Old 10-20-2014, 10:25 PM   #781
Re: '46 Chevy Shorty
Howdy Jack --- Eaton can pretty much engineer whatever you want. My new springs will be about half the originals spring rate of 4000 pounds before the overloads kick in (the old are WAY too stiff & bouncy) but will also drop the rear about two inches (it was about 3 inches high in the back). Of course I am guessing at all this, but hope it will ride softer and sit closer to level when all is said and done. I am also adding shocks to the rear which it never had. When I ordered the front springs, I had them compensate for the Cummins weight by upping them about 300 pounds. Who knows where it will all end up, but here's hoping for a little better ride. What can I say...I'm just not an airbag kinda' guy.
The window inserts will get riveted to the inside, then the flange mount windows go in with some seam sealer on the outside. Might add a couple of screws through the window frames into the outer skin to firm everything up. We'll see. I wish the HD windows were the flange mount type, I'd be all over them. So much easier to make weather tight.
Just picked up six new rims to go with the new rear axle. Dropping them off manana for sand blasting and primer. Still thinking through what their color scheme will be. Plaid? The the new rims will also fit the front axle but I need to make a couple of small spacers since the center pilot hole is bigger on the new rims than the old. The new rear spring mounts should be ready for pick up from my sheet metal shop on Friday and ready to weld on. Then...it's a couple of weeks before the rear springs arrive. Guess I'll be back on bodywork till then.
Onward!
Old 10-20-2014, 10:57 PM   #782
Hey Tango, the HD shed windows (now called series 2000) actually come with the flanged edges. I had to special order them without as though they were to be installed in a block wall. They'd be a snap to puit in those nice rectangular openings on your bus. Jack
Old 10-21-2014, 10:04 AM   #783
Really ---- Hmmmm, I may have to take a look after all. Are they aluminum frames or vinyl? And it seems I recall them available in double pane glass. Ya...I definitely need to check them out, thanks Jack.
Old 10-21-2014, 11:38 AM   #784
Yup, all the good stuff. 1/8" glass (rather than 3/32" standard residential), "e" coating, with or without venting between the panes, aluminum frames with white powder coated finish and screens. I have to laugh. I feel like I'n trying to sell an ice cube to an Eskimo I know what ever you choose will be a class act. Jack
Old 10-21-2014, 05:20 PM   #785
Thanks Jack --- I WILL be checkin'em out.
BTW...I just ran across a "sale" item at Northern Tool that got me to thinkin' (dangerous...I know). But I went ahead and ordered 6 rolls of the open type tool box liner. It is non-absorbent and mold & mildew resistant. No, I don't have that big a tool box. I'm gonna try it as underlayment for my floor. Don't have the headroom for a bunch of insulation but dead air just happens to make a pretty good thermal break. Might even help a bit with sound. Yet another adventure in the Land of Misguided Science Experiments! But hey, stranger things have gone into homemade RV's. A few of'em even worked.
Old 10-28-2014, 12:06 PM   #786
Hey Jack --- the Depot here has never heard of "shed windows" nor could they find anything designated a "1000" or a "2000 Series". They looked for a half hour under Anderson and every other maker they carry. Yours might be a California thing (according to HD). They may be somewhere in their system but the local yokels just can't find'em. Had my hopes up as the "Real RV" windows are over $300 bucks apiece! Gotta' wonder if I could get them through the store you went to and have'em shipped. But I'm still not clear as to whether the brand you found is available as a "clamp ring" type. The inner and outer frames being separate and screwed together to pull in and "clamp" the wall all around. (?)
Old 10-28-2014, 12:24 PM   #787
Hey Tango. Your local HD guys are sandbaging you according to my local guy. I'd asked about remote delivery to you from my HD store and it should be possible. What is the thickness of your walls where you capped over the original window opening? From your pics it looks like the edges of the opening are flat like mine are. That makes it simple to just screw the block wall style shed windows into the sides of the opening and seal the outside edge with Silkaflex 220+. That way you can remove the entire window, frame and all without messing up the finished interior should the need arise. As I mentioned before, you can get the windows with a standard mounting flange like you'd use on a stick built house. I'll stop by HD today and get some measurements for you as well as talk to the sales guy some more about shipping. Don't buy those $300 windows just yet--lets see what else can be done. Jack
EDIT: The HD window guy will be back from vacation 10/31/14 at 0800. I'll catch up with him then. J
Old 10-28-2014, 03:50 PM   #788
Muchas Garcias Bud! --- no rush. My heirs will likely have to finish this project anyway.
BYW...my window measures are:
23-1/8" wide x 18-11/16" tall x 2" deep
Old 10-28-2014, 10:25 PM   #789
Hey Tango, You probably ought to get on the stick and finish your bus! Perhaps your heirs are more open minded than mine, but mine have no use for an ancient Skoolie as best I can tell. That's part of why I busted my hump to finish the thing up. I'll try to wear it out so "they" don't have to deal with it . Wiffey is good with it but not really up to accepting the baton once I'm gone--Oh well.
Our next trip is to Lake Mead In the middle of November. The "real" bus folks are having a non rally and I sort of inserted myself (and Honeysuckle Rose). Though I am assured that my Skoolie will be welcome, because of its lack of "big dog" pedigree, I'm a little shy. But then I've spent most of my life being the t--- in someone's punch bowl, so why should this be any different?????
But, as Lost ranger would say, "I digress". That 2" measurement seals the deal. I'll get the info for you on Fri. Jack
P.S. How many windows do you need and did you leave a little wiggle room in your measurements--I left 1/8" in each direction--perfect! Jack
Old 10-28-2014, 10:50 PM   #790
I hope you plan on coming back from Mead with lots-O-pix! --- Never was much on pedigrees myself. Rescue mongrels make the best dogs. But then, maybe it just takes one to know one.
I'll be needing 4 windows, all the same size. And I could probably take another 1/16th off the height making it 18-5/8" tall, width should be fine at 23-1/8". I'll just buy another tube of Seam Sealer.
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 08:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 10:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 09:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 03:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-25-2007 12:58 AM
