Old 05-06-2014, 03:47 PM   #71
Re: Bookmobile / Turfmobile
All that's needed now is a cat to lounge right in front of the heater duct.
Old 05-10-2014, 06:42 PM   #72
in the garage, the cats had an affinity for the nitestand, we will see if they are cut out for bus life....
i finished the finish on the steps.....
and then........ i started back on the drain today. time to connect the toilet/shower to the tank! today, i was just cutting and fitting pieces until i run out of parts.
(also pictured ......the fuel pump to the diesel heater)
the toilet is straight over the tank, the shower drain is 12" away..... with the hepvo valve, the 2 won't connect in a straight line between the 2 stubs. so its attached to the pipe that will cross the vehicle for the kitchen sink drain.
and the view from the other side of the bus
the near side pipe is just hanging, it will be fastened up to the frame rail. the drain side has a 2x4 under the frame rail to get the drop across the bus.
the 2 big tubes are the tail pipe (nearest to drain) and the driveshaft.
Turfmobile Build Thread
Old 05-15-2014, 06:17 PM   #73
my closet is coming together today
Old 05-23-2014, 07:33 PM   #74
progress on the bathroom today
the floor of the shower is sloped towards the drain. installing the toilet flush to the floor would have put the toilet at a pretty funny angle for the appliance to work right.
i got some floor patch epoxy and filled the gap between the bus floor and bottom of the shower pan for support of the toilet, and then used some more to try to make a level pad to mount the toilet on.
the epoxy is water proof and should bond to all the surfaces - wood and metal floor, fiberglass tub, and the abs flange.
a few hours into the cure, i used a grinder to smooth the finish.
and here is the toilet set in place.
you'd think i was trying to camp this weekend
Old 05-23-2014, 10:48 PM   #75
i've been thinking about the shower for like......3 years now.
in my prior camping experience, a shower has been a rare occurrence. so i dont think there will be a lot of exposure to moisture. i was resigned to using the frp about 3/4 the height of the walls to retain the wood look.
however, no guts, no glory.... right?
so.... my plan today is to tile the bath walls, most of the way up, leaving the top foot or so the wood.
there will be a 4th wall and a door on the bath, but i think only 3 walls will get tile. and use a shower curtain to protect the wooden wall and door.
any feedback appreciated
Old 05-24-2014, 01:29 AM   #76
very cool product! sorry i wasnt aware of that.
i was very lucky with my bus. the original cabinet work was all done with nice cabinet plywood. im not sure what it is but the closest i've come to match it with is birch.
all the wall panels are original to the bus, just flipped over so that i could start with a clean side, unfinished side. i have and will recycled as much as possible from the original wood work.
the pieces in the bathroom were a bit smaller as they used to be over the wheel well. instead of a single panel, there is an upper and lower panel. im hoping my backer board snugs the wall up and covers my previous mistakes.
so far, i'm happy with the result of the epoxy tub fix. i wasnt sure what kind of results i was going to get. if i were to do it again, i would use a similar but self leveling product.
Old 05-27-2014, 08:41 AM   #77
its just fun to say "schluter kerdi"
cool stuff and i was almost sold...until i saw the price on that stuff
i might be back at the frp option again.....
so still contemplating the inside of the shower.
i was working on my refrigerator cabinet over the weekend and ordered some cabinets for the kitchen.
fridge in the foreground, cabinet in the back
Old 05-27-2014, 02:13 PM   #78
Engine: 190hp 5.9 Cummins
Yes tile will always be 5 times the cost of simple FRP.
Old 05-28-2014, 12:11 AM   #79
and the schulter kerdi doubles that number
on a happy note......
i got my door slider hardware today and it exceeds my expectations. the self closing mechanism is strong....enough so to work out of level (in the shop).... i'm hopeful it will work well when it gets installed in the bus.
slider hardware: hafele slido with demo video
Old 05-28-2014, 06:55 AM   #80
i believe that... same cost as starting from scratch. however, like you pointed out earlier, i've built the bath wrong. to get a flat wall for schulter system i will still need to finish the walls as planned with some other backerboard. then i could install the schulter system, and then my tile. or just backer board and tile... or backer board and frp.
the lip of the shower pan prevents me from having a flat wall at this point. some type of material will have to shim the wall flush to the shower pan.
Anyone need a bookmobile? Diesel Dan Classifieds | Buy, Sell, Swap 2 05-30-2013 12:03 PM
The Bookmobile josetann Skoolie Conversion Projects 13 09-27-2011 08:50 AM
Bookmobile for sale PRyberg Classifieds | Buy, Sell, Swap 0 10-02-2009 06:36 AM
Bookmobile in New Jersey PRyberg Classifieds | Buy, Sell, Swap 0 10-02-2008 05:49 AM
Bookmobile for Sale Anniston Classifieds | Buy, Sell, Swap 0 06-19-2007 10:16 AM
