Old 08-24-2014, 04:40 PM   #101
turf's Avatar
Re: Bookmobile / Turfmobile
I worked on some unfinished projects today.
the diesel furnace needed to be vented. i had the exhaust just vented under the bus, but you good people were quick to point out that it should exit the apron of the bus body. so i found this stainless steel "thru hull" boat part that makes for a great exhaust port.
here you can see the exhaust tube right behind the new stainless steel port...... it curves up to the furnnace unit.
and cut what i think will be the last hole in the bus! (i hope)
this hole will be a 15/20A plug in for shore power to connect to the battery charger. i can unplug the battery charger from this receptacle and plug it into the bus generator.
more pics when the wiring is finished...
Turfmobile Build Thread
Old 08-25-2014, 11:59 AM   #102
turf's Avatar
speaking of holes......
i never showed the stove exhaust vent hole. the stove is a down draft model, so my vent exit is on the floor..... just so happens its right on top of the generator.
i'll put and elbow and a damper on it to finish it off. i think it will exhaust under the bus towards the drive shaft instead of out the side....the generator door is right there making the outside difficult.
and i finished up the wiring to my plug in.
the holes visible here are the water fill mid way up on the right, the heater exhaust and the electric plug in..... flanking my battery box.
Old 08-25-2014, 12:13 PM   #103
Year: 1994
I have been reading through your conversion and getting so many ideas for my own.. Great job and quality work! Hopefully this isn't to ignorant of a question, but what's the reasoning for bringing the waste tank vent across to the drivers side? Thanks
SitkaConvert is offline   Reply With Quote
Old 08-25-2014, 12:48 PM   #104
Originally Posted by turf
i picked up this battery monitor
but the 15' cable included is way to short, so its just wired temporarily to check the batteries.
but i've been going crazy trying to guess at the batteries..... happy now, to have some useful info
here is the main screen telling voltage and discharge rate
and this screen shows the percent charge and hours to discharge.
Part number/source or link to gage? also what shunts etc and extras needed??
and Redbear kicks Azz...I couldn't of done the Water Heater w/o him
Old 08-25-2014, 01:34 PM   #105
turf's Avatar
its a Clipper Battery Monitor BM-1
it comes with a shunt, you can see it in the picture on the upper left. the included wire (15') was to short to run to the front of the bus, but i just ran a substitute and will mount the panel above the drivers seat. also...it has a limit of 650 amp hour bank.
other than displaying the percentage charge.... it measures the amp hours out that you use... and if you charge.... it puts them back in.
so far..... i really like it!
here is a link to one on ebay..... there are many there.
http://www.ebay.com/itm/Clipper-Batt...3D161374276074
i could not have gone this far without Redbear either
Old 08-26-2014, 04:09 AM   #106
very nice thank you
Old 08-26-2014, 06:14 AM   #107
turf's Avatar
thats a fair question....
the waste tank is next to the door of the bus. For odor control, i wanted the vent to be as far away from any window or entrance to the bus, and i didn't want to put it in the roof.
the stretch of real estate between the drivers window and the rear window seemed like the least offensive place to put it. the vent needs to be higher than the counter level in the sink. installing it in the roof would have been much more difficult. the bus is nicely insulated with spray on foam..... no need to carve more of that out than i need too. on the outside, the vent is 7'+ off the ground on the non camp side of the vehicle. the waste tank should should also be on the drivers side of the vehicle, but there was no room for mine with the generator already there. i will always be backwards at dump stations.
the plumbing has not been fully tested yet..... so its all still a wait and see project. i have my fingers crossed here that it all works.
Old 08-30-2014, 12:40 PM   #108
r_w
Macerating pump!
r_w is offline   Reply With Quote
Old 08-30-2014, 06:13 PM   #109
turf's Avatar
for a long time i considered a macerator pump, or even a macerating toilet.
the macerator toilet even has a warm water bidet built in
but truly the there is no room for a large tank under the bus ......except between the frame rails behind the differential.
it could have been done, but i would have needed another pump for the grey system.
my waste tank location, under the fuel tank, gives me the use of regular rv plumbing fixtures. not $1000 ones.
Old 08-31-2014, 08:24 AM   #110
r_w
I was thinking just the basic macerating pump that fits a normal 3" dump from the black water tank. Still a $200+ solution.
I hate black water tanks so much I am planning a composting toilet. Even though it may cost more than the bus
Old 09-08-2014, 05:29 PM   #111
turf's Avatar
you will find out that everything costs more than the bus!
$3k vehicle +20k in accessories
finally got the last panels up and stained in front, and started on the front benches.
Old 09-09-2014, 06:03 PM   #112
turf's Avatar
and a bit more
Old 09-10-2014, 05:06 PM   #113
turf's Avatar
today's progress:
and another angle
Old 09-12-2014, 07:47 PM   #114
turf's Avatar
getting closer
Old 09-12-2014, 08:33 PM   #115
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I think for someone who has said I don't know what I'm doing through out this thread you have done a bang up job!
Is that the full size of your table? If so why so small? Do you plan to do most of your eating outside?
Do you plan to use some sort of panel on it to convert to another bed?
-Doc
Old 09-12-2014, 11:02 PM   #116
turf's Avatar
thanks for the kind words and thanks for reading!
it is a tiny table!!
just enough room for 2 place settings
honestly, when i ordered it i was just guessing approximate size. it came from the counter top people. and you can see im building my benches now.
first go round with the benches were too big. they extended out enough to prevent walking past the table. the drivers side is right now..... but i still need to shorten the passenger side to match.
on my sketchup floor plan of the bus, it is the outside dimension of the bus. the wall framing made that measurement 8" shorter than it really is. so my small table is still too wide. when i'm done trimming the benches, there should be about 9" of clearance on the table to pass on either side. just enough to trip
no board across the camper for sleepers. passengers 3 and 4 can sleep long ways on the short sofas. both driver seat and passenger seat swivel around to extend the length of the sofa, to accommodate an adult length body.
im a single guy..... the table is plenty big for me and the dog.
Old 09-19-2014, 08:25 PM   #117
turf's Avatar
i started the last 2 pieces of furniture for the bus....
cabinet shelves for both sides, one over the kitchen / seating area, and the other over the passenger side seats.
here is the first one being fitted
and another view
Old 09-19-2014, 08:25 PM   #118
turf's Avatar
getting the finish applied.
tuesday, i have an appointment with the upholstery guy. the bench seats will get upholstered. i'll get cushions for the back.
Old 09-22-2014, 04:59 PM   #119
turf's Avatar
Shelf and dividers on the cabinets
and the pair
you can see i like my kreg jig....makes this easy
Old 09-22-2014, 05:50 PM   #120
Kreg Jigs do indeed make it easy --- But only if you have the skills you obviously possess. Great lookin work!
Anyone need a bookmobile? Diesel Dan Classifieds | Buy, Sell, Swap 2 05-30-2013 12:03 PM
The Bookmobile josetann Skoolie Conversion Projects 13 09-27-2011 08:50 AM
Bookmobile for sale PRyberg Classifieds | Buy, Sell, Swap 0 10-02-2009 06:36 AM
Bookmobile in New Jersey PRyberg Classifieds | Buy, Sell, Swap 0 10-02-2008 05:49 AM
Bookmobile for Sale Anniston Classifieds | Buy, Sell, Swap 0 06-19-2007 10:16 AM
