Old 04-27-2017, 11:38 AM   #1
TobinHagler's Avatar
Engine: 7.3 Detroit Diesel
Rated Cap: 11
DRIcore sub floor?
I have a 20 ft short Bluebird and am itching to get to work in a week or so on the conversion. Currently in the planning stage.
So, pull up floor, clean/derust, seal holes, then......
I was thinking of DRIcore R+ sub flooring. I like the idea of the air flow and the insulation all in one. I would probably screw each one in place with a few self taping metal screws. Then wood flooring over it.
To attach cabinets, bunks, etc I would drill a pilot hole all the way and use long metal screws all the way through.
Thoughts?
TobinHagler is offline   Reply With Quote
Old 04-27-2017, 12:16 PM   #2
Robin97396's Avatar
Welcome
Good to hear you've got a plan. I hope you're flexible.
Robin
Nobody's Business
Old 04-27-2017, 12:19 PM   #3
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by Robin97396 View Post
Welcome
"flexible" is an understatement.
Old 04-27-2017, 02:46 PM   #4
I really like the concept but hate OSB. Especially for use in an RV.
Old 04-28-2017, 03:00 PM   #5
Rated Cap: 11
More spacific
So, I assume y'all don't like the idea? Can you enlighten me as to why not?
Tobin
Old 04-28-2017, 03:04 PM   #6
Chassis: E-450
Engine: 7.3 Turbo
The reason people don't like osb is the edges expand when wet and don't go back. So you can end up with small ridges in the floor that never go back to normal. Buses are known for getting wet floors, so it's something to consider. If you get osb and have to cut, make sure you reseal the edges.
Our build thread
PigPen is offline   Reply With Quote
Old 04-29-2017, 10:48 AM   #7
You could accomplish something much better on your own with some insulating board and marine ply.
Bus floors WILL get wet. And since everything else you build is on top of the floor...start with something that won't swell or react badly to moisture. Tearing everything out later is not fun.
Old 05-07-2017, 03:06 PM   #8
Engine: T444e
Rated Cap: 35
I like your idea other than screwing it down. I used G-P Drymax on top of 1" foamboard in mine, but used PL300 adhesive to attach it. The issue I have seen others mention is the thermal transfer that can occur and the condensation that will be caused by the differing temperatures and humidity levels between inside and outside.
bstewrat3 is offline   Reply With Quote
flooring, insulation, short bus
