Old 03-31-2013, 10:10 AM   #1
Year: 1985
Chassis: Chevrolet CG3
Engine: 5.7 L (350 cid)
Rated Cap: 16
Down n dirty paint job
Looking to repaint my bus without spending a whole lot of money...was thinking about rolling it on and possibly adding sand to texture and hide any imperfections...probably going to paint it the dark brown all the way around...any suggestions would be helpful...thanks
skybluefreeway is offline   Reply With Quote
Old 03-31-2013, 10:52 AM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Down n dirty paint job
Why would you add sand? Our bus is combination of brush (rub rails & bumpers with Rustoleum Hammered) and foam roller (ACE's Rust Stop in a custom tint) The foam roller leave a very slight textured finish. Upside to rolling is that I can touch up the paint very easily and if I touch up with a foam roller, you can't tell it was touched up. The brushed on evened out pretty well (it is naturally textured). I will be repainting part of the brushed on to change the colour. I changed my mind. I'm a woman and that's my prerogative.
Wiped down paint well with deglosser, rolled on 1 coat. Let dry overnight, rolled on 2nd coat. Let dry. No sanding. No wax. Only paint run is one that was in the previous sprayed on paint job. I sanded it but got tired of sanding. Took too much precious time that I really didn't have.
I have a 40 ft paint job. It looks good at 40 ft away. Actually it looks good 3 ft away. Be careful you don't leave roller marks (excess paint on the edges of the paint roller, leaves thick line of paint, use light touch to roll over the line to pick it up and even out).
Fulltime since 2006
Old 03-31-2013, 05:02 PM   #3
Rated Cap: 89
Wouldn't the "sand" texture hold the dirt more? I prefer a smoother texture (ours is like a rough egg shell or fine orange peel - a real orange). Nature washes it fairly well on the rare occasions it rains. I don't wash my jeep (it's allergic to soap), I'm certainly not going to wash my bus.
Fulltime since 2006
Old 03-31-2013, 11:04 PM   #4
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
I have had great success by cleaning the surfaces with TSP, and then using oil based enamel house paint that was mixed with Penetrol (basically linseed oil). I used 1 quart of Penetrol to 1 gallon of paint. The Penetrol made the oil base paint flow like water based latex paint.
I used rollers and paint brushes. The results were a durable and shiny finish that lasted many years.
Dirty Canadian Hank's P-O-S Skoolie Conversion Projects 73 07-06-2019 09:20 PM
Let's talk dirty - as in Black and Grey water tanks.... enthe0gen Plumbing, Water and Waste 8 11-25-2013 11:26 AM
HELP with paint lapeer20m Conversion General Discussions 4 07-04-2008 08:53 PM
When to paint andybus9 Conversion Tutorials and How-to's 16 11-30-2005 08:24 PM
Used Veggie Oil on Dirty Jobs Steve Alternative Fuels | Electric, Propane, Wood & Biofuels 11 10-30-2005 09:05 PM
