Old 01-27-2015, 08:01 AM   #1
Chassis: E350
Engine: 7.3
A/c question
Hey guys,
When I remove the rear a/c is the front a/c still going to work?
Turtley12 is offline   Reply With Quote
Old 01-27-2015, 09:33 AM   #2
Chassis: Ford E-350
Engine: 351ci triton v8
My front and rear ac worked together as a system. The front wouldn't work unless the rear was on. They shared a compressor but I think they have separate evaps. I had the carrier system in my bus. It is now removed. No more AC.
Jandrew is offline   Reply With Quote
Old 01-27-2015, 09:45 AM   #3
Chassis: E350
Engine: 7.3
Does anyone know if it's possible to remove the rear a/c and still have the front operational? It gets hot in Texas!
Old 01-27-2015, 09:54 AM   #4
Chassis: Ford E-350
If you have the same system as me. NO!
Old 01-27-2015, 12:02 PM   #5
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
If it is a dual system with one compressor, an air conditioner guy should be able to cut and seal off the rear section for you to remove.
Old 02-02-2015, 07:48 PM   #6
roach711's Avatar
Rated Cap: 19
My 2000 E-450 Aerotech had a roof mounted rear condenser but no engine mounted condenser at all. I removed the rear AC to make way for a shower so I had to put in a new condenser in the engine compartment. Had to buy a few new hoses to hook it up but at least they're easily available.
Old 02-02-2015, 07:58 PM   #7
Chassis: E350
Engine: 7.3
that rear ac blew so cold i decided to keep it. i was able to drop it to the floor fully connected, with only minor things to weld back together. Im going to mount it under one of the bunks so i won't have to run a generator while traveling.
