Old 12-05-2017, 12:28 PM   #71
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Originally Posted by Rusty View Post
Hatches and Access Doors : Southaven RV Parts Store, Southaven RV Online Parts Store
To attach, I would use rivets and aluminum, with an aluminum backer strip so it makes a 3-layer sandwich. Proper seam sealer helps hold.
No idea why I didn't think about a prebuilt unit. Found a bunch of take-offs on ebay for cheap in basically any size/layout you could want. Thanks!
Old 12-06-2017, 12:28 PM   #72
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Ready to mount
IMG_20171206_101033495 by acidburn02zts, on Flickr
IMG_20171206_101003776 by acidburn02zts, on Flickr
It does have drain holes in the stainless bottom tray now. I'll be ordering the access panel/door this weekend.
Old 12-17-2017, 10:35 PM   #73
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Finally more progress other then just buying parts...
IMG_20171217_142451567 by acidburn02zts, on Flickr
IMG_20171217_142500411 by acidburn02zts, on Flickr
IMG_20171217_143826105 by acidburn02zts, on Flickr
Battery tray bolted up...
IMG_20171217_160525951 by acidburn02zts, on Flickr
No lower then the body...
IMG_20171217_160604190 by acidburn02zts, on Flickr
And... subfloor is finally done.
IMG_20171217_143917365_HDR by acidburn02zts, on Flickr
My buddy is starting on the cabinets soon and I'll be dealing with the mechanical bits. I just ordered 3 of the 5 gauges I want (Autometer mechanical coolant temp, oil pressure, and pyrometer)... still need voltage and trans temp. Then all thats left parts wise is brakes, wheel bearings/seals, and u-joints for the d-shaft.
A few months and spring will be here!
Old 12-17-2017, 10:56 PM   #74
Robin97396's Avatar
Good progress. I thought it would be to cold up there to be working on a bus.
Robin
Nobody's Business
Old 12-17-2017, 11:17 PM   #75
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Its been in the 50s this weekend... down in the 30s at night. I dont mind 30s-40s... the teens kill my motivation... especially when the wood stove is keeping the house in the mid to upper 70s.
Old 12-18-2017, 02:27 PM   #76
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Fresh Motorcraft ZD9 glowplugs in along with 6.0 powerstroke glowplug harnesses. They fit the ol' IDI nicely.
IMG_20171218_124058522 by acidburn02zts, on Flickr
IMG_20171218_124107721 by acidburn02zts, on Flickr
IMG_20171218_125042893 by acidburn02zts, on Flickr
Need to trim them off and add ring terminals to hook up to the IDI gp controller.
IMG_20171218_125058458_HDR by acidburn02zts, on Flickr
And the old plugs. They were a mix of original ZD9s, Autolites, and Bosch plugs. Thankfully, none of them were swollen or missing bits (which the autolites love to do). The old harness was shot so I'm glad I changed it out as well.
I also got the factory batteries out (not really a big accomplishment... but it's something. Lol)
Old 12-18-2017, 02:54 PM   #77
Robin97396's Avatar
Progress is good. I think the weather is about to shut your progress down.
I know I'm going to put on my big boy, insulated, pants.
Robin
Nobody's Business
Old 12-18-2017, 09:07 PM   #78
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Supposed to be decent here all week and dip down into the 30s by the weekend. I've got the coveralls ready... insulation on the inside of the bus is done so I can always move to the inside work with a buddy heater if need be.
Old 12-23-2017, 04:09 PM   #79
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
I hate cold weather... ...
Anyways.. Pulled the alternator/bracket so I could swap the thermostat out and get the passenger side valve cover off a bit easier. After getting the alternator out of the way, I grabbed the fan and noticed the water pump bearing has a bit of play (~1/16" or so). Although it isn't leaking or anything, not worth the extra effort to change it in 5k miles since everything is already apart. Found a Ford OEM replacement (new old stock) on ebay for $75. Now I have to play the waiting game with all the holidays. It'll probably be after New Years before I get it in.
Oh well...
IMG_20171223_135107603_HDR by acidburn02zts, on Flickr
And yes.. I'll be deleting all those nasty rusty lines and such. I'll also be replacing the lift pump while everything is apart. Already have it sitting in the shop.. it's just a matter of getting motivated to change it now that its cold again.
Old 01-22-2018, 11:43 PM   #80
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Argh I hate that I cant get this bus under roof right now. A month has gone by and hardly any progress. We've been getting hammered with ice and snow over the last 2 weeks but now we are in the 50s-60s.. Supposed to be decent for the next week anyways..
Now that the ice/snow have cleared off the drive.. I decided to make a bit of progress. Not much... but some anyways.
New FoMoCo water pump...
IMG_20180122_213349807 by acidburn02zts, on Flickr
New Motorcraft tensioner and Gates idler...
IMG_20180122_213358282 by acidburn02zts, on Flickr
And new Motorcraft fan clutch...
IMG_20180122_213330900 by acidburn02zts, on Flickr
Only a few little things left before I drop in the radiator and button up the front of the engine. Slowly but surely installing the large pile of parts that has accumulated over the last 4 weeks.
