Old 03-16-2014, 07:19 PM   #21
Chassis: B3800 Short bus
Re: Armageddon: the smell of airborne rust
Originally Posted by Redbear
Originally Posted by jazty
The power supply actually had a knob for adjusting the voltage +/- 4v so I turned it right up. Why not
27.9 volts will be fine with hydrate (wet cell) batteries if you check periodically to keep the distilled water and acid level up. If you are using any kind of sealed batteries, check with the manufacturer's specification for charging instructions. That much voltage will cook most gel-cells once they are fully charged. If they out-gas through the safety vents, there is no topping them back up to replace the lost storage capacity. Somewhere around 27.0 volts ± 0.3 volts might be better in a 24-volt system.
But I suspect you knew that. I just don't want to see anyone else destroy an expensive battery bank by over-charging.
Nice build, by the way. I just caught up with it again to see all the progress.
Thanks for the concern Redbear. This information holds true for charging in general and especially PWM charge controllers. The beauty of the MPPT chargers, however, is that they will take a high voltage (relatively speaking. My model will accept up to 100 volts) and bring it down to a voltage that is appropriate for charging the battery bank. It's hard to see from the photos, but the power supply is pumping ~27 volts into the charge controller's solar panel connection ports and the controller is then bringing the voltage down to ~15 volts which is an appropriate temperature compensated voltage for my 12v battery bank.
Actually, ~15v might be a tad much, but the charge controller can be programmed to charge at a lower voltage. But then again, it is -1000 degrees here so perhaps 15v is just right...
Old 03-16-2014, 11:41 PM   #22
I misunderstood. I thought you had a 24-volt battery bank (more common in coaches), and had the converter connected to the batteries in parallel with the output of the MPPT controller. I thought the meter was reading battery voltage. I did not realize that you were running the converter through the solar controller to step down the voltage. I wondered why you did that, and then realized it was probably a way to use available or bargain equipment.
So divide my numbers in half. Most of the sealed batteries I work with want 13.20 to 13.60 as a charging voltage, ± ambient temperature. That's where the 27.0 volt ± figure came from.
Since whatever you set the converter for will be throttled by the MPPT controller, carry on . . .
Old 03-17-2014, 07:53 AM   #23
Bingo ;) I looked at installing a decent 120vac to 12vdc smart battery charger, but couldn't find anything within a reasonable price range that I'd be happy with. Then it dawned on me: I already have a "smart" charger which can accept 12-100vdc and is already connected to the batteries with 2 gauge wire, it just needs some input power to play with. 27 dollars later the system is charging the batteries. As I mentioned before, the MPPT charge controller also takes into account the temperature when charging the batteries. Few smart charges that I looked at were offering that feature, which up here is important. This is supposed to be spring, yet it's still -21°C (-5.8°F)!
Old 04-16-2014, 11:55 AM   #24
Fun adventure the other day...
About 2 weeks ago I picked up my new house batteries: three US Batteries 12v XC2 155Ah http://www.usbattery.com/usb_us12vxc.html. Real nice. I was quite pleased. I went with three of these because they provided the amount of amp hours I was looking for while fitting very nicely in my battery bay.
Anyway, they sat around for the past 2 weeks as I got the electrical system to a point where I could get some use out of them; the last thing being setting up my inverter. Nothing fancy, just a used 1000w modified sine wave inverter I picked up for $60. I had done a couple modifications to it to make the power switch and display a remote unit, but it ran fine.
I went to plug it in to one of the new batteries the other day and *BAM*! Sparks and smoke. Oh #@$&! What the hell did I screw up?!?! Wiring looked fine. I even used my multimeter to test the wiring. Opened up the inverter and the fuses (soldered to the circuit board.. grr..) were all blown as well as a couple resistors.
After steaming for a while I thought, "Well crap.. That's disappointing. Ah well. Moving on, it's probably time to charge this battery". I plugged the charger to the terminals and the "Reverse Polarity" light lit up. I thought to myself, "What?! I'm usually extremely careful when connecting things." I took a close look.. Seemed fine. Dammit, now my charger must be broken, too! Tried it on another battery and it worked fine so back to the first battery. Still reverse polarity. Pulled out the multimeter, probed the terminals and sure enough. This battery was shipped from the factory REVERSED!!!
I'm not sure if anyone else has encountered this sort of thing, but it truly did blow my mind. I must have checked it 10 times before bringing it in for a refund. They quizzically listened to my story and after showing them the reverse polarity with my multimeter they happily gave me another. The nice fella said he'd see what he could do about paying for my burnt inverter as well, though I'm waiting to hear back about that.
Yowsers...
Old 04-16-2014, 02:21 PM   #25
Engine: 190hp 5.9 Cummins
Wow, sorry to hear about the bad battery.
Old 04-17-2014, 11:50 AM   #26
Yowzer Indeed! --- Yer lucky that rascal didn't blow up in your face! Never heard of a "reversed" battery making it that far out of the factory.
Old 04-17-2014, 04:58 PM   #27
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
OUCH!
Good thing an electrical fire didn't start! THAT was close! Sad to hear about the inverter frying!
M1031
M1031 is offline   Reply With Quote
Old 04-17-2014, 05:22 PM   #28
Yeh, it could have been MUCH worse. Imagine I had gotten so far as to have the batteries all connected together! 2 batteries properly in parallel then one connected reverse... And that's how we build an electrical bomb
Old 05-06-2014, 10:30 AM   #29
Perhaps it's time to post some info about my electrical system. I don't imagine this will be an interesting read for most, but perhaps someone will care to analyze and comment on what I have going on here.
The system is 12v for most everything. Reason? 12vdc adapters and appliances are plentiful and cheap and a small, properly designed 12v system with short runs can stay below 1% loss. I installed a couple NEMA 5-15 outlets and have them connected to an inverter, but I honestly don't have much to run off of the 110vac system aside from some power tools and my coffee grinder. Practically all digital appliances use between 5vdc to 20vdc so it's not hard to find the proper adapter or connector to use them on a 12v system, though sometimes you'll have to make your own.
Power usage:
Worst case scenario - Summer:
  • Ceiling exhaust fans (on medium speed): 2x 2.5a = 5a. 10 hours a day = 50ah[/*:m:1kjvcd61]
  • Range hood fan: 4a. 1 hour a day = 4ah[/*:m:1kjvcd61]
  • Ceiling lights: 12x 0.33a = 4a. 6 hours a day: 24ah[/*:m:1kjvcd61]
  • Refrigerator: 1.1a average. 24 hours a day: 26.4ah[/*:m:1kjvcd61]
  • 12v laptop adapter: 3.5a max. 10 hours a day = 35ah[/*:m:1kjvcd61]
  • Water pump: 5.2a max. 2 hours a day = 10.4ah[/*:m:1kjvcd61]
  • Stereo: 8a max. 4 hours a day = 32ah[/*:m:1kjvcd61]
Total: 181.8ah
Worst case scenario - Winter:
  • Ceiling exhaust fans (on low speed): 1x 1a = 1a. 2 hours a day = 2ah[/*:m:1kjvcd61]
  • Range hood fan: 4a. 2 hours a day = 8ah[/*:m:1kjvcd61]
  • Ceiling lights: 12x 0.33a = 4a. 10 hours a day: 40ah[/*:m:1kjvcd61]
Total: 153.8ah
As noted in the titles, these are worst case scenarios. I usually won't have the stereo blowing my ears out for 4 hours a day. Me and my lady won't typically be showering for a half hour each and running the tap for an additional hour. When I'm doing computer work my laptop will probably be on for 10 hours. My computer reports that under normal usage with the screen at full brightness it is only consuming 28.5 watts, so at 12v that would be 2.2a. Add in the inefficiencies of the adapter (let's be pessimistic and say 20% loss) and I would peg it around 2.6a instead of 3.5a.
Cooking and water heating are done with propane.
I also have a 2000w Whistler Pro inverter for the occasional 110AC tool or appliance I may need to run. If I'm using power tools I won't be using the computer or other loads inside the bus. For heavy building I'll be using a generator.
Battery bank:
3x US Batteries 12v XC2 batteries in parallel @ 155ah = 465ah
http://www.usbattery.com/usb_images/usb_12V_data.pdf
Safe available amp/hours: 465ah * 50% = 232.5ah
Recommended bulk charge is ~10% of C/20 Ah rating. 155Ah * 10% = 15.5a
Charge controller:
40a Tracer 4210rn MPPT charge controller
Max charge rate is 40a. 40a / 3 batteries = 13.33a bulk charge per battery.
To fully charge the battery bank when 50% depleted it will take 232.5ah / 40a = 5.8 hours with ideal solar conditions.
33% (Winter worst case scenario) depleted it will take 153.8 / 40 = 3.9 hours
39% (Summer worst case scenario) depleted it will take 181.8 / 40 = 4.5 hours
Solar panels:
2x 300w ~36v Heliene 72m panels (Realistic output is between 220 - 270 watts)
http://www.heliene.ca/products/detai...,10,20,581,616
Charge controller converts voltage from ~36v to ~13v.
270 watts / 13v = 20.77a
In ideal conditions the charge controller will be receiving 41.54 amps. 1.54amps over the controllers rated input shouldn't be a problem. We'll see
Before buying and installing the wiring I figured out distances and intended power draw per run. All systems are installed with a 1% acceptable loss rate. This website is handy to calculate acceptable loss: http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
Wall wiring in the bus is 8ga. Found it cheap at a local semi repair shop. Battery cables are 1/0ga welding cable. Praxair is practically giving that stuff away... I think it was $2.40 per metre, or $0.73 per foot!! For comparison, Home Depot is selling 12/2 Romex wire for around $0.80 per foot.
So with this set up I'll need to be conscious of my electrical demands, but I don't expect that to be a problem. We don't need much. Lights at night, a couple comforts and some electricity to play with when I'm working or the weather is foul.
Old 05-06-2014, 10:35 AM   #30
Great info. A few folks on here will find it interesting.
Old 05-11-2014, 06:32 PM   #31
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I am stealing some of your ideas! You make everything sound so simple and easy.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 05-11-2014, 09:31 PM   #32
Great Info! --- Many thanks for sharing.
Old 07-08-2014, 10:34 PM   #33
I suppose it's time for a couple updates, eh?
I've been working lately on the sh*#ter/shower. It's coming right along. Here are some pics:
That was a picture of the shower pan to be. I purchased a 2" thick, 30psi, 2'x8' piece of foam board (Foamular C300 in this case) for the shower pan. It's not quite as dense as a Kerdi foam shower pan, which is 48psi, but it should work for such a small area with the amount of traffic it will receive. Also, the foam board I purchased is several hundred dollars cheaper than a Kerdi shower pan. Normal foam board is 20psi, by the way.
I used an old school automotive battery charger and a strand of thin, stainless steel cable to cut a conical shape into the foam. The bolt that the negative terminal is attached to is where the drain is going. It all slopes inward to that point. It looks messy, but after sanding down the ridges it looked much better.
I cut another piece of foam board the same size as the pan, glued it down, then glued the shower pan to that. Should be plenty of insulation for those cold, wet feet.
In this picture the pan is in place and glued down with plenty of PL Premium. I filled a 50 gallon bucket with water to put some weight on it and make sure it wasn't going to do anything funny while the glue set.
Yup, looks pretty rough right now. I was working on the backsplash for the sawdust toilet. Once the polyurethane dries I'll put it together and post a picture.
The shower pan dried so I moved ahead with installing the drain. It's glued in with PL Premium as well. You may be thinking, "What a fool! PL won't adhere to ABS!" and you wouldn't be wrong. However, I read a neat trick where you first lather the ABS up with proper ABS cement then, while it's wet, apply the PL Premium. We'll see how it works. The drain is held down tightly by a 2x4 wedged against the ceiling. I'll be doing the entire room in FRP, so I'm not worried about scuffing up the ceiling.
Wondering why I haven't used thin-set mortar and all the other standard shower installation techniques? Because I don't trust it in a moving vehicle, that's why. I'd expect it to start cracking in no time. I like the slightly flexible stuff best. It's my bus, I'll do what I want!
Old 07-08-2014, 11:47 PM   #34
"It's my bus, I'll do what I want!"
Roger that! Go for it!
Old 07-10-2014, 10:35 PM   #35
Here's the sawdust toilet all together. I still need to add a handle to the sawdust compartment (that little door) and secure the toilet seat down.
The bucket will go in the big compartment, sawdust will go in the small compartment. Pex will get pulled tighter into the corner. Those are just some scrap chunks of wood in the bottom of the box.
By the way, here's some info on sawdust composting toilets, for those who haven't heard: http://humanurehandbook.com/. It's pretty neat. I met a farm family in southern Ontario who use nothing but sawdust toilets. Two in the house and a couple outhouses (they do catered events sometimes). It's amazingly simply, easy to clean and - when done right - smells only of wood. I also have a couple friends nearby who have outhouses set up this way. If you've ever had the dreaded task of dealing with black water then, comparably, sawdust toilets are a real treat to deal with.
Old 07-14-2014, 05:37 PM   #36
Getting ready to paint the roof! Check out that clean surface...
Old 07-17-2014, 08:46 AM   #37
The painting of the roof is looming on the horizon. With that, I finally decided what to do for paint. I'll be using Henry's Solarflex elastomeric paint. 4 (or 5) coats. Here's the thread describing how I decided on that over Hytech BusKote: http://www.skoolie.net/forum/viewtop...art=30#p590324 (This link will bring you to the first post where I actually started making progress)
Old 07-19-2014, 06:25 PM   #38
browncrown's Avatar
Rated Cap: 79 at Birth
Awesome job on the shower pan and toilet!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 07-23-2014, 12:09 PM   #39
Started cutting some FRP for the shower walls.
A template made of tar paper. It turned out to be a good material to work with. It is stiff, so holds it's shape well. However, it does stink like sh*#. It's also a bit tricky to cut with a utility knife since the blade gets gummed up with tar. You can see that I made a mistake cutting and glued a patch on.
FRP does a number on the jigsaw blades..
Here's the first piece of FRP glued in place. The adhesive holds the FRP in place really well. I thought I might need to brace the panel, but not this small piece.
I've also been working on the shower pan. Here's the first coat of RedGard. I used crack prevention membrane where the foam shower pan meets the Hardi cement board curb.
Old 07-24-2014, 06:57 AM   #40
Coachwork: ward
Chassis: international
Engine: dt360a
great work! so you figure the composting toilet will be ok in the humid environment of the shower? i too will be stealing your ideas! thanks.
Rust Buckets norreh1 Classifieds | Buy, Sell, Swap 30 04-30-2014 02:49 PM
The smell of fuel... Henukaw Mechanical and Drivetrains 7 10-29-2013 06:38 PM
The smell of fuel... Henukaw Mechanical and Drivetrains 1 10-27-2013 10:35 AM
Service records a thing of the past? Bad smell here. putterspitt Conversion General Discussions 3 02-21-2011 09:51 AM
After Armageddon Abbott Everything Else | General Skoolie Discussions 14 04-14-2010 11:53 AM
