Old 09-08-2017, 09:04 PM   #11
Engine: MBE 904
Not much to update. Just painting the other side so you've already seen all that. Put up the backview camera and hit all the trim pieces and lights.
Untitled by asdf asdf, on Flickr
Gatorbait is offline   Reply With Quote
Old 09-08-2017, 10:53 PM   #12
The bus is looking good! What kind of paint and sprayer did you use?
vtxvette is offline   Reply With Quote
Old 09-09-2017, 01:48 PM   #13
Engine: MBE 904
Rustoleum and HF HVLP
Old 09-10-2017, 03:56 PM   #14
Thanks for the response
Old 09-12-2017, 11:20 PM   #15
Engine: MBE 904
Started working on the hood. I bought the repair kit from TAC bus parts. https://tacbusparts.com/sections/cat...sp?cat_id=1478
Washed the inside again.
Made our first interior piece!
The water tank came in today too. Kind of disappointed with the quality. Not exactly square, thin walls, and there's dents/bulges.
Old 09-14-2017, 01:01 PM   #16
Engine: MBE 904
Got the hood buttoned up.
Painted the wheel wells.
Also painted the window trim black. I think it looks a million times better.
Old 09-14-2017, 01:35 PM   #17
Really good looking bus Derek, good work.
Old 09-14-2017, 03:20 PM   #18
that bus is coming together GREAT!!!!! i love the black window trim.. what did you use? I keep hearing people tell me if I paint my aluminum window trim black it will flake off quickly from the elements..
Old 09-14-2017, 03:25 PM   #19
Engine: MBE 904
It's all on the prep work. Just make sure you have a nice clean surface. I used rustoleum. The oil base has a tendency to adhere better and dry harder imo.
Old 09-14-2017, 05:37 PM   #20
good stuff.. did you just washit down with soap and water? rough it up at all? or prime it?
im thinking ill probably brush mine on.. less masking that way.
