Old 12-26-2009, 06:40 PM   #21
Re: adventure bus
their should be a sticker on the drivers door or door jamb with axle capacities and year built info,also the vin number in the dashboard, read it thru the windshield can be decifered to get the model, see a dealer or insurane agent, from the pictures that you posted its a 1 ton gmc van chassis with dual rear wheels, the drivers door info will give you the axle weight capacities to properly size the brakes, and their should be an emissions/tune-up engine id tag under the hood probably on the radiator support.
Old 12-28-2009, 06:46 PM   #22
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: adventure bus
Looks like a Chevy or GMC G30 DRW to me.
HOWEVER: I don't think you have the year correct. That body style ran until 1995. 1997 wiould be the new Express/Savana vans. You may well have a 1997 BODY, but it's on a 1995 van CHASSIS. Is the engine the TBI 350 or the "Vortec 5700" multi-point injected 350?
Jarlaxle
Old 01-01-2010, 04:10 PM   #23
Coachwork: blue bird
Chassis: gmc
Engine: 350
Rated Cap: 16
Re: adventure bus
its a tbi 350 and the van is a 96 with a 97 bus conversion.
Z28Justin is offline   Reply With Quote
Bus Life Adventure BusLifeAdventure Short-Bus Conversion Projects 14 11-26-2014 01:31 PM
Bus Life Adventure BusLifeAdventure Short-Bus Conversion Projects 2 11-24-2014 10:43 AM
Skoolie Adventure* (*as yet un-named!) scgwagner Skoolie Conversion Projects 34 06-28-2014 12:05 AM
Adventure Bus - Build Log That Guy in Maine Skoolie Conversion Projects 32 02-16-2014 08:04 PM
Adventure Awaits! dentedvw Skoolie Conversion Projects 92 07-07-2013 11:47 AM
