Closed Thread
Old 05-20-2015, 02:04 PM   #961
Thanks all for the feedback --- Especially those of you who have "been there, done that". The humidity was one of my biggest concerns and there seems to be total agreement that where the sawdust is concerned...drier is better than wetter. I may have to reconsider where said potty will be located, but with so little space to build in it could get tricky. If I could build one light enough to move about conveniently, maybe I could get by with removing it when the space is used as a shower, letting the space dry a bit and putting it back.
My question about venting came from the fact that most factory built composting toilets seem to have their own small fan & vent system built in and wondering if it was really necessary. The bath itself will have a high mounted wall vent & fan to help reduce the interior humidity from the shower. From what I'm hearing/reading, that should be adequate.
Need to get out my grid paper and play "what if" again.
Tango is offline
Old 05-20-2015, 02:27 PM   #962
A simple, albeit not glamorous combo is to build a sturdy 'shelf' and hinged frame (I'm thinking 2x4ish at the wall with a hinge, that is 5 gallon bucket high, and has a toilet seat attached, with hinged front legs that fold down like a card table. the bucket frame (with seat which can be flipped up against the wall during showers when you remove the bucket. You could get fancier and make a recessed closet to hide it in the 'wet wall' too.
You could even build a bucket shelf and sawdust container into that brilliant door idea of yours. If the toilet/5gal bucket is not a permanent fixture, you can make that fancy door a full quarter circle and as big as your shower box.
~Pamela
SassyLass is offline
Old 05-25-2015, 10:53 PM   #963
More Minor Movement --- Happy Memorial day to all! What a great time to get a little work done. I managed to fab & fit the brackets I needed to mount my new floorboard & doghouse. Also started on the new dash/firewall. Thanks to the engine sitting so far back, my new firewall is where the original dash was located.
This is the raw metal for the firewall/dash. 14 ga. steel...just a trial fit.
Here it is with some angle added that will attach to the rest of the unit.
And here are the angle iron pieces that I had to fab to attach everything else to (the black material around the edge of the opening).
The floor & doghouse are gonna be a bear to fab as they absolutely MUST seal up tight all around to keep out all the stuff that is never supposed to get inside (exhaust, rain, mud, birds, wombats, whatever...)
Meanwhile...
Onward!
PS...just looked out my door and there is nearly four feet of water over the road. Been a really wet year so far.
Hey Kalifornia...bring buckets!
Tango is offline
Old 05-26-2015, 09:53 AM   #964
opus's Avatar
Chassis: All-American R/E
We use sawdust in a bag, in a bucket. There really is no odor at all. I've read where more and more folks are using them for their "homesteads" as well.
opus is offline
Old 05-26-2015, 11:56 AM   #965
At the risk of asking for gorey details...what about toilet paper? Does it go "into the mix" as well? Is "RV Tissue" better suited to quickly break down?
Tango is offline
Old 05-26-2015, 12:40 PM   #966
opus's Avatar
In the mix...it adds color.
opus is offline
Old 05-26-2015, 01:24 PM   #967
Have fun! fire walls and tranny humps are a bear, especially if you make them removable
bansil is offline
Old 05-26-2015, 02:35 PM   #968
Roger that Bansil --- This has been a head scratcher but I think I finally have it more or less figgered out. But to complicate things even more...I have to also build a recess into the dash/firewall next to the doghouse for my pedals that I can also squeeze the new steering into. And right now, I'm not even sure whether the Isuzu NPR steering box & column I have will fit. Oh well...that's what cutting torches and mig welders are for, right?
Tango is offline
Old 05-26-2015, 10:40 PM   #969
Rated Cap: 40 Prisoners
What no plasma cutter? Boy are doing it old school.
Dragonpop is offline
Old 05-27-2015, 09:03 AM   #970
Plasma cutter?!...oh Lordy...what are these youngsters coming to?
In my day, all we needed was an old hacksaw blade wrapped with some duck tape on one end!
Tango is offline
Old 05-28-2015, 04:45 AM   #971
Coachwork: ward
Chassis: international
Engine: dt360a
real men dont need the duct tape.
claydbal is offline
Old 05-29-2015, 10:00 PM   #972
roach711's Avatar
Rated Cap: 19
Real men DEPEND on duct tape.
roach711 is offline
Old 05-29-2015, 11:24 PM   #973
Hey Tango. More later but being older than you (no duct tape) I, when confronted with a broken generator bracket on a NEW truck deep in the bowels of Baja, wrapped a hack saw blade in a rag, cut off the busted piece and rigged a new bracket. The Chevy dealer wasn't pleased with my patch but did make good on the warranty. Jack
ol trunt is offline
Old 05-30-2015, 05:37 AM   #974
Coachwork: ward
Engine: dt360a
man, you are old!!!!!
claydbal is offline
Old 05-30-2015, 09:17 AM   #975
Hey Tango,claydbal is callin us old! I got me some rel'tives in Lowsyana whool gladly fix him right up. Just say the word! Jack
ol trunt is offline
Old 05-30-2015, 09:42 AM   #976
We're not "old"... just highly experienced!
Tango is offline
Old 05-30-2015, 05:35 PM   #977
Wisdom comes with age and there is a difference between a wise person
and a wise a$$. Myself I'm just a couple years shy of being as old as Tango's
bus so I hope that qualifies me as sort of wise and definitely experienced.
Old 05-30-2015, 10:17 PM   #978
Hey Tango. As you build your floor and dog house consider placing a layer of "horse stall mat" or similar hard rubber under the cover. Next to lead it is best for dampening the low frequency noise produced by our little diesels. If there is room below the floor, add a layer of the stuff GM and others use on the floor board over the cats. The combination is very effective against noise and heat. I secured that combination to my removable cowl floor with a layer of expanded metal mesh held in place with large washers and 1/4" all thread (welded to floor). It has proved to be very satisfactory. Jack
Edit: I forgot to say----to be a successful wise a$$ you first need to be wise. We qualify-----
ol trunt is offline
Old 05-31-2015, 10:41 AM   #979
Hey Jack --- I'll have to check out the horse mat. Been looking at several different sound & thermal insulating products...the good stuff ain't cheap. My primary concern is the heat. My turbo downpipe will be routed pretty close to one edge of the doghouse. Close enough that I am concerned about whatever sealing material I use around the edges melting or worse...catching fire. I will be using a combination of ceramic coating, insulating tape wrapping and a small stainless shield on that section of pipe to try and minimize the transfer of heat from the pipe, but as you know...those suckers get seriously HOT.
Back to work now, should have a few new pix this evening/tonight.
Onward!
Tango is offline
Old 05-31-2015, 08:20 PM   #980
Hey Tango. I stayed up way past my bed time (it's 6:15 PM here) and still no pics. Now I probably won't be able to sleep trying to imagine the progress you made on the front floor/dog house. Just kidding. Hope the work day went well for you. Jack
ol trunt is offline
Closed Thread
All Or Bussed! 1990 Chevy Shorty Bus mellowdaizy Short-Bus Conversion Projects 6 02-07-2014 07:35 AM
Wayne Bodied '54 Chevy Shorty on Ebay Tango Classifieds | Buy, Sell, Swap 0 09-30-2011 09:52 AM
1955 Chevy shorty in CO: check this out! Stuff Classifieds | Buy, Sell, Swap 2 08-05-2011 08:55 AM
1983 chevy shorty A/C question trentwyrick98 Short-Bus Conversion Projects 0 05-24-2011 02:11 AM
New Member, 1959 Chevy Shorty 59Shorty Skoolie Conversion Projects 2 07-24-2007 11:58 PM
