Old 06-06-2010, 06:28 AM   #41
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: Big Mac I bought for $500!!!!!
Originally Posted by bus-ted
I guess I've never been in a Ward bus, but am I seeing correctly- are the floor panels all rivited down, or are they screwed?
Rivoted big time!
M1031 is offline   Reply With Quote
Old 06-06-2010, 06:29 AM   #42
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Originally Posted by crazycal
Will paint stick to that sealer?
So far...... It stuck to my fingers like crazy... I had to work fast because it was sticking to everything!!!!!!!!!
BTW, my ears are still ringing this morning........
Old 06-06-2010, 11:20 AM   #43
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
hearing protection my friend!! lol
whats the name of the gunk your throwing on?
Old 06-06-2010, 11:23 AM   #44
crazycal's Avatar
I mean if you decide to paint your bus. Will fresh paint lay down over it and stay?
I'm hungry!
You Gotta Let Me Fly
Old 06-06-2010, 01:07 PM   #45
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
It's roofing sealer that claims to be paintable...... Time (and budget) will tell.
Old 06-06-2010, 01:08 PM   #46
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Keep tuned for results.
Old 06-06-2010, 09:37 PM   #47
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Originally Posted by Smitty
Floor looks good! Don't get used to all that room though....it'll disappear quickly once you start construction
I found some butyl rubber caulk at Menards, which I'm using to set my windows "into", as well as caulk afterward. Also using it to seal the roof rack flanges to the roof (even though they're welded, so no chance of leaks, just wanting to keep moisture from between them and the roof surface), and any areas of the drip-edge that needs resealed.
It's gooey stuff, paintable....and butyl is pretty good stuff, not overly expensive either...it was under $4 a tube. From what I've used of it, it seems like good stuff.
Smitty
Thanks for the heads-up Smitty!
Well. after two hours of wire wheel grinding, all of the rust is now removed and the floor is now (for the most part) protected. I finally found the truck bed liner I used on my military trucks. So now I'm in great shape once I get some time to apply it. I ran out of sunlight (again) before I got everything completed. Well, tomorrow starts my EMT classes and clinicals. I'll still look in from time to time. But my postings will drop off now for sure. I'll finish on 20AUG10. Testing is shortly after that. Then onto Paramedic school (no rest for the weary)...
Here's the finished floor:
I'll modify the bottom door jam because the rust is so difficult to remove. I'm going to cut the rusted metal out and replace it with an aluminum piece:
Oh yeah, during that storm on Thursday I also discovered the windows leak over the rear axle, so I'll be replacing the windows with sheet metal sometime....... If you look at the first flooring picture I posted above you can faintly see some of the corrosion I'll be dealing with in the future.
Old 06-14-2010, 06:59 PM   #48
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
I guess I need help transferring this thread to the full conversion.....
Smitty, help me please......
Old 06-15-2010, 11:27 AM   #49
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
but whats the brand name? lol
Old 06-15-2010, 12:11 PM   #50
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
I had a rough night last night. I'm beginning to feel better. I'll have an opportunity to find out when I get back out to the farm, probably this weekend.
Just bought a bus. What do y'all think?! hello_im_alex Conversion General Discussions 18 04-07-2012 07:41 AM
Just bought a bus!!!!! swinada Skoolie Conversion Projects 4 05-11-2009 07:45 AM
Bought a bus! Abbott Conversion General Discussions 0 07-07-2008 08:18 PM
HELP I bought a bus! dentarthurdent Everything Else | General Skoolie Discussions 20 11-20-2007 11:22 PM
i bought a bus...now what? abbs681 Everything Else | General Skoolie Discussions 4 07-20-2004 02:01 AM
