Old 07-12-2019, 08:29 AM   #1
Engine: Cat C7
A Bus Named Sandy
It's about time to start a build thread. I've had her since December, and I am now at the point of adding to the build. For the most part, it is a stable chassis in excellent condition waiting to be reborn.
The bus: 2005 Thomas FS-65 with a CAT C7 and Allison 2000, under 50k miles. She started life with the federal government at the White Sands Missile Range, hence her name. 23' b to b, 14.5' behind the driver. She is rust free and in excellent running condition.
The build: To date we have gutted her completely, treated the metal floor and primed it. We have replaced the seat with a Dodge Ram seat with integrated seat belt. I also added a hitch with wiring and a backup cam. The RV style windows are out, and new ones are on order.
Layout: We plan to pretty much follow this drawing.
More details to come!
Joe
TeacherJoe is offline   Reply With Quote
Old 07-12-2019, 05:15 PM   #2
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
The ? In the layout may make for a good closet.
Nick
Old 07-12-2019, 10:31 PM   #3
TheHubbardBus's Avatar
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
Sweet ride! Can't wait to see it come together!
- Sharon & Jody
Old 07-13-2019, 01:57 PM   #4
Engine: Cat C7
Here’s a sense of where we’re at. All gutted, furring strips on ceiling mostly in, windows missing, DC wiring run for LED lights and fan. We put in a Maxxair fan and turned the hatch into a skylight. The galvanized pipe is our roof rack. The wood is locally sourced white pine, milled to 3/8” x 4” to our spec by a cool local wood worker. It’s all from one very old slab of wood.
File Type: jpg 6AE29E09-FFBA-4A69-B888-374196B1AC2D.jpg (239.6 KB, 6 views)
File Type: jpg 1064B9DE-D8DE-4418-9C7F-00170DA204B7.jpg (186.5 KB, 6 views)
File Type: jpg C2176A95-9A87-4F3A-905C-8B1ABF54397F.jpg (208.2 KB, 6 views)
Old 07-13-2019, 06:55 PM   #5
Engine: Cat C7
Electrical questions:
I am trying to calculate the correct size inverter and plan the basic components.
1. In looking at the two diagrams below, (I know they are not detailed; this is just for logic), the first has a main 120 panel directing 120v to non-inverter loads and not going through the charger/inverter. The second diagram has a transfer relay (not a manual switch) going straight to the 120 panel. Does the relay do the same job as the main panel in diagram 1?
2. If I will run my 12k mini split only off shore or genny power, and not through an inverter, can I go with this smaller unit linked here?
Joe
https://www.amazon.com/Aims-PICOGLF1...harger+&sr=8-5
File Type: jpg A8FF057E-A707-42A9-B4DB-582B8A4BA04F.jpg (195.9 KB, 4 views)
File Type: jpg AAEC2455-276E-40F0-B42E-E681BD9998BB.jpg (204.1 KB, 3 views)
