Old 12-06-2017, 06:29 PM   #11
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
It could be a 460 but if it is crammed into that it's going to be hot,loud and probably so crammed that you can't get a wrench on anything?
In the late 70-80's ford and almost all American manufacturers went to a metric designation like 5.3litre 305? or the 6.6 litre 400.
I would look to see if it's gas or diesel.
A factory ford diesel was probably around a 7.3 litre that was almost identical to there 460 block?
Jolly Roger bus 223 is online now   Reply With Quote
Old 12-06-2017, 06:51 PM   #12
I'm thinking it's a 7.3 Diesel for sure, that has been the focus of our search and I wouldn't be surprised if it was just a mistake on the sellers part.
I would also love everyone's opinion on the layout we have so far built in sketchup, should I post that here or start another thread? Figured I would try to keep each thread relevant to the title
smiley is offline   Reply With Quote
Old 12-06-2017, 06:59 PM   #13
like others have said unless its highly. modified its likely a 7.3 which is the same block as a T-444E. International manufactured the engines for those fords, so likely someone got mixed up and either called it a 'DT-444E' (seen that name used before).. or assumed a 7.3 and a 7.6 were close enough to call it a DT-466.
if they really did put a 466 in there id love to see it becasue that would be one Mean arse bus!
Old 12-06-2017, 07:40 PM   #14
Robin97396's Avatar
A couple days ago there was one of the larger 7 window cutaway bus that also said it had a 466 in it. It sold fast and at a high price.
Robin
Nobody's Business
Old 12-06-2017, 09:47 PM   #15
Chassis: IH
Ford never installed the DT466 engine in ... well ... anything, as far as I am aware. They did use thousands of the common 7.3 engines (almost the same thing as the T444). Sounds like a mistake on the listing to me.
Old 12-06-2017, 10:56 PM   #16
Robin97396's Avatar
False advertising! I'd make them put the 466 in it. Can you imagine the power?
Realistically I agree with the "it won't fit" theory. And yeah, Cornbinder and Ford aren't that kind of friends.
Robin
Nobody's Business
Old 12-06-2017, 11:59 PM   #17
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Is a nice little bus with the very good 7.3L. Sounds like a decent price depending on tires, rust, intended use etc.
Did you buy it???
Old 12-07-2017, 12:17 AM   #18
Did you buy it???
No we havent bought a bus yet. We have been narrowing our search down and we really like the 7.3 but saw this 466 madness and I had to ask the community.
Do you guys have tips as to what one may want to look for specifically in the '03 E450 7.3's? Should I be looking into the engine/tranny/rear end combo as much as I am thinking?
Also Rusty, to give you background for our intention with the bus, we will be driving it a buuuunch around the US come March time and possibly down to Mexico but we are going to be living in it full time so there is a buuuuunch of work to be done!
Old 12-07-2017, 12:47 AM   #19
Robin97396's Avatar
Has anybody talked to you about the Ford cutaway buses? There are strong opinions against fords and there are better choices out there, not to disrespect anybody that's already got a ford.
Robin
Nobody's Business
Old 12-07-2017, 12:47 AM   #20
roach711's Avatar
Rated Cap: 19
'03 was the last year for the 7.3L. I believe Ford switched over to the infamous 6.0L diesel mid-year.
The 7.3L came with a 4R100 trans and the E-450 used a Dana dually axle, usually geared in the 4.10 range which lets the bus run at 65 mph comfortably. Tires are typically 16" light truck.
Aside from the 6.0L diesel, the only issue I know of with Ford cutaway buses is that big diesel shoehorned into a van engine room. It can make engine repairs an adventure.
The Roach Motel
dt466, e450, short bus
