Old 02-18-2013, 11:01 AM   #1
Re: 91 Wayne Chaperone - Mental but Gentle
welcome
Old 02-18-2013, 11:23 AM   #2
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
here is what i found on Ebay for documentation for your Wayne.
http://www.ebay.com/itm/1987-Wayne-Chap ... 0d&vxp=mtr
proconsul100 is offline   Reply With Quote
Old 02-18-2013, 10:25 PM   #3
Welcome jgries --- Cool old Wayne and a very handy size. And with most of the demo work done, you are way ahead of the game. But I do admit some degree of jealousy regarding that Wayne booklet. For some reason the 1946 versions are harder to find.
BTW... there is an outfit called McClellan's that just may have some more paper on your rig. I actually found several different pieces of vintage literature for mine there. If not, leave him a note on what you are looking for. He gets new old obscure stuff in all the time.
http://www.mclellansautomotive.com/
Best of luck on the buildout and keep the pix a'comin'..
Old 02-22-2013, 07:46 AM   #4
Okay
1)you can rev engine up->throttle connected
2)when put into park it actually holds vehicle with park lug->linkage connected and flexplate connected to engine
3)assume driveshaft connected-> that would be a loud clanging noise and bus would roll when in park
You should have a 4spd 700R4 maybe the TV cable came loose on the carb/TB actually a good trans
Can you "feel" it engage into drive or reverse at all?
What tranny does it have?
Old 02-22-2013, 08:32 AM   #5
Don't pull it (that might break something)
It may be an electrical issue (water,ice maybe not letting a solinoid engage a band?)
I am no transmission expert (sure theres a forumn you could search on tho )
atleast the snow isn't wet initially , like the rain and mud here
Old 03-09-2013, 12:13 PM   #6
91 Bus Guy's Avatar
Chassis: Chevy G30
Engine: 5.7 V8 TBI GM
Rated Cap: 10
Send a message via MSN to 91 Bus Guy
Jeremy, just a quick question. The switch on the door opener, what does it do? I thought it was to turn on a step lamp or maybe to start the flashers out back working. I can't see it doing anything.
Thanks,
Keith
91 BG
91 Bus Guy is offline   Reply With Quote
Old 03-09-2013, 03:08 PM   #7
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
Thank you for your quick reply. I will just keep on keeping on. LOL Yes my bus had all of the original parts and seats from the factory. On my overhead panel there only three switches, one is for the passenger dome lights, one is for the rear heat and one is for the automatic snow chains. (frankly I an scared to try it, and there is a twist switch for the rear A/C. Not much, but a lot of spaces to add what I want. I think several LEDs for full light and some for mood. Maybe a light show like the van on "Cash Cab." You just never know when my wife start to be inventive.
Keith
91 BG
Old 03-09-2013, 05:14 PM   #8
Thanks,
Keith
If you have a manually operated door and the switch you are referring to is a momentary contact switch that is depressed by the door lever it should be to activate the overhead warning lights. Maybe yours were disabled at some point.
want2camp is offline   Reply With Quote
Old 03-09-2013, 05:43 PM   #9
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
Thanks,
Keith
I don't have any overhead warning lights. This was never a school bus, it was a old folks home transportation bus. I see a place that the lights would have been, but none ever existed.
Keith
PS sorry for jacking your thread, Jeremy
91 BG
Old 03-09-2013, 08:58 PM   #10
91 Bus Guy's Avatar
Chassis: Chevy G30
Rated Cap: 10
Originally Posted by richlindquist
That switch could be attached to a "door not latched" indicator. If it isn't, it might be a good idea.
Rich
Good thought, and thank you. I have a note to that effect and may do that.
Keith
91 BG
63 Wayne/International 63Wayne Conversion General Discussions 12 10-01-2017 10:56 PM
1991 Wayne Chaperone Shorty wont mooooove :( crazycal Mechanical and Drivetrains 0 02-22-2013 08:13 PM
First Timer, 92 Wayne 7.3 grnthmb55 Skoolie Conversion Projects 29 05-14-2012 10:22 PM
91 International Wayne Diesel Dan Conversion General Discussions 2 02-18-2010 01:03 PM
Gypsy Wayne 5gypsykings Skoolie Conversion Projects 2 09-28-2009 04:26 PM
