Old 08-01-2011, 01:59 PM   #1
Atridox's Avatar
Engine: Gasoline
Ceiling ventilation fan
I want to install a ceiling ventilation fan. CampingWorld has them but the install guy says that cutting a hole in the bus is different than cutting a hole in an RV since the RV ceiling is a single ply but the bus roof is two ply (out skin and interior roof). If so, do I need some type of flashing for the inside? How thick is the layer between the two plys of the school bus? Does anyone make a fan specifically for school bus? It is an 87 BlueBird on a Chevy C-60. Thanks, as always.
Atridox is offline   Reply With Quote
Old 08-01-2011, 02:29 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Ceiling ventilation fan
Originally Posted by Atridox
... CampingWorld has them but the install guy says that cutting a hole in the bus is different than cutting a hole in an RV since the RV ceiling is a single ply but the bus roof is two ply (out skin and interior roof)...
Interesting since most RVs have an interior ceiling. It's just luan in our case. But cutting thru should be similar. Drill thru both layers in the corner of your proposed cut out (from outside) and make sure you are drilling straight down. Then use a straight edge to "connect the dots". Should be about 2" and you should have a trim piece for the interior. Flashing should already be part of the fan which installs from the exterior.
Fulltime since 2006
Old 08-02-2011, 02:12 PM   #3
Atridox's Avatar
Engine: Gasoline
Thank you, as always
Ceiling lights tomas_maly Conversion General Discussions 8 05-30-2013 10:02 PM
Carpet on ceiling Soundman1 Conversion General Discussions 12 08-04-2012 02:28 PM
Generator ventilation putterspitt Conversion General Discussions 6 09-12-2011 10:19 AM
what is adequate ventilation for propane tanks adamanderr Conversion General Discussions 4 03-06-2008 07:06 PM
Texture on the ceiling Kirbystud Conversion General Discussions 9 03-15-2006 07:25 AM
