Old 09-12-2016, 09:44 PM   #1
Corked our bus added flatbed
Finally got the flatbed put on our cut-off bus. Still trying to figure out the fenders. Any ideas or suggestions would be great! Also added rolled cork to the bus ceiling as the first layer of insulation. There was a huge difference in the temperature of the ceiling between the cork and bare metal. Next is the pink foam board. Walls are on hold while we continue to chase window leaks! We just found out that the leaks are coming from the seal between the glass and frame and not the frame and the bus! Glad we only have 6 windows to worry about.
Bus Progress by nevittja | Photobucket
nevittja is offline   Reply With Quote
Old 09-12-2016, 10:47 PM   #2
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
are you able to build a frame & just bend sheet metal over the wheel well.? weld it down unless you dont have access to fabrication tools.? if that was mine i would turn it into a hang out deck, put a awning that covers a bbq. a beer keg inside with a tap on the outside a stereo followed by a nice shiny pole in the center but hey thats just me. nice bus tho
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 09-12-2016, 11:36 PM   #3
Carytowncat's Avatar
Woa that's pretty bad ace!
Old 09-13-2016, 12:29 AM   #4
Coachwork: Corbeil - RAMROD
Chassis: IH 3800 66 Pass
Engine: 7.3 IH IDI NA w AT545 hyd
Sweet looking rig.. what's the plan for it?
slidewayzm5 is offline   Reply With Quote
Old 09-13-2016, 04:15 AM   #5
Curious why the cork board AND pink panther's foam board?
Trying to get the insulation flush with the ribs?
Old 09-13-2016, 07:31 AM   #6
Chassis: International S3800
lookin good! that flatbed is gonna look bad ass!
