Old 02-01-2019, 12:14 PM   #1
6-window college student conversion
Hello! This thread is to keep track of the progress with my shortie bus conversion. I am a 19 year old college student based in Seattle, working to convert my 6-window Blue Bird 3800 International bus into a versatile RV capable of taking on road trips and camping, as well as serving as a potential living space for me during one or two of my next several years of college. My bus is named Ahote (uh-hoat), which is from the Native American language Hopi, and means Restless One.
My name is Matthew, and the assets I bring to this build are my spacial reasoning, creativity, mathematical skills, and passion. I have little experience with electricity, plumbing, engines, and carpentry; however, I look forward to learning a decent amount about all of them as I go! I'm hoping to have all the base work completed by June so that I can bring Ahote up with me to Orcas Island for the summer, where I'll be able to take it out to camp once a week or more.
So far I have been able to remove all the bus seats, and a decent amount of the flooring. The plywood beneath is in good condition everywhere but near the driver's seat, so I will be working to remove that seat (and the cockpit), so that I can rip out the rotten wood and repair the leak (which seems to be coming from behind the cockpit). I plan to leave the rest of the plywood as-is unless my father is a lot better at ripping it up than I am. So far I haven't even gotten it to budge.
Mat_te_chu is offline   Reply With Quote
Old 02-01-2019, 12:49 PM   #2
If there's rust under part of the floor, it will be just about everywhere. It would behoove you to remove the whole plywood layer and treat the metal floor.
Removing it can be a PITA, but it is an essential step.
Old 02-01-2019, 12:51 PM   #3
6 window is a great size!
what engine did you get?
Old 02-02-2019, 09:01 PM   #4
With the help of my dad, four crowbars, and two hammers, I was able to remove the walls from the entire bus, as well as the insulation. Most of the insulation was clean, dry, and undamaged, with the exception of one damp piece of insulation. We peeled up most of the rubber flooring today, the rest will likely come up with the plywood once I get the driver's seat out of the floor.
Speaking of the floor, if anyone has advice about getting particularly tricky plywood up, please let me know. This stuff is nailed into the metal floor, and also seems to be stuck down by thick black rubbery glue. I'm having a hard time even getting a crowbar in between the wood and the metal!
Old 02-02-2019, 09:05 PM   #5
I took a circular saw set at the depth of the plywood and ran a cut about an 1/8" away from the row of screws. Then long pry bar and grinder for the difficult ones. Lots of screws had to be ground down after the plywood was up.
Old 02-11-2019, 12:35 PM   #6
I got a DT466E engine on an International 3800 chassis!
Currently I'm working on the ceilings, I should be able to get them all out using a hammer, chisel, and crow bar. My dad will be back with his power tools once all this snow melts, but for now I'm going solo.
In the meantime, I have a pretty urgent question. There are two wires coming up out of the floor behind the driver's seat, a negative and a positive. They seem to be coming straight from the batteries beneath, and they're live. The bus came as-is, so I have no idea what they used to be wired to, or why they're there. I'd like to remove them, any tips for how I can do that?
Old 02-11-2019, 12:36 PM   #7
Follow them to the battery and disconnect them.
Old 02-11-2019, 01:51 PM   #8
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Great engine. It will have plenty of power for a shorty. If you look on the top of the valve cover there should be a sticker showing the power rating. Could be anywhere from 175-215 hp. How much have you driven it? If it's speed limited you can get it removed at an International dealer or any place with the right software.
Dave
Old 02-11-2019, 04:21 PM   #9
Doesn't your International have screws securing the ceiling panels, piece of cake removing the panels.
Old 02-11-2019, 04:33 PM   #10
I wish! It's rivets through and through. Wall paneling is all off and after a couple hours out there today I have three rows of rivets left. Two hours tomorrow should finish it up nice.
Old 02-11-2019, 04:35 PM   #11
I'll take a look and let you know! I would guess that it's speed limited, I drove it 270 miles to get it home from Spokane, and the fastest I got it to go was 75, and there were times it was only giving me 55, if I was on an incline, usually.
Old 02-12-2019, 06:40 AM   #12
ermracing's Avatar
If you're able to get it go 75, there probably isn't a limiter set. Usually they are set at 55 or 60 or 65 I think. 75 is quiet fast enough I'd imagine. Do you remember what revs you were pulling at that speed?
Dave
Old 02-16-2019, 03:05 PM   #13
Does your college have a School of Engineering? Make friends with some students there---engineers love working with gadgets; that's why they're engineers!
Roberta's Man is offline   Reply With Quote
Old 03-16-2019, 01:10 PM   #14
We're making progress now boyssssss
I have removed the rear and side heaters and reconnected the coolant tubing, removed all the plywood, grinded and converted the rust (using Klean Strip concrete and metal prep), gone over the entire floor with Rustoleum primer, reinstalled the drivers seat with new bolts, pulled and recaulked two windows with silicone, and painted every rivet and seam inside the walls with Flex Seal.
I've never been more anxious for it to rain, I'm pretty sure I've nearly solved all the leaks (I'm lucky to have none in the ceiling), and once I'm certain Ahote is waterproof, I'll move on to framing the subfloor with 1x2's and .75" foam board insulation. 2" insulation for the walls and ceiling, and then I'll get to the wiring.
While I wait patiently for the rain to set in (looks like late next week), I'm going to be painting the roof with flat white Rustoleum, so that I can get to work installing the solar panels and deck supports, make sure they're watertight, and ensure my roof has full integrity before I install the ceiling.
Old 03-16-2019, 03:28 PM   #15
Up here on Vancouver Island, I see moss and mildew growing on every RV’s roof (and walls, and...). You might want to think about some level of gloss on the roof, to make removing the flora easier every spring...
Polarweasel is offline   Reply With Quote
Old 03-16-2019, 08:36 PM   #16
Thanks for the tip! Once I finish the paint job the whole way around, I think I'll hit it with a clear spray on coat to make it easier to clean
Old 03-20-2019, 07:30 PM   #17
Do you know the exterior length of the bus?
lettuce_ is offline   Reply With Quote
Old 03-25-2019, 12:54 PM   #18
Solar panels have been mounted!
The brackets look really close together on the closest panel, but I don't think it's going to cause any issues (feel free to share if you believe otherwise). The mounting brackets are steel, and are bolted through the sheet metal with stainless hardware, and on the inside are held in with extra big washers to prevent the hardware from pulling through the sheet metal.
The two panels in the front have their brackets further apart.
Next up is a new skylight and the roof deck
Old 03-25-2019, 01:11 PM   #19
Pics?
Old 03-25-2019, 02:15 PM   #20
Whoops, it didn't work the first time
college, seattle
