Old 05-07-2012, 05:29 PM   #1
Coachwork: Ford Eldorado / Aerotech
Chassis: E350
Engine: Ford 7.3 Gasoline
Rated Cap: 11
Custom Screens on 1/4 round windows
Anyone have an ideas for putting screen on the windows I would like like to be able to leave them open without the mosquitoes. My bus has the small sliding 1/4 panel at the top of each window pretty much the standard. please share any ideas you may have or solutions you tried thanks
If the women don't find you handsome they should at least find you handy. ~ Red Green
ptooti is offline   Reply With Quote
Old 05-07-2012, 06:38 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: Screens on windows
You want functionality or bling?
Old 05-07-2012, 07:31 PM   #3
all you have to do is to buy the screen window kits that include the frame, screen, etc and assemble your own and screw them on the outside of the entire window.. they are cheap, and essentially that is how the really old campers had them.
all you do to assemble one is cut to length the metal, and insert the corner pieces, etc...
Old 05-07-2012, 08:39 PM   #4
lornaschinske's Avatar
Rated Cap: 89
I did mine a bit different based on past experiences. My screens are on the inside of the window and are hinged to tip down from the top. I have to tip the screens open in order to open/close the window. But I also don't have to worry about losing a screen while going down the road or them getting damaged. Also they stay cleaner over the winter since they are inside. It was a personal decision that most folks think is strange. But it works for us. And that's all that counts.
Fulltime since 2006
Old 05-08-2012, 09:16 AM   #5
I am in the process of making screens for 4 of my windows. I'm using the standard bronze aluminum frames, but in the 1" width so the screen won't distort them. The screens are the Solar Shade type that cut down on heat dramatically and very tough stuff. The frames are easy to work with, especially with the snap in plastic corners. My windows all have a space at the top that the 5/16th thickness of the frames fits snugly into and I will add two, small screws at the bottom of each to keep them in place. Mine are on the outside so I can open & close the windows easily. Will try and get a few pix, but it will be a couple of weeks out.
Old 05-21-2012, 11:26 PM   #6
Chassis: E350
Rated Cap: 11
Solved: Screens on windows New Pics!
Okay after much thought I managed to come up with this and did all 10 of the windows on my bus application is easy the first window took about 15 mins to figure out a plan then after that about 5 mins per window.
The screen is on the inside so when the windows are closed for travel mode they will be protected.
I used 1/2 foam backer rod $3
screen frame kit with spline $10
fiberglass screen $7
I cut the screen frame to fit into the channel snugly to run vertical between top and bottom channel
then cut the screen larger than the window
jammed the screen in place using the 1/2 foam backer rod as a spline in the channel around the upper curve and a piece along the bottom
then used the spline that came with the frame kit to secure the screen into the vertical screen frame
then trimmed off all the excess screen.
Jabbing the backer rod into the channel to hold the screen
picture below the excess screen is ready to be trimmed off
Finished!
Old 05-22-2012, 07:16 AM   #7
clean install
Old 05-22-2012, 08:17 AM   #8
roach711's Avatar
Rated Cap: 19
This is genius at work. Of course, I'm stealing this idea before you patent it.
The Roach Motel
Old 05-22-2012, 11:33 AM   #9
Chassis: E350
Rated Cap: 11
Thanks guys glad you like, hope it works for you I was thinkin' of drilling a hole thru the channel and screen frame and putting a rivet thru the 2 but things are pretty snug there that would probably be overkill so maybe a dab of crazy glue top and bottom.
** Oh and I forgot to mention on the back side of the screen frame i stuck on 3/16 X 1/2 foam insulation tape runs the length of it leaving it short 1/2 inch on each end this takes up the space between the screen frame and the glass so mosquitoes cant crawl in there.
Old 05-22-2012, 02:57 PM   #10
Rated Cap: 89
Re: Custom Screens on 1/4 round windows
Neat. I really mean "neat" as in a clean install. I'm glad I put our screens inside since I've noticed several screens in the park were damaged in the recent hail storm. I have decided, since David wants vinyl mini blinds, to flip my screens over so they are hinged at the top rather than the bottom. Another upside to the screens being inside, they don't get so dusty since I close up the windows in the dust storms. We have a lot of dust storms here.
Try a drop or two of that EU6000. I think that would work better than crazy glue and can be removed when you need to rescreen.
Fulltime since 2006
Old 07-08-2012, 07:34 PM   #11
roach711's Avatar
Rated Cap: 19
I tried using the foam backer rod to hold the screening in but my screens blew out of the track when we drove the interstate with the windows open. I replaced the foam rod with some 1/4" flexible clear plastic tubing (it's marked "nalgene") that holds the screening in more tightly. I think the tubing looks a bit better in the bargain.
The Roach Motel
Old 02-13-2014, 07:20 PM   #12
Engine: Big Block
I had thought about sewing screens to fit the windows with Velcro strips all along the edge, glue the opposite side of the Velcro around the metal frame of the window, completely, and there you go removable screens, cheap and effective.
MissJaneStrummor is offline   Reply With Quote
Old 02-14-2014, 11:00 AM   #13
fostina1's Avatar
Year: 1982
i plan on doing something similar but with magnets in the corners. stick them on the outside when im camping and bring them in when im not.
fostina1 is offline   Reply With Quote
Old 02-15-2014, 09:59 AM   #14
Engine: Big Block
Will bugs be able to get through the cracks of the screen frame since it won't be flush against the windows?
Old 02-15-2014, 08:47 PM   #15
I just use "citronella" candles -----and scratch.
Screens opus Conversion General Discussions 12 07-15-2011 10:06 AM
Window Screens TygerCub Conversion General Discussions 3 06-14-2009 08:35 PM
window screens ezbme Conversion Tutorials and How-to's 1 05-16-2009 01:55 PM
Window Screens nyrockingchairs Conversion General Discussions 13 08-22-2007 08:55 PM
Windows screens vonslatt Conversion General Discussions 13 08-11-2005 08:35 PM
