Old 12-04-2018, 11:32 PM   #3731
GuidoLyons's Avatar
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
Hoops on the roof rack look good Tango.
GuidoLyons is offline   Reply With Quote
Old 12-05-2018, 07:03 AM   #3732
lovin that roof rack!! the curves are perfect!! gonna look great!!! are the rafters in your building strong where you can rig up a pulley system?
Old 12-05-2018, 09:59 AM   #3733
Thanks All...
Bas...Would love to hear your take on that little heater. Good luck with it.
Guido...turned out to be a piece of cake to install. I had tacked some square tube inside the rectangular tube to use for positioning but still expected I would have to do a fair amount of torqing on each end the big piece for it to fall in place. Not at all. I stood in the middle of the cowl and it slid right on like it was made to do it!
Caddie...not worried about the rafters as the whole rack only weighs a little over 100 pounds (metal only). In fact, I will probably try and move it without going to the roof. If I can get a guy on each corner with a short pole attached to it, I am pretty sure we can lift and maneuver it pretty easily.
Well...I am HOPING we can anyway.
Old 12-05-2018, 01:38 PM   #3734
2kool4skool's Avatar
Originally Posted by brijn View Post
Just discovered your build thread. Fantastic work!
I have one of these heaters on order. There is a VERY active Facebook group "Chinese Diesel Vehicle air heaters".
Most people have no issues with the heaters. A small percentage of people seem to have issues with massive build up of soot in the burn chamber (or whatever that is called). Good news is, the passwords to make setting changes are known, so fuel feed rates can be tweaked if needed.
After spending a good amount of time reading about them, I was pretty comfortable ordering one.
If I get it installed and working I'll post some experiences
Bas
My 2 pennies.
We have a Planar 44d, might be similar if not the same as the China ones. 4lkw, about 14,000 btu. Very thrifty on fuel but these too may soot up if run long time at low heat. I recently cleaned ours, it was belching white, nasty smelling smoke.
Cleaning is not hard and I've found that partial disassembly is enough with no parts/gaskets needed if done with reasonable care. I use some kerosene and blow it dry after.
It is good to run it wide open for 1/2 hour before shutting it down to minimize the build up.
We run ours all night often at low (18c) setting to keep the chill off and crank it up in the morning as long as we can stand it. Even then it cokes up occasionally (twice in 4 years).I'm going to start cleaning it every summer from now on.
Now I'm off to FB to read some heater posts.
Don, Mary and Spooky the cat.
Old 12-05-2018, 05:47 PM   #3735
Good info 2kool...thank you. Doesn't sound too bad actually. Everything requires some kind of maintenance...right?
Old 12-07-2018, 10:08 AM   #3736
Coachwork: sturdivan
Chassis: E-350
Engine: 7.3l IDI
Rated Cap: 10,000lbs
so what are the passwords, there is more than one?
Is there any other technical data on these things. They sound like they might be good for the short bus.
Al
telegram: https://t.me/mr_alpine
alpinekid is offline   Reply With Quote
Old 12-07-2018, 11:07 AM   #3737
Year: 2005
Coachwork: International CE200
Engine: VT365
Rated Cap: 26
Tango, to not sidetrack this fantastic build thread I thought it would be wise to split this off in a separate thread:
http://www.skoolie.net/forums/f51/th...ead-25109.html
Bas
brijn is offline   Reply With Quote
Old 12-07-2018, 09:59 PM   #3738
Not much to report. Mostly just bored.
We are under (yet another) flash flood advisory (Welcome to Houston!). And anytime a cloud goes over, my satellite TV goes away. Lotta good it does if you are trying to keep up with storms!
Had a really nasty cold the past few days but did manage to get a few more pieces of the roof rack in place. Very close to taking it down. Hopefully next week.
Like I said...just bored! I need to be working!
Old 12-18-2018, 03:23 PM   #3739
Just a couple of more ladder pix --- Been slowed down by some health issues that have had me spending way too much of my "bus time" out at the local VA hospital the past couple of months. Apparently, I did such a swell job of beating stage four cancer seven years ago...they want to see if I can do it again.
Sucks. I have better things to do with my time.
At least this time they are installing a "port" for the chemo. Good thing 'cause all my veins are still trashed from the last go round. Will be getting the new parts put in tomorrow morning. Yippee. Not exactly what I was hoping for for Christmas.
Meanwhile...
Got the steps back from the sheetmetal shop and put them on today.
Just 10 gauge steel diamond plate with a 3/4" fold around the edges. Plenty stout.
I can now begin taking the ladder & deck down to complete welding the undersides and throw some paint on.
ONWARD!
Old 12-18-2018, 03:59 PM   #3740
Really sorry to hear of your medical setback Tango.
That sucks anytime of the year, not just Xmas.
Be a good patient and hope you are home for Xmas.
Take some time to appreciate your outstanding accomplishments bro!
You have brought that baby a long way back!Incredible undertaking man!
The work will still be waiting but take care of yourself first.
The ladder looks really good with the steps.
Prayers and blessings to you for a speedy recovery and do have a Merry Xmas.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
