Old 01-11-2018, 09:07 PM   #1
Year: 2010
Coachwork: Coach & Equipment MFG
Chassis: ford E350 superduty
Engine: 5.4 liter v8
Rated Cap: 7 passenger
arrrgh no start ,..at the end of my rope,....
ok brainiacs,
2010 ford E350 cutaway with a gas v8 collins conversion
will not start randomly (i thought it was cold related but today was in the 40's)
brand new battery (yesterday)
started ran great brought it home from garage
son moved bus early am to plow melting slush
mid afternoon tried to move bus cranks as it should,,, no start
any ideas about what could be causing this? is there a ignition interlock i should check? appears to be totally random if it will start or not
pbeggs is offline   Reply With Quote
Old 01-11-2018, 11:28 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by pbeggs View Post
ok brainiacs,
Tell us more.
Does it beep?
Does it click?
Does it crank (turn-over, but no start)
Is it really moist/humid & have ground issue?
Old 01-12-2018, 12:01 AM   #3
Year: 2010
cranks (very fast,..fresh battery yesterday,.) have it on charger to replace cranking loss
when it starts,... it starts instantly
bright lights
not a real humid area (just got done with -10 for a week)
not frozen (+40 today)
you can go out start it then a few hours later it wont start,.. then maybe the next day it will start. or not
Old 01-12-2018, 12:15 AM   #4
Traveling
Rated Cap: '00
bright lights
Yeah, I still suspect humidity playing a role. Check the ground on the ECM computer (under seat?). Does your bus/State have corrosion/salt?
Old 01-12-2018, 06:18 AM   #5
Johnny Mullet's Avatar
Engine: T444E 7.3L
Anyway to get a scan tool and scan the codes?
Old 01-12-2018, 06:28 AM   #6
Check on a ford forum. A quick search suggests that it could be the crank position sensor. Lots of folks have reported similar issues with that sensor being one of the main culprits.
Roll Your Own Build Thread
Old 01-12-2018, 06:39 AM   #7
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
This or fuel pump..
Old 01-12-2018, 06:45 AM   #8
Originally Posted by leadsled01 View Post
This or fuel pump..
Yes, fuel pump was another one that seemed to be giving the Ford guys fits.
I know the pumps on the Crown Vics are famous for failing and being a huge PITA.
Old 01-12-2018, 06:59 AM   #9
Engine: 5.4 litre
Rated Cap: 12
I know the older fords had 2 fuel pumps, 1 in the tank and 1 on the frame rail. If either one wasn't working they would sometimes run and sometimes not run. P.S. I hate cars.... Try starting fluid for diagnosing.
Old 01-12-2018, 07:48 AM   #10
Traveling
Rated Cap: '00
or the key switch. or the fuel pump relay. or the ecu. or the curse of Henry Ford.
