Old 02-12-2018, 06:32 PM   #3071
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Just saying he needs to check with whoever is providing his warranty to make sure they know that Allison has still not approved it?
That way when he is on the road and hopefully not but does have tranny problems then if the TC was the issue then Allison can eat wrecker bill and all?
Just trying to help with some CYA.
I believe his tranny is already installed.
SO to pull it out to change a converter that Allison sent with it to an upgrade because ALLISON still don't know would be costing Allison some money and time.
I wouldn't push them to approve it but I would want the ones that sourced all of it for me and the ones warranting it for me to know that Allison still has not approved it application even after they sold it to me 6-years ago as of this year.
Old 02-12-2018, 11:43 PM   #3072
Wow...I had no idea. Totally missed the meaning there. Need to get back with Stewart & Stevenson (who I ordered it through) for clarification.
Many thanks!
Old 02-18-2018, 01:55 PM   #3073
sojourner's Avatar
Engine: DT408
Fabulous fab work!! I'm thinkin' if you and I were in the same shop, things would get very dangerous!!
I'm thinking of using hammertone paint on the outside of my build. Charcoal grey from the floor down with black storage bay doors. Silver between the floor and bottom of the windows and white from there on up. How does hammerite compare to the rustoleum product? I too see 140% humidity here in SC. The two week cure time might just force me to take a break.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 02-18-2018, 02:31 PM   #3074
lol...I can manage to be dangerous all by myself! But thanks for the kind words.
I've had very good results with Hammerite. Pretty tough stuff once it is fully cured. And the attractive texture can hide a world of small issues. That was one reason I chose it for my dash/firewall (Which led to the steps). No amount of sanding was ever going to result in a smooth surface so why fight it? The original product came out of England, but the last few rattle cans I bought are marked as a Rustoleum product. (Maybe they just bought them?) But I have also seen a separate Rustoleum product simply called "Hammered" so I have to assume they are different. I know the original requires no primer and can go straight over rust or bare metal. No idea about the other one.
Meanwhile...
I just got my hydroboost unit back from CA. Had the guy I bought it from convert the input shaft to work with my new, all mechanical system. Also now have my adjustable proportioning valve so I hope to get some more brake work done this coming week.
Old 02-18-2018, 02:41 PM   #3075
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Spray hammertone paint is great for all the above mentioned reasons. Real good to cover up your sins. The only downside is outdoor durability. But it touches up real easy.
Old 02-18-2018, 02:56 PM   #3076
sojourner's Avatar
Engine: DT408
Meanwhile...
The hiding a multitude of sins is precisely why I'm using it. There's just no way the exterior of a skoolie's gonna pull off a a really high quality finish. That's the main reason I'm doing more of a "utility" look on the outside and would prefer something relatively uniform and durable. The interior will be another story altogether.
I don't want to rattle can it though. Would rather buy gallons and paint with HVLP if possible.
Proportioning valve? Last time I heard that word was with a guy racing circle track.
I wonder how one might improve the durability?
Old 02-18-2018, 03:08 PM   #3077
plfking's Avatar
Rated Cap: 34
According to my old paint vendor, the Rustoleum "Hammered" is the normal Rustoleum formulation with an additive to separate the paint pigments and give it the 'hammered' look.
The Hammerite is a different formulation altogether.....it actually has a catalyst in it to produce a harder finish. It's a cheaper option than powercoating, but gives a similar result in hardness and chip-resistance (note I said 'similar', not 'better').
Don
The Busted Flush
Old 02-18-2018, 03:16 PM   #3078
Chassis: Saf-T-Liner MVP ER
Hammerite has been the go-to paint finish for this kind of use in the UK, for decades.
It can be painted directly onto rust once the loose stuff has been removed.
Steve Bracken
Build Thread
Old 02-18-2018, 07:03 PM   #3079
The above exactly resembles my take on the two paint options. The Rustoleum "Hammered" is basically, regular rattlecan paint that accomplishes a similar finish/look...the "real Hammerite" is a much tougher, rust preventing/converting paint. But...as I said...the last cans of "Hammerite" I bought had the Rustoleum logo & branding (?).
Old 02-19-2018, 02:26 PM   #3080
GuidoLyons's Avatar
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
after a quick Google, it looks like the UK Hammerite is different than the US Hammerite. UK Hammerite website doesn't list US as a Hammerite market: https://www.hammerite.com/
Hammerite rust cap paint in the US (sold at Ace Hardware, etc) is owned by MasterChem (not Rustoleum) Masterchem Industries
Masterchem Industries LLC is a national leader in the manufacture of architectural coatings, including primers, professional and one-coat paints, spray paints, rust-preventive coatings and more. The company markets primers and specialty paints under the KILZ® brand, professional paints under the KILZ Pro-X™ brand, one-coat paints under the KILZ® Casual Colors® brand and rust-preventive coatings under the Hammerite® Rust Cap® name. These products are sold on a nationwide basis to thousands of outlets, including big box stores, national retailers, paint and hardware stores and distributors.
The Rustoleum Hammered finish is similar. I've had good results with the Rustoleum Hammered finish. Covers a multitude of sins, looks good, works well, and makes for easy touch up if it does get scratched.
Tractor Supply Co used to carry a Valspar (or Rustoleum?) hardener with the tractor paint. Might be worth a look.
GuidoLyons is offline   Reply With Quote
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
