Old 07-08-2013, 02:35 PM   #1
roach711's Avatar
Rated Cap: 19
AC dash switches + ancient computers thread
Can any of you Eldorado short bus owners tell me how you turn on your air conditioning compressor? Do you use the Ford dash rotary switch or use a switch on the add-on panel that Eldorado installed on the motor cover?
I'm just about to re-work my engine mounted air conditioning and I want to have the wiring right before taking it in to be recharged. Naturally, I can't try turning on the compressor until the system is pressurized.
The Roach Motel
Old 07-15-2013, 07:15 PM   #2
roach711's Avatar
Rated Cap: 19
Re: Aerotech AC dash switches
Well, I started out tracing a few wires and ended up dismantling almost the entire HVAC system in the Ford E-450 engine compartment. The mechanical stuff was easy enough but the control circuits sure had me talking to myself. I now have a pretty good understanding of the E-van HVAC system. Working on a bus conversion is nothing if not a learning experience.
To answer my own question, the front blower fan and AC compressor are, in fact, controlled by the dash switches - at least on the Aerotechs. In my explorations I found one bad dash switch, a blower fan on it's last legs and a broken fan resistor so it wasn't a total waste of time.
I also rebuilt the van air conditioning and removed 60 feet of AC hose (while cleverly absorbing quite a lot of compressor oil with my T-shirt ). Not bad for someone who didn't know diddly about auto air conditioning three weeks ago.
The Roach Motel
Old 07-16-2013, 10:14 AM   #3
roach711's Avatar
Rated Cap: 19
Another thing I learned:
Don't use penetrating oil in plastic parts. The resistor connector was being stubborn so I sprayed on some PB Blaster and waited 10 minutes. The connector came out all right, but in little pieces.
The Roach Motel
Old 07-16-2013, 11:08 AM   #4
I had nothing useful to say, so I didn't
but watching the onesided question and answering....I figured someone had to break in
never ssen PB break down plastic, i have melted some with old skool sprays
Old 07-16-2013, 01:12 PM   #5
roach711's Avatar
Rated Cap: 19
If the rest of the world had that attitude there'd be one TV channel with three hours of programming a day.
The Roach Motel
Old 07-16-2013, 01:33 PM   #6
3 hours a week I would say.....
Malkieri is offline   Reply With Quote
Old 07-16-2013, 02:42 PM   #7
See the perfect world already has an editer .......... remember when the internet was only museums and porn? except for the "weirdo's" typing at each on a black or green screen
Old 07-16-2013, 03:59 PM   #8
roach711's Avatar
Rated Cap: 19
There were museums ??
The Roach Motel
Old 07-16-2013, 04:09 PM   #9
I bet they had porn too if you looked hard enough!!
Old 07-16-2013, 04:21 PM   #10
Those were called classic paintings
Electrical Safety Switches DaRealGuru Electrical, Charging and Solar 6 10-08-2013 02:20 PM
Who uses a dash cam? bapos Everything Else | General Skoolie Discussions 11 03-18-2013 05:57 PM
Switchplates and switches wtd Electrical, Charging and Solar 6 11-29-2011 03:23 PM
Cannibalizing Computers lornaschinske Conversion General Discussions 13 02-02-2011 10:07 PM
quality switches/elec. components for new dash adamanderr Electrical, Charging and Solar 6 04-13-2009 02:52 PM
