Old 01-31-2018, 07:27 AM   #3011
Originally Posted by Tango View Post
Agreed. keeping the trans happy means keeping it comfy. Not too hot, not too cold. I like your idea of a bypass that is thermostatically controlled. Not sure I know how to pull that off just yet...but...I like the idea.
there are cooler line bypasses valve made out there.. I was simply thinking if you are using a remote mounted trans cooler that it wont get much wind and will require a fan.. which its super easy to have a fan thats thermostatically controlled, so the cooler wouldnt do much cooling in cold weather while its fan is off.. that wouldnt involve any wierd piping..
the cooler line fittings on the allison SAE bell are #12 O-ring Boss. (not #10 like the internet world seems to say).. #10 Hose is the norm and quite OK.. but the fittings going into the trans are #12.. took me a couple tries to get that one right..
the one time a local grainger was my friend..
Old 01-31-2018, 11:03 AM   #3012
Guido --- Thanks. Just hoping the final product works.
Cadillac --- The Derale cooler I am looking at (below) does have a high volume fan which should be easy to control thermostatically. Still uncertain about the fittings going in & out of the trans. I believe the 5th gen have 7/8" ports but I'm trying to confirm. Since the trans is full of expensive Transynd fluid, I am hoping to get confirmation without pulling the plastic plugs before I'm ready to hook it up.
https://derale.com/products/fluid-coolers/engine/remote-mount/gm-700r4-4l60-4l60e-transmission-cooling-pan-detail
Old 01-31-2018, 08:03 PM   #3013
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
And if Bondo doesn't do the job...there's always JB Weld!
What about duct tape. Lol
Tootalltechie is offline   Reply With Quote
Old 01-31-2018, 08:16 PM   #3014
wow the trans is already filled? definitely catch that fluid if it comes out!!
yeah mine was 1 1/6 (#12) ORB. that I came out and went to a 7/8" JIC fitting (hydraulic) for the cooler lines.. and I was told thait acceptable for the allison 1000/2000. its larger than what the GMC or SAE2 bell is (im told)... that cooler has 7/8 ORB fittings on it so that mate up well with your lines even if you need to adapt down from #12. im thinking going all the way down to #6 hose (the barb they have on the cooler) seems a bit small...
this is the fitting I used..
https://www.grainger.com/product/4VTH6
nice derale cooler.. im a big fan of derale products.. seems like their stuff it top notch and works well.. for electric fans I do tend to go with SPAL as I get more performance for the size..
Old 01-31-2018, 08:16 PM   #3015
Gotta love Duct Tape. Hey...it got the Appollo 13 guys back to Earth alive!
Old 01-31-2018, 09:11 PM   #3016
did you know standard duct tape is good for everything EXCEPT ducts?
Old 01-31-2018, 09:12 PM   #3017
And "DUCK" tape is really bad on ducks.
Old 01-31-2018, 09:18 PM   #3018
I never had a need to tape a duck.. must be lots of people who do since I see 'Duck' tape quite a bit
Old 01-31-2018, 09:21 PM   #3019
Chassis: Saf-T-Liner MVP ER
Yeah, because "Duck" is a brand
In the UK we call vacuum cleaners, "Hoovers", for the same reason.
People here look at me funny when I say it!
Steve Bracken
Build Thread
Old 01-31-2018, 09:28 PM   #3020
just like Kleenex.. we always called it. that and its actually a brand
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
