05-18-2017, 11:24 PM
#241
That's an interesting choice for a camp trailer. I keep expecting grandma to stick her head out the door. I'll bet it's comfortable.
Robin
Nobody's Business
05-19-2017, 07:08 AM
#242
Someone needs to tell this kid there's a mobile attached to his bus.
05-19-2017, 10:07 AM
#243
Are you aware that those were used as campers back in the 50's?
Robin
Nobody's Business
05-19-2017, 10:13 AM
#244
The only surviving camping trailers I've seen from the '50s are Airstreams. That ain't no Airstream!! I'm sticking with someone attached a mobile home back there at the last truck stop. How the kid didn't notice is beyond me tho.
05-19-2017, 10:54 AM
#245
Chassis: B3800 Short bus
That there, my friends, is a '62 model Vagabond 10'x46' trailer! While the Vagabond company did make campers this particular trailer is more of a park model, being considered a wide load and all. Not too mention that it is crazy tongue heavy.
Picked it up for $1800 CAD (that's $1329 USD for you foreigners ). Also came with 300 litres of heating fuel which will burn happily in the bus engine.
05-19-2017, 11:15 AM
#246
Exchange rate must be up. That used to be $13.29. And 300 L... what's that you imperialist swine. That's like a 6 pack or something right?
Yes, I know the exchange rate was never at the Peso level and that 300L is short of 100 gallons.
Since it is 10', do you have to have the oversize permit? Are you dragging it along with you on road trips or are you just re-locating and dropping it at the final destination?
05-19-2017, 12:11 PM
#247
We have whole neighborhoods of vintage trailers in FL. They're not nice places to live or visit.
05-19-2017, 12:23 PM
#248
The "vintage" mobile homes are bad enough. Travel trailers tend to be 3 steps below that. I try not to go to those places.
A well maintained mobile home I have no problem with. I've lived in both; nice doublewide with skirting to the single wide that is drafty with the windows closed. The drafty one was mine. My dad's too the cake tho. If you leaned the wrong direction on the toilet to wipe, you'd end up in the basement. He had no basement.
05-19-2017, 12:38 PM
#249
Chassis: Blue Bird
Engine: ISC 8.3
It has a pressure gauge on the non-visible side. I'll get a better picture later.
I had never used one of these before so it took some trial-and-error before things worked out. 5 tries on the first tire before getting it right. Had the bead seated on the second tire with one well placed blast.
That looks nice! I haven't ever seated a bead that way. One or two of the tires on my skid loader have slow leaks that I don't look after very well, so it routinely happens that the tire has leaked down to no pressure at all and then I go run the loader and tug a bead out of its seat. Usually it works pretty well to lift the tire off the ground, put a ratchet strap around the circumference in the middle of the tread area, hook up an air hose with a clip-on tire chuck, and push or pull on the tire manually to minimize the leakage. Then I hold it in that place and pray that the air going in through the chuck is faster than what's leaking out so that pressure will build and eventually it'll re-seat. Sometimes it's very quick; other times I wonder why I didn't just pull the whole wheel off and take it to a tire shop..
The blasting tank looks nice for voluntary tire changes, but I'd rather not carry it with me on a road trip. Has anybody had success on bus-sized tires (say, 11R22.5) with the strap method described above?
05-19-2017, 01:21 PM
#250
The strap method works well to spread the tire beads apart so they contact the rim edges. I've seen it used on 11' tall tires as well as small tires.
Robin
Nobody's Business
05-19-2017, 07:36 PM
#251
Hold on, hold on.. If my history lessons aren't failing me, you're US measurement system is closer to the good ol' British Imperial system than the metric system which we officially use (though we still like feet and inches sometimes )
Ah yes.. The oversized trip permit. We did attempt to do it all above board and legal.. I promise. However, as nice as the folks at the MTO were they couldn't figure out how to fill out an oversize trip permit using a motorhome as the tow vehicle. I read that legally a motorhome has a registered gross vehicle weight of 11,000kg max, but the ownership documents don't outline it explicitly. Anyhow, I wasn't getting anywhere so we picked a Saturday and went for it. Not a cop or MTO enforcement vehicle to be seen during the 75km trip, which was surprising because we had to cut right through town.
This will likely be it's second last move. The final move being the dump. Nah, it ain't that bad. A wee bit of water damage, but it's otherwise quite charming inside.
05-23-2017, 07:05 AM
#252
So you don't plan on dragging it everywhere with you.
05-23-2017, 08:47 AM
#253
No, not dragging it around. I'd need to apply for a permit trip every move, which would get old really fast. Not to mention that it requires a 10km turning radius thanks to the short tongue!
05-23-2017, 09:13 AM
#254
Oh no doubt. That's why I was wondering. Hauling it to a final location makes sense. Using it as a travel trailer sounds risky.
08-08-2017, 09:03 PM
#255
Finally getting around to putting those new rear tires on! After a handful of other related tasks, of course.
The studs are pitted and crusty and the nuts are tired. They're only a couple dimes each, so I plan on replacing them. To get the old ones out I welded the nut on before unscrewing them. This helps by getting the studs good and hot, which would cook any Loctite (if it was used).
Using an air chisel I smashed off the rust scale. Unfortunately I didn't take a 'before' picture, but I'm sure there are some in this thread near the beginning. Then I cleaned the hubs with purple cleaner/degreaser, rinsed 'em well, let 'em dry then applied POR15's Metal Prep. It's nothing fancy. Same thing as Ospho essentially, which is just phosphoric acid with some unknown additives.
Here's the hub after the Metal Prep dries. Before painting wipe the loose white stuff off. I don't work too hard to clean that stuff off.
I managed to get a single coat of paint on, but forgot to take a picture. More tomorrow!
08-08-2017, 09:05 PM
#256
Also, baby goat!!
08-09-2017, 09:37 AM
#257
Baby goat! awesome!
08-09-2017, 10:20 AM
#258
Originally Posted by toplessartist
Baby goat! awesome!
Do they taste better?
08-09-2017, 10:21 AM
#259
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
They don't taste baaaaaad. Much more tender.
08-09-2017, 12:39 PM
#260
Well played sir.
