01-02-2018, 12:11 PM
#2941
Brrrrrrrr! Too damned cold here in the Tropics!
Did not get much done yesterday. A few hours of damp, 34 degree work sent me to Happy Hour early. But I did manage to get a little done.
My crappy Jig Saw got the template for my roof cut but it took quite a bit of sanding/fitting/sanding to get a tight fit.
Then...
...I got a start on an overhead gauge panel. Once again, compound curves complicate the fool out of what should be a simple process.
I soon discovered I needed one of these...
Went down into the 20's last night and will do the same tomorrow.
Thinking of moving to Ecuador.
ONWARD!
01-02-2018, 01:39 PM
#2942
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
Oooh, overhead gauges could be a good way to declutter that dash.
What kinda thinga-ma-widget jig-doohickey did you make there, Tango?
which engine is a 58cc diesel?
Originally Posted by Twigg
Yeah, but that's 58 cu in, not 58cc
Damn it!
That's what I get for trying to be witty and not checking my units and/or math.
444 CID/8= 55.5 in^3 or 7,300 cc/8= 912.5cc
Originally Posted by juliol
Guido, do you still have the air filter assembly?, I have a 1961 that the oil filter assembly is all rusted and not repairable.
J
Nope, sorry, long gone.
01-02-2018, 01:43 PM
#2943
Don't even get me started on that whole "metric" thing!
01-02-2018, 01:47 PM
#2944
Chassis: Saf-T-Liner MVP ER
Originally Posted by GuidoLyons
Damn it!
That's okay ... I got it first time around and didn't want to spoil the joke by being picky
01-02-2018, 02:10 PM
#2945
Year: 1965
Tango-
Cool idea for your bed/couch. Slides out on heavy duty full extension drawer slides:
01-02-2018, 06:22 PM
#2946
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
How's this for COLD? I've got liquid FREEZING inside the fridge - not the freezer part.
01-02-2018, 06:51 PM
#2947
I just lost my third batch of produce from it freezing while in the fridge, not the freezer.
When my cooking oil solidifies its getting serious. Gotta boil water to melt the oil so I can fry a tater.
Of late we're having 40s during the day but its frosting hard every night. You guys seem to be taking the brunt of the jetstream this winter. Thanks.
Robin
Nobody's Business
01-02-2018, 07:43 PM
#2948
Chassis: HDX
Engine: Cat C7
My spuds have all frozen solid! Likewise the onions and apples.
01-02-2018, 07:55 PM
#2949
You can't keep them taters, onions and apples in your basement at this time of year. Well actually you can, but you need to use them all up before they melt. Those tomaters and other healthy stuff turns into mush.
I'm meat rich at this time of year. Chicken, ham, pork roast. They all freeze well. I get my vegetables from the occasional pizza topping. Working on a good case of scurvy here.
Robin
Nobody's Business
01-02-2018, 08:03 PM
#2950
Year: 1965
Hey Tango- Possible solution (or ideas) for your air filter. Not exactly what you are looking for but the size is right CF-812-4 (12" Lg. Filter Element x 8”round x 15-3/4 O.A.L. w/ 4" Intake Inlet Cap)
https://bti-tool.com/overview/
https://bti-tool.com/cf-812-4-buggy-...in-intake.html
Uses a fairly common heavy equipment air filter (Bobcat IIRC) (Donaldson P181054/WIX 42126)
Speaking of Bobcat, might be worth looking at construction equipment for a canister style filter assembly.
More ideas: https://www.donaldson.com/content/da...ccessories.pdf
01-02-2018, 08:06 PM
#2951
Hey Tango. Could you stuff a wiper motor in behind the gauges. Jack
P.S. I just remembered that I have a pair of these new in box. I was going to use them on Honeysuckle Rose until I discovered I need 3 wipers but had not enough room to deal with three motors. Free if you can use 'em. They look like these. https://www.ebay.com/itm/Black-Wiper...item3af829d2ae.
01-02-2018, 08:08 PM
#2952
Chassis: HDX
Engine: Cat C7
What basement? They're right next to my chair! It's been THAT cold. My inside thermometer registered "LL" when the outside thermometer registered "-17ş F "
01-02-2018, 10:13 PM
#2953
Then...
ONWARD!
Happy New Year Tango, heavy on the rum till the cold spell breaks!
Just looking at your setup for guages here. Have ever seen the 4" square duct that is made by Square D? It has a hinged side, weatherproof and oiltight cover and easily adaptable for mounting with simple brackets you can fab. You could run it right across from one side to the other and enter wiring from either end or both for guages. Should help if you decide to go with Jack's wiper motors also in hiding and soundproofing them.
Google or visit an electrical wholesaler to view what I am talking about. Comes in various lengths and even bigger square dimensions but might really look good for gages and accessibility for future. Cut holes anywhere you need them easily for look.
Warmed up here to -8Canadian with 60km/h gusts so snowing sideways, buried again..oh well
01-03-2018, 10:16 AM
#2954
Year: 1965
Few more ideas https://www.cumminsfiltration.com/si...LT32599_05.pdf
The cyclonic filter housing start on 5-35 (but seem to be designed for horizontal mount, not vertical)
Here's the part numbers for the BHAF (Big Honkin' Air Filter)
Donaldson AH1141/WIX 46637 (8.5"x12.4")
Smallest reverse flow Donaldson Era Filter housing is 11"x20" (A110052)
https://www.donaldson.com/en/catalogs/engine/033614.pdf
01-03-2018, 10:34 AM
#2955
Funny, I was just gonna mention Donaldson. Watching Jay Lenos Garage and the Power Wagon he shows has one and made me think of you Tango.
Now back to the video...
2002 E450 Thomas/ U-JOINT 4X4, family hauler
1954 Crown 35 foot RV conversion, guest house
1945? City Bus (unknown manufacture), yard art
1940s 'Binder 7 window, man cave
01-04-2018, 03:43 PM
#2956
Howdy All --- and thanks for the suggestions. I am looking at a couple of the Donaldson filters including the one made for the RZR's but cannot get/find the actual rate of flow Seems to be one of the few on the Donaldson site that does not show it. Will contact them for that info to see if it might work (I need about 400 cfm to feed that little 4 banger). I do know that none of their "reverse flow" filters are small enough for me to use, hopefully one of the conventional filters will be.
The gauge arrangement is yet another tale of two (many) dimensions. Can't really fit anything square up there so I am playing with sheetmetal to see if I can adapt to all the curves involved. Will no doubt call for wasting a fair amount of steel before I can get anything to fit, but hey...I'm getting used to that on this rig.
The weird, wooden widget was a shot at trying to mark a "square" line across the compound surface...it did not work. Off to try something completely different.
ONWARD!
01-07-2018, 10:06 AM
#2957
Still having fits trying to keep things moving. My sheetmetal guy has a couple of projects that have been in the works for months now. And what does he do? He decides to get married and go on a honeymoon! Really!
And getting all the bits and pieces to the new, all mechanical brakes system has been going OK, just slowly. In the midst of that fab work, the machinist/car builder I'm working with takes a week off to arrange a memorial service for an artist we lost here recently...so I can't really gripe much about that one. He is a really great guy who routinely takes on stuff like that. And, truth be known...I am letting them use my studio building today for a service and to try and raise a few bucks for his family.
Might be noble and all that...but the curmudgeon in me still really wants to whine.
OK...rant over.
01-10-2018, 10:05 AM
#2958
Not much progress of late. Between the weather, other projects and simply waiting on other people for parts...the past month or so has been less than productive. Seems everything is creating hold ups.
Like finding a few machine screws.
Looked all over for some low profile stainless steel screws to attach the wooden dash panel. Found exactly what I was looking for online...filled out the order form...then got " Not in Stock". Contact the company and it turns out that in spite of being presented in their catalog...they NEVER stock them. Thanks guys.
Wound up with the plain steel version (which I am going to treat). Since they go through the firewall, the back side will be exposed to the elements and I really don't want that nice Maple getting munged up with rust.
Amazing how much time can get eaten up by little shite like this.
ONWARD!
01-10-2018, 10:55 AM
#2959
I can sure sympathize with you. My bus never had an over the road heater so I've been collecting parts to create one. I ordered the last pieces (special size computer fans) last November only to discover they are coming from China to be delivered between Dec 1, 2017 and Jan 31,2018--not here yet. By the time they do arrive I won't even need a heater anymore.
Between parts from china and my wife, my tombstone will read "Here lies Jack--he waited".
01-10-2018, 11:10 AM
#2960
I know what you mean Jack. And you really have to read the fine print on Ebay. I was shopping for some intercooler tubing a while back and about to hit the "Buy Now" button...when I saw a note that read..."Most products ship within 4 to 5 months". Really?
Same parts from another supplier were here in about 5 days. Same price.
