Closed Thread
Old 07-03-2015, 09:20 PM   #1061
Good price but those bad boys are serious overkill for my little porch. Picked up the pipe & all-thread today. Should have pix before too long.
Tango is offline
Old 07-03-2015, 09:45 PM   #1062
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by Tango View Post
When I said it was a "Shorty"...I meant it!
And I think I have a plan for the stabilizers. It is pretty simple...some all-thread, a length of pipe and a couple of nuts. That way, each leg can adapt to whatever surface I wind up on. Think Lunar craters. I'll try to get a drawing worked out. It looks doable in my head...but that's the scary part.
I cannot begin to tell you about the scary things that go on in my head.
Stu & Filo. T is offline
Old 07-03-2015, 11:23 PM   #1063
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Originally Posted by milkmania View Post
I thought he was just wanting to stabilize it, not lift it.
stopped at Atwoods farm supply earlier today....
the jack in first 2 pics, is the same jack.... set at different intervals, with pins.
$66.99 each
Those aren't jacks, this is a jack. LOL.
I have a hydraulic leveling setup off of an old MRI trailer. I just need to pull it off when I get some time.
I'm hungry!
You Gotta Let Me Fly
crazycal is offline
Old 07-03-2015, 11:34 PM   #1064
miltruckman's Avatar
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
I just got my rear stabilizer jacks bolted on tonight.i used the Bulldog 12500 lb model and bolted them just behind the rear axle. Between the mud flap and tire.
Bill
MI
miltruckman is offline
Old 07-03-2015, 11:36 PM   #1065
Engine: 5.9 cummins
Here it is before the tire is on.
Bill
MI
Old 07-03-2015, 11:40 PM   #1066
buddy's trailer was set up with this style jack..... seemed to work well
milkmania is offline
Old 07-03-2015, 11:41 PM   #1067
Moderator
crazycal's Avatar
Bill
MI
Now that's a jack!
I'm hungry!
crazycal is offline
Old 07-03-2015, 11:48 PM   #1068
Moderator
crazycal's Avatar
That is the same location as on my trailer. It's OK for equipment but a crappy spot for a jack if you load a car on the trailer. I will be cutting it off and moving it closer to the front.
I'm hungry!
crazycal is offline
Old 07-04-2015, 09:20 AM   #1069
Them thar is nice jacks fer little fellers, but I ended up using these intermediate size ones--------. Jack
Thirty five tons each seemed to get the job done.
ol trunt is offline
Old 07-04-2015, 11:26 AM   #1070
Moderator
crazycal's Avatar
Are you going to bring a trailer for your lifts when you go camping?
I'm hungry!
crazycal is offline
Old 07-04-2015, 09:41 PM   #1071
Leave it to Jack to outdo everybody.
Love it!
Tango is offline
Old 07-04-2015, 10:28 PM   #1072
Ha Ha Tango, you made me laugh. Can't wait to see the clever way you solve the jack problem! Jack
ol trunt is offline
Old 07-05-2015, 10:45 AM   #1073
Not really gonna be "jacks". Just adjustable stabilizer/supports. Have one mostly made and hope to wrap up the other today.
I know,I know..."without pix...etc., etc."
Tango is offline
Old 07-05-2015, 11:06 AM   #1074
Old 07-05-2015, 08:08 PM   #1075
Details, details,details --- Seems the big stuff goes fast. It's all the little sh*t that eats yer lunch.
At least both of the deck mounting plates are done. The gray square tube will form the innermost deck support.
4 - 9/16" bolts should hold this sucker in place. At least this way, If I get rear ended (or back into a boulder), I can remove the deck fairly easily. The 3 in a triangle are bolted through 2 - 1/4" plates and the other is threaded in. 3/16th" x 3-1/2" x 2" C-channel will weld where the beveled edges are.
And here is what I came up with for supporting the deck when down. 2 sections of 1" blackpipe with 5/8" all-thread run up through 2 nuts that are welded in place inside the tube. Here it is partially extended...
...and partially closed. They each have 16" of travel so I should be able to adapt to most terrain. The "shiny" spots are where the bolts are welded in. Each will hang from a swivel mount and have a 4" x 5" foot plate on bottom.
Still waiting on my main frame crossmember.
Onward!
Tango is offline
Old 07-06-2015, 11:27 AM   #1076
Ah, the old linear actuator trick--with you being the actuator. Jack
ol trunt is offline
Old 07-07-2015, 12:06 AM   #1077
Linear is good --- And...self actuation keeps it simple.
Tango is offline
Old 07-07-2015, 02:26 PM   #1078
Engine: 190hp 5.9 Cummins
I like simple.
Nothing wrong with some manual labor.
nat_ster is offline
Old 07-07-2015, 05:53 PM   #1079
opus's Avatar
Chassis: All-American R/E
Distraction post:
opus is offline
Old 07-07-2015, 06:38 PM   #1080
Sheer bus porn...
EastCoastCB is offline
Closed Thread
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
