Old 01-18-2018, 01:36 PM   #2991
Robin97396's Avatar
I guess you were born on a cold winter's night!
Happy birthday. I'll buy a virtual round for the house.
Robin
Nobody's Business
Old 01-18-2018, 01:58 PM   #2992
Thanks Robin. You got me curious as I was quite young and don't really recall what it was like that day. So I looked it up. Much nicer then than now.
On February 2nd, 1945, the closest available weather station to Houston, TX (HOUSTON ELLINGTON AFB, TX), reported the following conditions:
High Temp:56.3F *
Low Temp: 51.3F *
Average Temp:55F( 24 )Dewpoint:53F( 24 )Sea Level Pressure:1023.8 mb( 24 )Station Pressure:n/a
Visibility:3.8 miles( 24 )Wind Speed:9.9 knots( 24 )Max Wind Speed:13 knots
Max Wind Gust:n/a
Precipitation Amount:n/a
Snow Depth:n/a
Old 01-18-2018, 02:44 PM   #2993
Robin97396's Avatar
I stand corrected. Apparently it was a balmy evening. The stars were twinkling and screams of child labor were in the air. Good times.
I was comparing that date with our current weather situation which was the wrong weather assumption. By the way I am usually frosty and snowy this time of year, but am enjoying mid to high 50s during the day and low 40s at night. I accidentally slept with the hatch open last night.
Robin
Nobody's Business
Old 01-18-2018, 02:46 PM   #2994
Mmmmm...balmy! Sounds like great sleeping weather.
Old 01-18-2018, 06:23 PM   #2995
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Happy B-day Tango! Hard to believe this thread is as long as it is! But, hey, look at the bright side, if you forget how something goes together, you can always re-read it......
M
Firearms stand next in importance to the Constitution itself. They are the American peoples liberty teeth and keystone under independence. George Washington
M1031A1 is offline   Reply With Quote
Old 01-18-2018, 08:43 PM   #2996
Thanks M...I have been doing just that for years now!
Old 01-19-2018, 12:38 PM   #2997
GuidoLyons's Avatar
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
Originally Posted by Tango View Post
Holy Moly! --- I just noticed that the views here had rolled over to 300,000+ !
And it is certainly nothing to be proud of. It is just a testament to how long I have been screwing around with this project. I would have been thrilled to have wrapped it up with 300 views.
I've said it before and I'll say it again...if you intend to rebuild/convert a 70 year old bus...START YOUNG! I turn 73 in two weeks so I really need to wrap this thing up before Oldtimers Disease sets in and I can't remember where anything goes or why I started this project in the first place.
ONWARD?
Hang in there Tango! You'll be cruising in style soon. You got all the big bits done, just need all those fiddly bits to fill in.
Just like eating an elephant, one bite at a time.
GuidoLyons is offline   Reply With Quote
Old 01-19-2018, 02:02 PM   #2998
Thanks Guido! --- Sometimes seems like this elephant just keeps getting bigger.
How is your instructor cert coming along? You still coming and going from the Houston area? With that commute...you really should be flying back & forth bud! Remember... me & REHAB are also in the area and I will always be happy to provide some adult refreshments.
Just sent part of my brake booster off to Kaliphornia for some fixes so it will work with the new all mechanical system we built. It is all installed now and I just need the master/booster to have the right fitting on the input shaft.
The outfit that built the hydraulic version is going to replace the input shaft end with a threaded version like you see above. Will take a couple of weeks with all the shipping back and forth so I am moving on to some other "fiddly bits".
Will go ahead and start on the hydraulic lines and brake lines next.
ONWARD!
Old 01-26-2018, 08:46 PM   #2999
Still on hold for numerous items that are out to be built but I did get started on the brake lines today. Spent nearly all of it chasing parts. Gotta drill and tap numerous holes for the line mounts. Drilling, grinding and welding upside down are among my least favorite pastimes. At least I have someone to call on who is an old timer at bending & flaring.
The past week or so was spent on equally exotic and un-photogenic little chores so not much to show. Hopefully that will change soon...along with the weather. I am SO ready for Spring!
Old 01-30-2018, 02:19 PM   #3000
I once had a 73 Dodge Tradesman 300. Interior of that van was just a smidge smaller than a handball court. At any rate, an unfortunate series of events resulted in my having to replace a couple of brake lines. While I was about it I found that some of them were rotting; evidently they had separated from the undercoat, resulting in the undercoat holding moisture against them.
My point is that if I could figure out how to bend and flare tubing as a 27 year old idjit, you can do it too. Not rocket science.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
