not sure if the name will stick or not, thought of it just now.
1998 Ford E350 Minibus with Corbeil body.
7.3 Powerstroke Diesel with 166K miles.
Needs one starting battery, new tail and signal lights and a new fuel filler neck.
it will need new tires before i can travel too far, they are good enough for now.
engine runs good, transmission shifts good, it stops and steers good, no rattles or shakes.
Plans are to have twin bed in the back with AGM batteries, propane and fresh water tank underneath all separated by compartments, sink and bathroom on driver side, stove, fridge, table and chairs on passenger side, cabinets above windows and a few on the bottom.
the propane tank will be easy to access through the rear door in case of fire and i have to get out in a hurry in theory i can disconnect the tank and run with it.
there will be a 1000 watt pure sine inverter, 200 amp hours of batteries, 200 watts solar on the roof as well as a fantastic fan and max air vent cover.
i will be adding videos to my YouTube channel as the project progresses.
i can't get this site to accept photos even under the guidelines.
https://www.youtube.com/channel/UCm0...bvftp8Qwszpx8w
