Old 02-04-2019, 04:41 PM   #1
2jens1forever's Avatar
Downshifting?
So we are a converting a 1991 Thomas built chevy short bus. Along with the many challenges of the build we are having some driving challenges as well. I already knew it was going to be slow but it will not get past 15mph going uphill. It is an automatic and I would downshift to 3rd gear but there is a blocker of the shifter that will not let us shift down. I know basically nothing about driving a bus so I am hoping you guys could help me. Anyone else run into this and if so how did you fix it or compensate for it?
2jens1forever is offline   Reply With Quote
Old 02-04-2019, 04:51 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Need a little more info. To get the best guesses/advice.
Motor size?
Gas/diesel?
Transmission type?
Or at least a pic. Of the shifter with blocker plate but to me if it has a blocker then it is most likely a 545.
Does the motor still run strong or does it sound like the transmission is pulling it down?
If the motor is giving it its all with know problems then I would say tranny but if the motor is bogging down then I would start looking at the motor.
Depending on what they are depends on the first go to check out points.
Jolly Roger bus 223 is online now   Reply With Quote
Old 02-04-2019, 04:55 PM   #3
It is a diesel and I can post a pic when I head back out there in a few. It seems to run great otherwise. We had it at the diesel mechanic about a week ago just doing maintenance and making sure it's ready for the cross country trip. He did say we have a great transmission on it
Old 02-04-2019, 05:05 PM   #4
Year: 86
Chassis: Ford B700
Engine: 8.2
Is this your style shifter with a block out plate?
Old 02-04-2019, 05:06 PM   #5
Yep sure is
Old 02-04-2019, 05:09 PM   #6
Huh. It almost looks like you could just take that plate of with a screwdriver?
Old 02-04-2019, 05:12 PM   #7
You could take it off with a screwdriver but not sure if I should. Don't want to kill before I get it on the road lol
Old 02-04-2019, 05:14 PM   #8
Year: 86
Chassis: Ford B700
Engine: 8.2
That would be the AT 545 tranny.
A lot of busses have them.
Still need answers to the size motor and if the motor is still giving its all while the transmission isn't shifting or if the motor is losing or not gaining any more power.
With a diesel it can tell us if the fuel filters need to be changed on the motor or if the tranny needs a good flush,filter,fluid change.
For that tranny and a cross country road trip an aftermarket fluid cooler is definitely in order before hitting the road.
Just trying to hear from you if the transmission is slipping or if the motor isn't creating the power?
Old 02-04-2019, 05:19 PM   #9
Year: 86
Chassis: Ford B700
Engine: 8.2
That pic is of my shifter and its riveted through the plastic.
I could take it off with no problems but for me as of now even a down shift isn't going to stop the 545 on a down hill grade and mine even in the mud doesn't up shift until what feels like a solid ground actual speed/torque resistance on it?
Old 02-04-2019, 05:43 PM   #10
It's a 8.2l diesel v8. It feels like the motor is giving it it's all when going up hill. We really slow down when going up hill. Like from 45 to 15 mph.
downshifting, shortbus, slow, uphill
