you so get it right, lmao!
Old 11-18-2017, 05:31 PM   #2798
plfking's Avatar
Rated Cap: 34
I used to be a manufacturing engineer for a major player in the furniture industry, and one of my responsibilities was developing processes to reduce the flammability of our products. You can buy fire-resistant fiber that stands up to open flame for as long as you can hold a lighter to it. The fiber also has noise-reducing properties.
Every time I see someone discussing doghouse insulation I think of the following.....could you put down a couple layers of FR fiber (which is approx. 1/2" - 3/4" thick) over the motor, and against the inside of your doghouse, and then fill that void with closed-cell spray foam? How flammable is spray foam? In my scenario the FR fiber is only there to protect the spray foam, if spray foam is even usable.
The doghouse could even be built a little oversized to allow for more foam, to increase the noise-reducing potential. Then a 1/2" rubber gasket sandwiched between the bottom edge of the doghouse and the bus floor.
Just a thought.
Don
Don
The Busted Flush
Old 11-18-2017, 06:03 PM   #2799
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
In the past I have fabled up shapes using 2" foam board covered with fiberglass. Just reinforce mounting locations. It can be any shape and can have any coatings.
JMO
watching, reading, learning
Tootalltechie is offline   Reply With Quote
Old 11-19-2017, 12:04 PM   #2800
Along similar lines, I had wondered about using a layer of something like Reflectix covered (on the heat side) with some hi temp, aluminum faced fiber type barrier. You can get that stuff rated to over 1000 degrees.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
