Old 06-18-2020, 01:20 PM   #321
Chassis: B3800 Short bus
Sealed a leaking oil pan and rear main seal while in Ottawa then driving home!
Old 06-18-2020, 01:42 PM   #322
Good to see an update! Love that green and white bus!
Old 06-18-2020, 07:45 PM   #323
plfking's Avatar
Rated Cap: 34
Glad to see you posting again......have a safe trip back to the homestead.
Don
The Busted Flush
Old 07-07-2020, 10:20 AM   #324
Out grabbing some hay.
Looks like the bus could use a wash!
Old 04-02-2021, 09:16 AM   #325
Still using the bus on a regular basis! Being that we are just coming out of winter it's been used for hauling more than for camping lately. This spring I decided to try out one of those injector shim kits sold on eBay by user "truckrental": https://www.ebay.ca/sch/i.html?_from...m+kit&_sacat=0
I bought the $60 kit, which lacks some of the tools that I already had.
On a T444e in a dog nose bus the job was easy-peasy. Takes about a half hour to get both valve covers off, then maybe 10 minutes per injector if you're slow like me and want to double/triple check everything. Also noticed that the connector came off of 2 of the glow plugs, so I squeezed the female contacts with needle nose pliers to tighten the grip and re-connected them.
I haven't driven it enough since to know if there's much of a difference. Before shimming each injector I did check the clearance using the feeler gauge and there were probably 4 that were well outside of spec, so I expect to see some change in engine operation.
Now, I know that the shim kit is a band-aid fix. The proper way is to get injectors rebuilt and that shimming can ruin the injectors beyond re-use. And that's ok with me I'm not planning on dumping money into this engine ever, really. If ever something costly goes wrong with this one I'll hunt around for a full-length dognose with a lower mileage T444e and do a swap. Though they may be getting harder to find, so I should probably scoop one up soon and put it in my "Resource Pile" (aka junk yard) soon!
Old 04-02-2021, 09:42 AM   #326
Oh, I also shimmed the fuel return valve spring. These mechanical pumps make a fuel pressure gauge bounce around quite a bit. Before shimming the spring the upper PSI was just under 60psi, probably averaging roughly around 50psi.
I used one of the old injector solenoid screws as a shim, ground down to fit perfectly into the valve seat.
Now the gauge bounces almost as high as 70psi, probably averaging around 60psi or so.
Will it do anything useful? Who knows! But it's an easy thing to undo if I don't like it.
Note that the pressure regulator is different on the T444e fuel bowl than the 7.3l Power Stroke. Not sure if this is simply due to the age of my engine, or if it is for all T444e engines.
Here's a fuel flow diagram:
And here's a picture of the pressure regulator housing (not my photo):
I had to undo the return fuel line then unscrew the pipe fitting. That's all that is required to have access to the spring.
Old 03-21-2024, 12:58 PM   #327
Still using the bus regularly.
This past summer I lost an injector and - instead of replacing all injectors - picked up a donor bus with a lower mileage and lower hours engine.
2003 T444e with Allison 2000 attached.
I just swapped the whole engine+transmission, since the Allison has over drive and the Spicer 5-speed did not. I miss the low end grunt of that Spicer, but cruising the highway is much quieter.
I may still look at what diff is in the donor bus to see if it is a better fit.
With the current 4.33 diff ratio I get 1700rpm at highway speed. I have a feeling that might be a touch low; probably doing better around 1900-2000rpm. A 4.78 aught to get that RPM. Any thoughts?
Old 03-21-2024, 01:03 PM   #328
So many apologies for not getting a single photo of the whole ordeal
I took on the job only a couple days before departing for a week long camping trip with the bus up north. It was a busy few days, but with the help of the neighbours tractor we managed to swap the engines. I left home later in the day than I had hoped, but with no issues along the trip!
Rust Buckets norreh1 Classifieds | Buy, Sell, Swap 30 04-30-2014 02:49 PM
The smell of fuel... Henukaw Mechanical and Drivetrains 7 10-29-2013 06:38 PM
The smell of fuel... Henukaw Mechanical and Drivetrains 1 10-27-2013 10:35 AM
Service records a thing of the past? Bad smell here. putterspitt Conversion General Discussions 3 02-21-2011 09:51 AM
After Armageddon Abbott Everything Else | General Skoolie Discussions 14 04-14-2010 11:53 AM
