Old 04-01-2013, 11:06 PM   #491
Re: '46 Chevy Shorty
Gotta' love that "sizzle"! And the best thing about the new Millers is that they make even me look like I know how to weld!
Not!
Old 04-05-2013, 01:04 AM   #492
Hi Guys 'n Gals --- took delivery on a 195" frame today. Bought it for a hundred bucks. I figure the wheels are worth more than that. Especially if they have to be shipped. Had fantasized that it might have the elusive 5.43 gearing but no such luck. Ah well, if I'm stuck with a 6.17 at least now I have a spare rear end. Was planning on yanking both axles but I'm now convinced this rig is not the 1.5T I was told it was, but rather a 2T. The front axle and steering are different than what is on mine. Will still pull the axle, steering & such. Hey, ya never know with these old rigs. Something just might fit. Meanwhile, there is some info below that may help any other Skoolies with questions about their early Chevy rear ends.
Frame is in great shape overall. Had just been sandblasted but two days of sitting in the rain brought out the oxides.
A little oil & wire brushing helped me locate the rear axle ID number. Never could find it on mine until I saw it on this one. It is located at the top of the center section between the two top ribs.
and if you pull the inspection plate...
...the gear count & ratio are stamped onto the flat, inner surface of the ring gear.
Unfortunately for me, this one is definitely the 6/37 count which works out to be the 6.17 ratio.
Dang.
If anyone is in the market for a bare '42-46 long wheelbase (195") Chevy truck frame just gimme a call and come & get it for free. I'm hoping it finds a home before I have to chop it up for a scarp yard.
Onward!
Old 04-05-2013, 10:49 AM   #493
Hey Tango, I had you rollin' down the road with your 5:43. Sorry the new frame didn't have the right part. Maybe you can sell it and pocket a little profit--hope so.
I'm still trying to figure out a way to get the '35 sheet metal to cover the new frame. Sure wish the new frame rails were narrower. Oh well.
Old 04-05-2013, 06:57 PM   #494
I know the feeling Jack --- My engine fit will likely go the other way...but you can only cut out so much frame!
Confirmed today that the spare frame is indeed a 2T but I just may swap the whole front axle assembly into mine anyway. It is only 1/2" wider ( 1/4" each side) but there is a chap over on the Stovebolt that is working up a killer front disk kit for 2 tons that would make life a lot sweeter...and safer. We'll see.
Need to start searching for a power steering set up that I can transplant too.
Oh the joys of rehabbing.
Old 04-16-2013, 10:48 AM   #495
Well Howdy Guys & Gals --- finally getting a little bit of work done on the bus. Spent a week fighting a front rim that was rust-welded onto the drum and now have to do battle with the duallies. I now have a greater appreciation for why no one makes "Hub Centered" wheels anymore. Sheesh!
Also wrapped up all the trimming, fitting and sealing on the passenger side rear wheel well. They have to be at a certain point before I can begin to think about skinning and since this unit is so short, I also had to accommodate my sofa/bunk. It will fit partially over the aforementioned well. I'm now working on the driver side well which is yet another sequencing act. The combo shower/toilet has to fit (very snugly) over it.
And, I even got a little more done on the back porch. The mounting brackets were a little tricky and the frame a b*tch to drill, but at least I can de-mount the whole thing if need be.
As for the engine & tranny, I first have to build an A-Frame to hoist and position that package. I just don't have that much faith in my Chinese hydraulic hoist for some reason.
Here's a few pix...
Passenger wheel well with steel mounts for sofa bed and a storage cabinet (yet to come). This side is now ready to skin but I'm waiting till some other body work is done first.
I'm using commercial automotive "Seam Sealer" on just about everything that opens to the great outdoors. Good stuff but takes forever to cure.
Here are my frame extensions (and spreaders) that will support the deck on back. They are now wide enough to accommodate my giant spare tire underneath the porch. I'm also installing a cable hoist to raise and lower that big, heavy sucker.
Since it will be hanging out back by three feet, I want it to be readily removable (just in case), so the whole thing will be bolted on rather than welded (which would be much, much easier BTW).
Onward!
Old 04-16-2013, 02:56 PM   #496
Hey Tango, as always, very handsome work. When I first saw that gear shift linkage with the boot back by the reat tire I thought "Wow, and I thought my shift was remote being to the left of the driver" I guess that is a tank filler?--hard to see things clearly here on my Comador 64 computer.
Old 04-16-2013, 03:40 PM   #497
Ha! --- Easy to see how it looks like a shifter but yep, it is the fuel fill. Since it's a diesel (or will be someday), it needs a big vent . And the shift boot worked out to be a great seal. I borrowed a couple of quality punches from a friend and cut the openings to a nice snug fit. Shame that the chrome will be hidden under the sofa/bed.
Old 04-16-2013, 05:56 PM   #498
And...
Should you ever encounter an old Chevy hub piloted rim that just won't give up and come off...this is what finally worked for me...
Weld a half-inch nut over an open lug hole in the rim (on the front they only use 5 of the 10 holes)...
Run a half-inch bolt in against the flange and...Voila'...it pushes it off. (It took me a week to get to this solution)
When off, just cut & grind the nut flush and you are back in biz.
Old 04-16-2013, 09:06 PM   #499
I just love nasty down and dirty solutions like that --now I just have to remember it
Old 04-17-2013, 09:47 AM   #500
Roger that Jack, me too --- Now if I can just come up with an "NDADS" that will work on the rear duallies I'll be a happy camper. They use all ten lugs so this trick won't work back there and with the outer rim reversed you can't really hook anything into the hand holes. Trying to rig some kind of chain wrap through them combined with a bottle jack but first need to make a protective cover for the axle cap.
“It just goes to show you, Jane . . . its always something. If it isn't one thing its another.”
Roseanne Rosanadanna
Onward!
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
