Old 06-06-2018, 12:42 AM   #601
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
Originally Posted by LoveBusTreatery View Post
Thank you SO much for posting this! I thought I was the only crazy person who wanted to do an epoxy counter... I was thinking live edge slab epoxy river flowing into my sink personally, but I NEVER see any builds with an epoxy counter, so I was starting to think I was just dreaming.
Awsome glad you like it, epoxy counters are defunetly hard to do. Your idea sounds great let me know if you give it a go,
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 06-12-2018, 09:04 PM   #602
What is your thoughts & opinions on this in the front entrance & up the side panels.? Im worried about it crumbling to fast fronm the movement of the vehicle. (grout&stone.) I been putting it off for some time cause i didnt know what i wanted, if this will work & be ok in the long one ill get started, $15 a sheet plus grout i didnt want to just do it & pray for the best, what do you all think yes/no.? Thanks
Blue Sky's
Old 06-12-2018, 11:47 PM   #603
I've always heard that the grout/tile would tend to crack and break over time from the rattles/bumps on the road - but there are people on here who have built some mighty fine fireplace hearths and other things that you do NOT want to crack, so. ..
I think I'd avoid it for two other reasons. How slippery is it when it gets wet? There are stairs involved. Also, how do you seal the grout? While those round stones are cool, there looks like there's a lot of grout showing. While the tile would be easy enough to wipe down, would the grout eventually be a problem?
Old 06-13-2018, 12:13 AM   #604
plfking's Avatar
Rated Cap: 34
I'd worry about the grout cracking also.
What about this.....break out the epoxy again. Maybe buy those tiny mosaic tiles, lay some kind of backer on the floor, lay the tiles in place, and epoxy over them? How would that epoxy handle foot traffic?
Don
The Busted Flush
plfking is online now   Reply With Quote
Old 06-13-2018, 01:58 AM   #605
Wet & slippery is not of any worry to me, their is grout sealer i can add a top layer to protect it, i have seen one tile fire place base but he built it way up off the ground wwde i didnt think bumbs & rattle were of issue, i was hoping someone on here with tile & grout expertise might give me the yay or nay i need to move foward thanks for the reply.
Blue Sky's
Old 06-13-2018, 02:05 AM   #606
Its been months since my first epoxy top & it is holding up very nicly but unfortenetly it does get scratches a little easy, just from my plastic clothing bins that i been setting on top to get clothes out everyday for a couple months did a bit scrathing, so i would never consider it for heavy foot traffic.
I guess i need more time to think.
Blue Sky's
Old 06-13-2018, 08:57 AM   #607
GuidoLyons's Avatar
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
Return those tiles. Tile and grout is heavy and will Crack over time from the vibration and flexing.
They make vinyl stick on tile squares that look like tile, but won't crack because they are flexible.
I've seen them at RV stores like Camping World and online Amazon. They stick on, no grout, no mess. Make sure the surface is clean, smooth, and dry.
GuidoLyons is offline   Reply With Quote
Old 06-13-2018, 12:18 PM   #608
Common guys? Flexible Grout
https://www.homedepot.com/p/SnapSton...FVBcDAodkRsHJw
Old 06-14-2018, 01:09 AM   #609
Attachment 23207
Attachment 23208
Thanks, i didnt buy them yet i wanted to consult with the pros on here before, two nay's & one yay. If they have flex grout than i dont see why it would not work, with a good base, i think ima just go for it. I have been told alot of times what i will do wont work, i like the peeel & stick idea but i always like the feeling of stone/tile & grount under my feet i guess im just wierd. The debate in my head is giving me a headache.
Blue Sky's
Old 06-14-2018, 01:11 AM   #610
I didnt know a such thing exsited thanks for the input o1marc i think you gave me the confidence that i need to make it work.
Blue Sky's
